Valve spring retainer offset?
Okay, I was going to purchase Manley valve springs and retainers but then I noticed there was one with a +.060" and just regular ones, will I need to run offset ones or the regular ones for VT/CMS stage 3 blower cams?
![]() 2004 GT Boosted by Vortech |
Proud American
Ethier will work. An offset retainer I'd typically used in a NPI head that needs higher lift.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
id just go for the regular one(s)
99 limited edition vert
the regular ones are what you need. they only have .547 lift, plus .060 retainers will effect the seat pressure and mod motors don't run that much as it is
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
Threads Similar to: Valve spring retainer offset?
| valve spring upgrade? | V6Power | 99-04 | 3 | December 7th, 2008 05:11 PM |
| Valve Spring Troublee! | tehdwarvenn | 5.0 Mustangs | 12 | September 12th, 2008 08:20 AM |
| Valve spring cups | hooligan | 2.3 Mustangs | 0 | March 31st, 2008 12:57 PM |
| Valve Spring removal | acmillr | 99-04 | 0 | January 7th, 2007 10:53 AM |
