R.I.P.
twin screwed!!
![]() ![]() ![]() iTrader: 9 reviews
can a fenderwell cold air (supercharger) kit suck up water while driving..?
just curious, i seen my car with the anderson power pipe and sct 90mm mass in it and the k&n nearly touches the bottom of the plastics in the fenderwell...
anybody here of any problems like this happening, i know if i would drive in the rain , i would not try to hit water puddles, but what about normal splashing?....seems pretty protected in there, but you never know.... i tried searching and found 1 which may or may not have been the cause....the filter is pointing in the downward position.. anybody want to put my mind at ease?.
The Doctor
'01 Cobra Vert.
its possible. but i wouldnt think very likely. there has been a FEW ppl on here have had problems with sucking water into the intake and locking the motor.
The Doctor
'01 Cobra Vert.
Just don't go through a big ass puddle.
It is pretty protected from splashing water from the front tires, but I guess anything is possible.
Smelly Fists, Socking Cocks
Millenium Falcon
it's completely possible. don't drive through big puddles... if the water goes up to the body panels in the car, you shouldn't be driving through it in the first place, but u will most likely be sucking up some water
The Doctor
'01 Cobra Vert.
All I know is I wouldn't get it on my car.
But that's ![]() Some people run em' others don't. Just a big word of advice is don't go through puddles.
I have heard of a very select few people having problems with it....IMHO you would have to run the car through a lake to pick up that much water lol
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno * looking for block busting power...cms stage 3 blower cams on the horizon..[/
13.58 @ 102.31
![]() ![]() iTrader: 5 reviews
i always had this dilema also, i was big into the offroading scene with my ranger before i got my mustang. i was always worried about sucking up water into the filter, but the fact is that youll need to pretty much submerge the whole filter to cause a strong enough vaccum to suck up a decent amount of water, im my ranger i ran the stock airbox without the stock snorkle and simply drilled about a dozen 1/2" holes in the bottom of the air box, that way is water did get sucked in it would drain out the bottom of the air box before getting sucked into the intake. if you run a cone filter, which you probably do, you can get one of these covers that are water resistant and still flow great. heres the link and a neat video
http://stuffforyourranger.com/galler...c9bb09995429f8 K&N PreCharger Filter Wraps, DryCharger Filter Wraps, and Airforce Pre-Cleaners |
ask my brother (thepizzle44) why he has a new motor. lol
2008 Cadillac CTS4
as long as you dont submerge the intake into water, you will be ok. ive had mine for a year now and it always rains out here. just be careful when driving
2003 Mustang GT See Garage for mod list....360RWHP,360RWTQ....SOLD 2008 Cadillac CTS4 |
R.I.P.
twin screwed!!
ok, sounds good....i guess i could shorten it some but the 90mm mass is in the fender as well...thats where the powerpipe puts it, so i have the mass and filter in the fender.., but i have all my plasitics in place as well as a front lip....
do all mustangs have a full sheet of plastic across the front end?...because mine does which all is a good water barrier ... just curious..
99 limited edition vert
I have had a fenderwell type cai on my car for 10 years with no problems and I live in washington(need I say more lol) just aviod those 18" puddles or at least don't blast thru them
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
Blown 03 GT
While it is possible you would have to have your front bumper covered before its an issue. even if part of the filter where in water its much more dense than air so the air would just flow in above it.
It is possible to suck up water even on a NA CAI setup. I recall a certain someone on here the went through a unknownly big deep puddle and his engine took an unhealthy gulp of water and bent some rods.
1998 Mustang GT
1:34.43@13.86
right, i would just steer clear of puddles. also, thats the job of your wheel well thinger inside the fender.... mudcover i think its called, to stop all that splashing. but i have also heard of people removing that to get the maximum air flow to their intake pipe which is bad idea i think.
![]() "The only way to learn about a car truly is to break something and fix it yourself..." |
#18 | |
Millenium Falcon
yea, i can think of a few members too. i didn't want to post names cause, well, it's kind of embarrassing unless it was one of those situations where u were forced through the puddle do to a t-rex chasing u..... |
Blown 03 GT
An airfilter would need more than just the tip to dip in water to cause major problem. A few holes in a straw dont equate to filter element. You would have to cover enough in water to where it cant suck in enoguh air then would pull the water in.
R.I.P.
twin screwed!!
ok, thanks for the heads up...i won't be doing no puddle chasing, so i think i'll be fine....
lol
Threads Similar to: can a fenderwell cold air (supercharger) kit suck up water while driving..?
| cold air kit info | redhumphries | Modular Mustangs | 6 | March 7th, 2008 12:10 AM |
| Cold air kit for '96 GT | starman1950 | 96-98 | 11 | March 9th, 2007 09:44 AM |
| jlt cold air or march ram air kit with k&n | jagstang96 | 96-98 | 19 | January 11th, 2007 07:37 PM |
| cold air intake kit? | new 5.0 | 94-95 | 20 | December 14th, 2006 11:42 AM |
| Cold Air Kit | RottManK9 | 99-04 | 24 | October 29th, 2006 10:23 AM |
