2000 GT
Time to bite the bullet, tranny time..
As some of you remember in my post awhile back, Reverse is stuck
my transmission got f'd up. I have been driving it with only 2nd and 4th for about a month now, cause my DD is also busted. Finally have DD in the shop (damn previous owner f'd stuff up). Anyways what are my options for Trans? I was thinking built t-56 from promotion. Thing really holding me back is do i need a new drive shaft too? I have an aluminum one so don't want to get shafted for that. Or would a new yoke setup work? Doesn't the t56 have a little different length? Spline would be different so i know a new clutch would have to go in also. Options and opinions?
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
13.86@100.3
u cold also do a tko600 or switch to a manual auto
2004 40th Anniversary GT Pro 5.0 Shifter Lowered(H&R Springs) Summit Hpipe w Dynomax weldin mufflers Minor odds and ends |
2000 GT
Yeah i was looking at the tko at promotion also. I like the gearing on that too. Whats the manual auto? Im thinking that would be too expensive. Big thing is getting the supporting stuff that comes with the trans. Like figuring out the drive shaft.
#4 | |
13.86@100.3
FB Performance Transmission Pricing but if u love the ability of complete control of shifts and clutch go t56 or tko.
~C~, The Other White Meat!
If you are going to upgrade, do it now! Something I should have done when I re-did mine. Im pissed about that still. Either way, most definitely go with promotion. I went with a Japser tranny and I am on my 4th Jasper trans...of course all under warranty, but def not worth the hassle. Make sure it comes with a warranty to. I would say go with the t56. I would have if I thought about it prior to.
BLOWN Bumblebeast! 370 rwhp / 381 ft lbs ![]() ~Tuned by JJ at WMS ![]() "Like the blind man says......We shall see...."
2000 GT
Thats what im leaning towards. Durability, and an extra gear to narrow that gap.
Biggest concern is figuring out the driveline issue though... and making sure the drive shaft will be usable? With both the input and output splines being different the drive shaft will need to be changed? Anybody that do this swap know?
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
the driveshaft will be different with the t56. i personally would just get a built t45 from them. i love the shit out of mine, by far the best mod i have done on the car.
2000 GT
Yeah true, im getting a 31 spline rear end going in at same time. Will that affect the drive shaft too? Cause if it doesn't ill probably just get a built t 45 for simplicity.
mm's nitrous mod
2000 mustang gt
no, the rear end wont effect anything, the flange placement doesnt change.
2000 GT
Hmm so really i could just get a t-45 and nothing would need changing. Minus the clutch since the spline change in the tranny. How does the tko stack up drive line wise?
mm's nitrous mod
2000 mustang gt
you will just have to get the conversion kit for the tko swap. the built t45 is plenty to hold up to most situations.
2000 GT
True, pro motion have good stuff. Im thinking more of ratio's though. Would be nice to not have such a low gear in first cause of the KB. It looks a lot cheaper though!
ProMotion Powertrain It looks like 1,600 for a fully built t-45? compared to a t-56 for 2,600 not counting driveshaft issues?
2000 GT
And if im getting whole new tranny from them, what would be the difference between the 3650 and the t-45? Only 100 dollar difference (3650 being more). Would it just be gearing ratio's?
This is the main reason I didn't do the entire 56 swap. I knew though I wasnt going go over 450hp or so, so I figured the 45 would be fine. I just think the 56 is a better transmission overall. My 45 seems to be holding fine. The whole thing is brand new.
#15 | |
3rd Place '11 ROTY
'02 GR-40/SLA Saleen
19.34@42.259
I have everything you need to know and is fantastic to drive now.If the gap is not such a big deal, save yourself a LOT of $$$ and go T-45 as Sweet is saying. Jazzer
2000 GT
Yeah the t-45 will hold 750 hp they say. (pro motion's) Anybody know the real differences between the t-45 and 3560? Is it the gearing since both are built? Between the 2 would it be interchangeable? (like driveshaft and those types of things).
I think ill go the cheaper/simpler route. 1000+ cheaper on the trans, and then i dont have to get a new driveshaft which would also add up. Gap isn't too big of a deal for me... right now i have huge gaps since i only have 2nd and 4th gear working :p
TT Bullitt
![]() iTrader: 2 reviews
Promotion is way over-priced, I'd try using another tranny shop. IMO Liberty's Gears is the best out there, all the pro-stock cars/bikes guys run their stuff (but I'm also partially biased as I got mine from them
).Don't get me wrong, promotion is good, just way to expensive for what they are giving you. To try to answer your driveshaft/clutch ?.. If you have an aluminum driveshaft, you can get it shortened as opposed to buying a new one (I believe 1"). For the clutch (and correct me if I'm wrong), but you COULD reuse your stock clutch if you really wanted to (stock 3650 is 10 spline, stock T-56 is 10 spline), however I don't see the point if you're already putting in a new tranny. Are you trying to go for a budget build or top notch? If top notch I'd say a built T-56 will be just what you need and last forever. However, you might want to look into finding a used T-56 from a Cobra owner as you can find one that will come w/ a driveshaft and crossmember (2 things you need) to save you some money. |
2000 GT
Well a built tranny would have a different input/output shaft. Stock is 10 spline but built is 26 i think. So would need new clutch. Unless a stock t-56.
Going for a strong reliable build but not ridiculous. If i have to get a cross member and shortened drive line then ill probably stay away from t-56 and just get a built t45 or 3650.
#19 | ||
mm's nitrous mod
2000 mustang gt
I have to agree that promotion is not overpriced. They were like $100 more than Jasper, and Jasper was just repairing the broken parts. I ended with a completely new transmission, but after a major headache.
Threads Similar to: Time to bite the bullet, tranny time..
| Time to rebuild the tranny | 69fastback | Classic Mustangs | 3 | January 9th, 2009 06:08 PM |
| tranny is FUBR....time for a bulletproof rebuild | shadow5403 | V6 Mustangs | 1 | November 17th, 2008 10:43 PM |
| Finally time for tranny work... need advice | workinprogress | 99-04 | 16 | April 10th, 2008 04:27 PM |
| FIRST TIME AT TRACK, NOW TRANNY PROBLEMS. | 5.0FUZ | 5.0 Mustangs | 19 | August 21st, 2007 07:40 PM |
| i might bite the bullet | 232stang | The Clubhouse | 19 | February 17th, 2007 04:24 AM |
