01 GT 4.6 2V
01 4.6L 2V cylinder heads porting & polishing
Hello,
I'm new to the forum, thanks to all who have contributed to all of the good info in the archives. I would like to get some input on porting & polishing my cylinder heads vs. purchasing the Patriot stage II or III. a- what is the range & consideration of spec's are recommended to provide to machine shop doing the work? b- could having this done potentially be advantageous to purchasing performance cylinder heads. c- what is your experience for those who have done this themselves. d- what are the other options other than patriot and pro;'s and con's, hp/torque effects etc ? Thanks, Tom
01 GT COUPE 4.10 Gears, Steeda Triax Shifter, O/R X-PIPE Flowmaster 40's, DiabloSport Predator Tuner 4000W JL Audio Stereo System, FR500 Wheels Last edited by BOSSHO; April 19th, 2009 at 02:41 PM. |
Well with a stage 3, you'll have to have an over bore of at least .20
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
all the heads available for for modulars are just ported pi ford heads. there is not an aftermarket head casting for these cars yet.
#4 | |
To the OP, these would be what you want to go with if you are even thinking about taking you heads off of your car. You can read about them here. Trick Flow® Twisted Wedge® Street/Strip Cylinder Heads for Ford 4.6L/5.4L 2V - trickflow.com |
01 GT 4.6 2V
thanks for the good info Double0Fox, I've also been awaiting Edlebrocks Heads.
I'm hoping also to hear if anyone out there has had their stock cylinders heads ported and polished ?
01 GT COUPE 4.10 Gears, Steeda Triax Shifter, O/R X-PIPE Flowmaster 40's, DiabloSport Predator Tuner 4000W JL Audio Stereo System, FR500 Wheels |
1999 3V GT/2007 GT D/D
corner carver
I had my pi heads ported, what did you want to know?
OS2 (SW) USNREAR SEAT DELETE FABRICATOR "RSD pics in garage" 99 3V GT/2007 GT DD |
2003 mustang gt
yr 1965 @ 88mph
![]() ![]() ![]() ![]() iTrader: 5 reviews
Welcome to the forums im from tampa so not to far from you im out at bradenton all the time.. But yes allot of people port and polish the stock cylinder heads..
![]() i'm pretty sure that when i move into my own place i'm gonna mount an anti aircraft gun on my roof with somebody manning it 24 hours a day. why? because it would be fucking AWESOME.[/quote] |
2004 mustang gt
![]() iTrader: 1 reviews
how much hp and tq can u pick up by port and polishing of 2v heads
corner carver
That highly depends on your other mods. I had mine done and installed cams with a blower so I see a lot more gain than a N/A enginie from the P/P. N/A with worked heads, cams, CAI, and tune could put you around 300 +/- and a similar TQ gain. A must if you plan on going FI in the future
corner carver
2K
i heard right around 1800, idk if it is something i would do, but apparently you can run a pretty big cam without ptv contact. im curious to see what a stroker motor with a sick cam will do with those heads. i hear you can even port them more. would be cool to get over that 400 mark n/a. total sleeper
13.58 @ 102.31
porting and polishing is never a bad idea, but i feel most people do not consider it if they are staying n/a due to the fact that you have to tear down the top end of your motor. with bolt ons, stock cams, and no nitrous or blower, you'd probably gain 15-20hp i would guess. there are alot of guys with full bolt ons and just cams making 300hp with stock heads. but if you are going to go through the trouble of getting your heads p&p you might as well get some cams while your at it, it will be the best time to do it since your motor will be disassembled
#14 | |
I'm very happy with my patriot stage II heads. The best company out there for ported heads is probably foxlake, but it will cost you. I seem to make similar numbers with the patriots. Patriots heads had some trouble with valve guides, seals and valve height in the past, but they have seemed to work out the bugs since.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
01 GT 4.6 2V
how do i tell if thyre junk?
i got an opportunity to pick up a set of ported heads for 600 - how do I know if its quality workmanship or a future headache? - the seller allegedly bought them from a guy who blah blah blah - but cant provide names or any documentation or specs - any suggestions guys?
02 mustang gt
6.92 @ 99 mph 1/8th
i would stay away from them you never know what the hell you are paying for unless it has a guarrentee...
01 GT 4.6 2V
good choice?
also......if I decided to do a 5.4 swap could I use these heads on a 5.4?
02 mustang gt
6.92 @ 99 mph 1/8th
i believe so....
Moderator
2012 300a gt auto
12.10@116
yes
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
Threads Similar to: 01 4.6L 2V cylinder heads porting & polishing
| porting and polishing an intake? | mystang0673 | 99-04 | 1 | February 9th, 2009 05:56 PM |
| porting and polishing new pics added. | 99v6stang | V6 Mustangs | 0 | March 7th, 2008 06:23 PM |
| Porting and polishing..... great pricing | 99v6stang | 96-98 | 3 | February 16th, 2008 01:23 AM |
| Porting and Polishing | RandoGT | 96-98 | 37 | August 19th, 2007 09:44 PM |
| 2 questions NITROUS and PORTING and POLISHING | 90TANG.GT | 5.0 Mustangs | 11 | July 26th, 2007 02:05 PM |
