Ford GT fuel pump swap - guide
LinkBack (1) Thread Tools
Old May 5th, 2009, 06:40 AM   1 links from elsewhere to this Post. Click to view. #1
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
I looked and couldn't find any step by step instructions on how to swap over a ford gt pump into my mustang gt. I figured I might as well take pictures of the swap and make my own, this is for anyone interested in the swap.
Materials needed
A buddy, much easier with a second set of hands
Ford GT fuel pump
A few small hose clamps
About a foot of fuel line
A couple electrical spade connectors
a couple rags
Tools needed
Jack stands
Jack
Utility knife
Ratchet, 13mm, 8mm, 5mm sockets, and medium length extension
Wire Crimpers
A file
Alright start by getting the car on nice flat ground. You don't have to jack the car up too high, just get the wheels off the ground by a couple inches and y ou should have plenty of room. After the car is up, take the 13mm socket and extension and remove the bolts that hold the tank up. There should be three bolts, two on the passenger side and one on the driver side, in front of the tank. I found it easier to just slide the cover under
The tank wont come off completely, the hose used when filling up the car will prevent the tank from detaching completely. You may be able to swap pumps without dropping the tank completely, but it is a lot easier with the tank on the ground. To remove it, its easier if one person pulls the tank towards down and towards the drivers side while the other person pulls it out of the tank.
Once you get the tank down, clean off the top to prevent anything from falling into the tank. You will need to remove six bolts with a 8mm socket. This exposes the inside of the tank, so its probably best to be careful not to drop anything in there.
This part that is easier if the tank is on the ground. You need to pull the little assembly that the pump sits in. There are only two push tabs holding it in place, push them in and it will all come out easily. Watch out for the floater though, it comes with and might get hung up on something.
Now is probably a good time to throw a rag over the opening to prevent anything from falling in the tank. Go ahead and remove all of the 5mm screws, disconnect the fuel line, but be careful and remember how it sat. The top pulls off once you unscrew it all, and the pump should slide down, right out of the top. Take the filter and rubber pad off of the bottom for use on the Ford GT pump.
Here is a picture of the pumps side by side, they are almost the same, but the Ford GT pump isn't a direct fit. Major differences are the plugs for power, and the size of the outlet.
The outlet for the Ford GT pump is a little smaller, but the fix is simple. Simply cut off a length of the tube that came with the pump and slide it over the outlet. This gives you a fair seal when you press the little manifold back on the pump.
Now you need to file or sand down the plastic on the top around the power connectors. Trim it down until it fits properly where the old pump sat. It might take a couple tries, but once done it should look close to this.
Put the assembly back together, don't forget to attach the filter and rubber pad from the old pump. It should all go together fairly easy, I had problems getting the rounded piece to stay bolted on the top, so I left it off and discarded the screw.
Now clip off the old plug, strip the wires and crimp the spade connectors in place of the plug. Connect the black wire to the -, and yellow to the +, make sure the wires are snug. Attach fuel line, don't forget to throw clamps on it. Take note of how that rounded piece was oriented, don't put it in backwards. It is also probably not a bad idea to zip tie the wires to the fuel line. Now just pop it all back into place. Check over everything one more time to make sure it is all nice and tight. Just a little tug on the wires and fuel line, make sure they wont just fall out while driving.
Now just bolt down the top, make sure nothing gets caught in the way. Plug in the hose on the passenger side of the tank, if you disconnected it. Lift the tank into place, set the cover over the tank and reattach the brackets. It is a little easier if you do the drivers side first as it is hinged. With everything in place, its all done and good to go.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old May 5th, 2009, 10:47 AM   #2
ajm
Nice job. Its about time someone writes a decent one of these .
Old May 5th, 2009, 12:31 PM   #3
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
hope you are not boosted,no offense, but that install is riddled with problems.may get you by n/a with mild boltons if the hoses don't blow off
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old May 5th, 2009, 06:38 PM   #4
2003 gt
5.4 32v on the way
Well what did I do wrong? I winged it based on what little info I was able to find online.
Old May 5th, 2009, 08:07 PM   #5
April 2012 ROTM
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
I plan on runnin a GT pump with FI...I just dont like the BAP idea (even though it works really well for some people) whats the LPH rating on these puppies? lol
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer
Old May 5th, 2009, 08:08 PM   #6
ajm
Old May 5th, 2009, 08:09 PM   #7
April 2012 ROTM
Thats not much more than the focus pumps huh?
Old May 5th, 2009, 08:10 PM   #8
ajm
109 at the dealership -- cheaper than online actually
Old May 5th, 2009, 08:29 PM   #9
April 2012 ROTM
no I mean flow wise...thats about what I figured on the price lol
Old May 5th, 2009, 08:30 PM   #10
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
I thought the gt pump was 300 lph or so?
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old May 5th, 2009, 08:31 PM   #11
ajm
Shit youre right, I wasnt thinking focus is 255 gt is 310
Old May 5th, 2009, 11:08 PM   #12
GTermi's Avatar
GTermi will become famous soon enough
I got the Ford GT fuel pump for 102 dollars online brand new.
My Car- 2004 Mustang GT
Her Car- 2011 V6 Auto Premium
Saving up for either a 2009 Shelby GT500 or a 2011 5.0...Can't decide!
Old May 5th, 2009, 11:12 PM   #13
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
im bout to be selling my entire hat setup with gt pump once i get my cobra pump assembly in. It will come with sending unit, hat, basket, GT pump and everything ready to just drop in. I am going to the twin cobra pumps, hat, sending unit, etc.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old May 5th, 2009, 11:16 PM   #14
ajm
^ Damn, I just bought mine today .
Old May 5th, 2009, 11:18 PM   #15
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
i am about to pull my cobra hat off and install 2 gt pumps .
Old May 5th, 2009, 11:26 PM   #16
BakerFX4's Avatar
iTrader: 14 reviews
damn i just bought mine. LOLOL! ^^^^
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old May 6th, 2009, 12:37 AM   #17
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i was going to go with the fore hat, but i went way over budget splurging on a few things i "wanted". now i regret it because i have to buy a few things that i didnt plan on
Old May 6th, 2009, 12:41 AM   #18
Safud: MM's Resident Hadji
Safi's Avatar
00 v6 & 99 Cobra
Safi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud of
Send a message via AIM to Safi Send a message via MSN to Safi Send a message via Yahoo to Safi
Thanks for the guide bro. I have a GT pump sitting here needing to be installed, just havn't gotten around to it yet
Originally Posted by asiansensation78 View Post
Yeah Safi beat me on OG status lol
Old May 6th, 2009, 12:54 AM   #19
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
I would have left the pprv out because it's a hell of a restriction. You should also use fuel injection hose clamps those will allow for leaks at high pressure.
What kind of fuel line? If it just regular fuel line and not the special submersible type like gates sells for 20 a foot, the gas in the tank will eventually eat through it. The regular fuel line is not threated on the outside.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old May 6th, 2009, 03:10 AM   #20
limited's Avatar
wrong clamps
wrong hose
pprv should have been removed
hose should be connected direct to pump and that connector eliminated
couple of holes drilled in basket
connections should be soldered
people on other websites that did not do these have had problems,especially with the way the fuel connection is cobbled on. the way yours is plumbed there are going to be many internal leaks and you won't get the full advantage of the gt pump
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/122150-ford-gt-fuel-pump-swap-guide.html
Nitrous Help (fuel pressure) - SVTPerformance This thread Refback December 27th, 2011 03:57 PM
Threads Similar to: Ford GT fuel pump swap - guide
Got my FORD GT fuel pump today... NOW?? BakerFX4 99-04 42 March 15th, 2010 07:51 PM
Need to know-ford gt fuel pump DickH 99-04 11 June 8th, 2009 12:03 AM
Ford gt fuel pump? DickH 99-04 1 February 27th, 2009 10:16 PM
Ford GT fuel pump? supercharged03gt 99-04 23 February 10th, 2008 11:39 PM
