13.86@100.3
Aftermarket Shifter height
Which is shorter the mgw adjustable handle or the pro 5.0 handle?
2004 40th Anniversary GT Pro 5.0 Shifter Lowered(H&R Springs) Summit Hpipe w Dynomax weldin mufflers Minor odds and ends Last edited by adrenaline=lifeline; April 18th, 2009 at 06:33 PM. |
2003 mustang gt
yr 1965 @ 88mph
![]() ![]() ![]() ![]() iTrader: 5 reviews
I would say the mgw its allot more adjustable and they also have this one which you can adjust even more.. Mines pretty short i dont have any pics but if u want i can get some..
Mustang Shift Handle
![]() i'm pretty sure that when i move into my own place i'm gonna mount an anti aircraft gun on my roof with somebody manning it 24 hours a day. why? because it would be fucking AWESOME.[/quote] |
Both of these will shorten the throw, however if just used to replace the OEM lever they do nothing to eliminate the stock shifter's vagaries and overall monkey-motion characteristics...
-cliff knight- My Mustang 2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch 3.73s, 262 rwHP/305 ft.lb. Flex-fuel: burns gas and rubber... |
The MGW is shorter.
and better in my opinion.
The problem with all aftermarket levers/handles, bolted up to the stock shifter, is that they are like putting lipstick on a pig (with all due acknowledgments to Governor Palin)
You may end up with a somewhat prettier pig, but it's still a pig--IMHO forget about a new lever and get an MGW shifter, you will not look back...
13.86@100.3
gentlemen i feel like my sig is useless. i have a pro5.0 already and love it, but i want a shorter shifter lever. is the mgw adjustable lever from their site shorter then my 5.0
2004 40th Anniversary GT Pro 5.0 Shifter Lowered(H&R Springs) Summit Hpipe w Dynomax weldin mufflers Minor odds and ends |
#7 | |
![]() ![]() ![]() ![]() iTrader: 13 reviews
I have this one. you can make it extremely short. and then you can make it really long too. very adjustable too. But one of the reason you can make it so short is because on the shifter there are 3 different holes you can mount the handle onto. and then you can adjust the Handle length as well. But i have a UPR shifter base so i dont know if the mgw and Pro 5.0 are adjustable on the shifter like mine.
#8 | |
13.86@100.3
All aftermarket shifters (shifters, NOT handles) I've seen, except the MGW, use the OEM style 2-bolt mounting for the lever.
The MGW shifter is a complete redesign of the OEM unit and uses a different scheme for mounting the handle. ![]() The handle clamps on to the operating lever:
#10 | |
13.86@100.3
see mine has 3 holes on the shifter to Mount the Shifter Handle too. thats why i can adjust mine to be so short. heres a visual. Should of provided the link in my last post. but yeah that handle is really nice. very adjustable.
MUSTANG-UPR Products.com
#12 | |
My point was that the other aftermarket shifters can work with MGW's generic shift handle--however the MGW shifter can not...
Threads Similar to: Aftermarket Shifter height
| Aftermarket auto shifter? | silentlvight | 2005 - 2010 | 35 | April 1st, 2010 11:27 PM |
| can an auto shifter(aftermarket) for an 05-08 work in my car? | o2gtstang | 99-04 | 9 | March 29th, 2009 02:57 PM |
| Best height for a tv | G.T. Rags | The Clubhouse | 15 | November 29th, 2008 11:54 AM |
| Aftermarket shifter lower boot. | gragra73 | 2005 - 2010 | 21 | July 24th, 2008 11:21 AM |
