The Mean Green
Pilot Bearing....
All I can say is F%@& this mother f@&$in pilot bearing
. I tried renting a pilot bearing puller and it just didnt have enough bite on the jaws, pretty much just chewed up the bearing part. Tried a slide hammer....chewed up even more. So now I have just the sleeve for the bearing stuck in the crank, and it wont budge . So any tips would be great. Im gunna have a beer and calm the nerves now
Billy Weston
A chisel and a hammer....
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
The Mean Green
2002 MUSTANG GT
14.2@100
i used a recipricating saw and metal cutting blade. i cut threw one side being careful not to cut into the crank. then i used a flat head screw driver and a hammer. presto pilot bearing was out.
Billy Weston
The metal the pilot bearing are made is pretty soft. A chisel will knock it out in only a few mins.
Boost gets you laid
there should be notches on the inside of the sleeve so the puller can grip. did you make sure you lined the puller up with them? mine was a pain too.. i got it when i lined them up and put the slide hammer on the puller. you can also try using a propane torch and heating the crank slightly around the bearing. MAKE SURE YOU DON'T BURN THE REAR SEAL. if all else fails just chisel that bitch out of there.
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
The Mean Green
I got it! Only took like 3 hours ans a 6 pack of Corona. Chisel...Chisel.. Chisel...slide hammer
1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
The Mean Green
The damn bearing took longer to get out than the tranny did
1/8 7.95@82.43
Dude when I did mine I had the same trouble lol. I ended up getting a slide hammer and the end that is just a right angle hook fit in there pretty well after the pilot bearing puller effed everything else up. A few hits with the slide hammer and it came right on out lol. *Memory Note* Never use pilot bearing puller when trying to pull pilot bearing
2011 Mustang GT
12.1 @ 116
Grease and clutch aligment tool....
Shove grease down inside the crank till it's coming out, take the pull end off the alingment tool and tkae a hammer to it. With each hit of the hammer add more grease.
Mods in garage. Built suspension and gears since posted times. |
1/8 7.95@82.43
lol I tried that didn't work very well.....Maybe it was just me....hhhmmmmmm lol
2011 Mustang GT
12.1 @ 116
Worked for me
The Mean Green
The carnage....
![]() ![]() But it looks like this now...... ![]() ![]() And thanks to my helper too lol....
TT Bullitt
![]() iTrader: 2 reviews
Seriously, no joke...
Next time use 2 slices of bread. Works like a charm. |
The Mean Green
I was actually reading about that (too late of course) but its like the grease trick but no mess
chisel and hammer......
just using the search option to get the pilot out. the insides broke out of the bearing w/ a puller. left just a sleeve in the crank |
You asking a question? This is like over a year old, but I didn't have any problem using a puller lining it up with the grooves.
nope, just showing that people do still use the search option prior to writing another threat about the same thing that's been covered 100 times
The Mean Green
Way to wake me from my grave...but this method sucks, and is a last resort. Try the methods mentioned before...chisel + hammer sucks!
Its not how fast you drive, but how you drive fast. 2002 Mustang GT... Just The Usual Bolt-Ons ![]() ![]() Bolt on list in Garage.. Last edited by MATT02GT; July 10th, 2010 at 06:49 AM. |
Threads Similar to: Pilot Bearing....
| Pilot bearing question | dafizuck | 96-98 | 2 | March 1st, 2009 05:57 AM |
| v8, 4cyl trans pilot bearing | superbean | 5.0 Mustangs | 0 | October 26th, 2008 06:52 PM |
| i cant get my pilot bearing out | B0B | The Clubhouse | 6 | April 18th, 2008 07:50 PM |
| pilot bearing for 4cyl in 351 | onehot351 | 5.0 Mustangs | 17 | March 12th, 2008 07:03 PM |
| 94 GT to/pilot bearing issues... | WVSNS& | 94-95 | 2 | August 15th, 2006 01:43 AM |
