need some input
Old May 2nd, 2009, 01:22 AM   #1
2003 Mustang GT
dpbbnc89 is on a distinguished road
need some input
I currently own an 03 automatic GT with 99k miles.
I'm relatively new to modding cars but my goal is to have a reliable street car that i'd also be able to take to the track. I'd imagine i want to be pushing around 450hp, and i'd want to know my motor could handle it safely, so would it be worth investing a ton of money into building a motor for a 2v, getting heads ported, supercharger, cams, all that.. or would it be a better idea to sell my car and wait for a 03-04 cobra to come along?
How much horsepower can you make from a 2v?
Old May 2nd, 2009, 01:23 AM   #2
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Well it depends...do you want to have the fun of building your own 2V? Or would you rather just hold off for the Cobra? That's all up to you my friend
Old May 2nd, 2009, 01:26 AM   #3
03SuperchargedGT's Avatar
2008 Cadillac CTS4
03SuperchargedGT will become famous soon enough
well most people will say it will be easier to just buy the cobra and go from there casue it will make good power will a pulley swap and a tune. but on the flip side look at jive(another member) he has a sick GT pushing over 600 to the wheels. so its up to you. our GT have potential if you have patience and money. Plus its always a surprise to see a fast ass GT. people suspect a cobra to be fast, but when a GT pulls up and kicks your ass its a nice surprise
2003 Mustang GT
See Garage for mod list....360RWHP,360RWTQ....SOLD
2008 Cadillac CTS4
Old May 2nd, 2009, 01:41 AM   #4
Moderator
casper gt's Avatar
2010 mustang gt auto
casper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud of
450 hp is a very lofty goal for someone who is both new to modding & wanting a reliable d/d. my advice would be to do gears, a converter, tune, exhaust, & some minor bolt ons & I bet you'll be pretty happy (for alot less money & have a much more reliable car). but if you insist on that much power you'll want to do a motor if you want to both race it & have it be reliable.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2010 GT auto
Old May 2nd, 2009, 01:45 AM   #5
Gee
Super Stang
never quick enuff
Gee is on a distinguished road
You can reach the 430-470 power range with a blower and a set of cams as long as you have a enuff fuel and a good tune.
Don't overlook the trans and a torque converter as it will make a night & day differance when stepping up H.P. You don't wanna burn out a high mileage stock tranny with the added mods.
Old May 2nd, 2009, 01:51 AM   #6
Bush18's Avatar
Bush18 can only hope to improve
buy a corvette lol
Old May 2nd, 2009, 02:00 AM   #7
2003 Mustang GT
I was planning on a shift kit, and one of my buddies told me something about getting the pressure increased in the lines for faster, firmer shifts? Would there be anything else i'd need for a stock tranny to keep it from breaking with that amount of hp?
What's the recommended stall? is 2700 good?
Old May 2nd, 2009, 02:03 AM   #8
2003 Mustang GT
Originally Posted by Bush18 View Post
buy a corvette lol
would only be able to afford an LS1 already had one of those and it had too many problems
Old May 2nd, 2009, 02:06 AM   #9
Moderator
casper gt's Avatar
generally closer to 4000. if you were to get those kinda h/p #'s you'd still be good with a very minorly built 4r70w (the trans that's in your car) as they are very strong.
2010 GT auto
Old May 2nd, 2009, 02:51 AM   #10
ajm
Theres a difference between a shift kit and increasing line pressure with a tuner. One simply gives you faster/firmer shifts by increasing line pressure. One gives you faster/firmer shifts yet supports weak features of the valve body. Which one you go with is up to you though.
Old May 2nd, 2009, 05:23 AM   #11
4.6L Coupe' 5spd
2002 BLK GT will become famous soon enough
Send a message via AIM to 2002 BLK GT
This should help...
Yep! Stock from the top to the bottom, minus shifter. Stock clutch, flywheel, and all that as well. I never had any clutch slip, or anything... Launched the car at 6200RPM drag racing on DOT slicks, no problems ever.
100% stock longblock. It was running 13psi - and was running out of fuel (needed a larger pump than single focus pump).
The stock block I believe, is capable of 700 bro so if you want more than that go for the cobra but as you can see with the money spent on the cobra the gt will be faster..
Old May 2nd, 2009, 06:52 PM   #12
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
450 hp (crank) shouldn't be a problem. For guys with manual transmissions that's around 380-390 rwhp. This is considered fairly safe for a daily driver. Because of the higher parasitic loss through an automatic transmission you would only see around 360 rwhp.
What do you need? An intercooled supercharger at 10 psi, a 75mm TB/Plenum and an off-road mid-pipe should get you pretty close.
Edit: The stock block is capable of 1000 hp. The stock rods and pistons are not.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old May 3rd, 2009, 01:50 AM   #13
4.6L Coupe' 5spd
I thought the cobra block was only capable of that...?
Old May 3rd, 2009, 02:08 AM   #14
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
The GT's have cast iron blocks the same as 03-04 Cobras do only difference is the heads and internals... etc...
2004 GT Boosted by Vortech
Old May 3rd, 2009, 02:09 AM   #15
4.6L Coupe' 5spd
I see now..
Old May 3rd, 2009, 03:12 AM   #16
02 mineral grey GT
SORC 29 miles 13 mins 14 secs
Exodus is on a distinguished road
GT Mustang..........10k
Supercharger...........5k
the ear to ear smile accross a the face of whoever is in the passenger seat.............priceless
oh and did I mention the other 10k thats still in your bank because you didnt buy a snake
Old May 3rd, 2009, 03:20 AM   #17
2003 Mustang GT
whats the hp limit for the stock internals?
Old May 3rd, 2009, 03:31 AM   #18
Garhfer's Avatar
450 rwhp is borderlining the limit of the rods so you might as well swap everything out for forged internals if you want to stay at that power range or above... and seeing as you have 99k miles already on the clock who knows how much more stress the stock internals you have can take.
Old May 3rd, 2009, 08:45 AM   #19
12.73@111.36
I've seen several posts where motors came apart after a few weeks at 420 rwhp and I've read posts where they've lasted a couple of years at that power. The difference is in the other supporting mods such as cams, heads, etc. Some have even pushed the stock internals further but they had all of the supporting mod available.
I believe that all of them were manual transmissions. You have to remember for an automatic that it takes a lot more horsepower at the crank than for a manual transmission to make the same horsepower at the wheels and if you use rwhp as a measuring stick you will be pushing your motor a lot farther than they did. The same horsepower at the block results in 30-35 less horsepower at the wheels for an automatic. If you want to go much beyond 360-380 rwhp you should probably rebuild the motor with forged rods and pistons.
450 rwhp takes a lot more money than 450 hp. 600 rwhp is possible in a 2v. It just takes money.
P.S. Just because automatics put down less at the wheels doesn't necessarily make them slower. With a shift kit automatics are just as fast and they never miss a shift.
Old May 3rd, 2009, 04:42 PM   #20
00GT5spd's Avatar
258.7 RWHP 301.1 RWTQ
00GT5spd will become famous soon enough
Send a message via AIM to 00GT5spd
so you would be good sticking right around 400rwhp and not have to change much? wich would be what.. 455hp
2009 Kawasaki Ninja 250R (For Sale)
2002 Yamaha yzf R6
Threads Similar to: need some input
I need your input! 02MustangV6e9 Reviews 8 January 11th, 2010 11:47 PM
Need some input Megawatts88 Visual 3 March 13th, 2009 01:30 AM
I need your input! 02MustangV6e9 94-95 77 September 8th, 2008 03:40 PM
Looking for some input. chris1 The Clubhouse 36 June 9th, 2008 07:09 PM
i need some input Nick_Rapitis Classic Mustangs 63 October 29th, 2007 04:14 AM
