i don't know i go by it tooo fast to read it!!
Track heat intake
I know a few peeps have used this intake what were your gains, is it worth the coin?
It was for me, but I'm FI. With the intake and a S to T-trim upgrade I picked up 93rwhp with the same size pulley and I was already at 572 at this particulate dyno. A lot harder to pick up 93 rwhp when your making almost 600 than it would if your only making mid 300's.
I went with the oval throttle body upper intake version and an Accufab oval tb.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
what gains do you think i would see being n/a, i am just trying to see if the power gain is worth the wallet drain
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
not worth it unless you are spinning that motor higher than 6100 constantly.
or at least when you're racing and have the bottom end, heads and valve train to support it.
April 2012 ROTM
+1...I would imagine you would be havin to spin it to the moon N/A to take advantage of the extra flow
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer |
mm's nitrous mod
2000 mustang gt
still not going to matter if its not revving high. the stocker is plenty sufficient to move the air needed to make set ups rev efficiently to the high 5k mark.
You nead all the others mods to safely spin it high enough.
ahh i see thanks fellas
Threads Similar to: Track heat intake
| New Trick Flow Track Heat Intake | cowboyup351 | 5.0 Mustangs | 9 | March 31st, 2009 12:06 PM |
| Trickflow Track Heat Intake 2V | Stang281GT | 99-04 | 1 | March 16th, 2008 04:59 PM |
| Track Heat intake manifold | k3vin | 96-98 | 9 | September 23rd, 2007 03:42 PM |
