fpdm - Page 2
Old May 8th, 2009, 12:38 PM   #21
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
in my thread with the wiring upgrade, i t'd into the wire going into the hat. i thought about cutting and soldering a little thicker wire from the hat to pumps if new wires werent needed to get to pumps. probably do a 12ga wire to the pumps, and call it a day. i wont be pushing the gt pumps hardly at all really, but i just want to do it once, right, and able to be plenty stronger than i plan on for right now.
Old May 8th, 2009, 12:59 PM   #22
Trick Tuners's Avatar
KB'd GT
lots of people run 10g from the fpdms to the hat and then tie into the little wire. I don't think anybody every wires thru the hat.
Old May 8th, 2009, 01:03 PM   #23
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i just donw want to get it to dyno and turn around to go back home because i had something screwed up. the tuner i probably going to is about a 6hr drive one way for me. that is an expensive trip to screw up.
Old May 8th, 2009, 01:11 PM   #24
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
Tune it yourself. Don't be a pussy.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
96 GT-Junkyard Aviator, B cams...
www.KPERacing.com
Old May 8th, 2009, 01:12 PM   #25
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i dont have the software to do it. the proracers package from sct is too damn expensive. i have thought about doing it with the sniper set up, but i want a st up that is adjustable on the fly.
Old May 8th, 2009, 01:52 PM   #26
KB'd GT
List up your parts and i'll give you my opinion. Do you have a way to datalog? I'd make sure to put in the proper heat range plugs (new), properly gapped before you head down there.
Old May 8th, 2009, 04:54 PM   #27
Derek@DRI is on a distinguished road
I was talking about the MDMjr, the new one which is smaller and made for setups with twin Ford GT Pumps and BAPs. I would still use the modified FPDM personally, but the MDMjr is supposed to be the better solution.
Old May 8th, 2009, 08:50 PM   #28
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i wont have a way to data log when i start it, i will be selling my diablo. me and the cam manufacture talked about the plugs and i will be running what hw has been on his set ups. i have to call back and get the part # from him again. and the list of parts........................not wanting to give away my build yet.
Threads Similar to: fpdm
fpdm/fuel pump wiring upgrade SWEET2KSTANG 99-04 48 November 7th, 2010 09:19 AM
Dry kit, window switch, & extra FPDM installed pics acmillr 99-04 37 April 8th, 2008 12:55 PM
