slight miss or bad sensor?
Old May 6th, 2009, 06:50 PM   #1
John's_stang is on a distinguished road
ok so my car kinda idles rough while sittin at red lights and stuff... and today the rpms would jump about 500 and come back down.. did it for like 20 secs till i tapped the gas... then it stopped... any ideas?
Old May 6th, 2009, 07:03 PM   #2
ajm
Everyones gonna say clean the iac, but yea -- thats where id start clean the iac and maf and see if thatll help it any then go from there such as checking the plugs coils etc.
Old May 6th, 2009, 07:05 PM   #3
well i had the maf off no more than a month ago maybe... cleaned it then when i had it off.. and i had the iac off like maybe 6 months ago and cleaned it while it was off too... so i dont think its them... i had a blow by problems bout 6 months ago thats why i took off the iac thought it was that... but had oil on the plugs instead so replaced the plugs then.. but i believe these are the original coil packs in the car still
Old May 6th, 2009, 07:07 PM   #4
ajm
Hmm..thanks for wasting my time. If you could have ruled all that out yourself w/o asking then why not try that in the first place. Check the coils with a dvom then and inspect the boots.
Old May 6th, 2009, 07:15 PM   #5
heh sorry didnt mean to waste your time... yeah i was talkin to my brother and he said if it was the coils it would prolly do it all the time...
Old May 9th, 2009, 05:07 PM   #6
4.6L Coupe' 5spd
2002 BLK GT will become famous soon enough
Send a message via AIM to 2002 BLK GT
TPS then......
Old May 11th, 2009, 12:49 PM   #7
Trick Tuners's Avatar
KB'd GT
Is it setting a code? A miss will typically trigger a MIL in about 15 min of driving or less. Also the IACs go bad sometimes and cleaning them will only buy a bit of time before they act up again.
Threads Similar to: slight miss or bad sensor?
02 sensor cause a miss? mtw002 99-04 13 March 26th, 2009 07:00 PM
Bad miss, Undrivable gdcpony V6 Mustangs 16 December 18th, 2008 09:42 PM
running bad...small miss GT87Stang 5.0 Mustangs 4 September 13th, 2008 10:09 AM
Bad miss at WOT, Need Help!!!!! kilby91 5.0 Mustangs 13 January 19th, 2008 07:46 PM
Slight Miss When In High Gear / Low Rpm built54 Modular Mustangs 10 October 16th, 2006 12:22 AM
