Al. driveshaft
Old May 9th, 2009, 12:05 AM   #1
KevinJ99GT's Avatar
1999 Mustang GT
8.30 1/8th mile
KevinJ99GT will become famous soon enough
Al. driveshaft
I got quoted 150 bucks just to fix my damn u-joints. I figured for 70 bucks more i could get a aluminum driveshaft that i could probably install but i know you have to transfer the yoke over on automatics. Is this correct? and how hard is it?
- full bolt on's, hitech stage 2's, zex 100 shot
Old May 9th, 2009, 12:10 AM   #2
ajm
Yes you have to transfer the yoke over for an auto. Its simple and shouldnt take you but ten minutes max. On the other hand its the same exact process as changing a u-joint. Soooo logically if you cant change the u-joints youre having issues with now and have to pay someone, spending $70 more for an al. drive shaft isnt going to be "only $70" more because youre gonna have to pay someone to swap the yokes for you. Its a fairly simple process to do yourself and you can rent the tool(s) just about anywhere if you dont have them though.
Old May 9th, 2009, 12:13 AM   #3
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
yeah you gotta switch the yoke for auto's (also cut the weight off the yoke while your there) other than that it's just a straight forward swap, probubly 30 min. start to finish (+ time to jack the car up). also get the cheapest d/s as the cost diffrences are due to the diffrent splined yokes & you'll be tossing that anyway (the one that comes with the d/s that is). seemed worth it on my car but wouln't know till tomorrow (will be 1st time to the track with the car this year).
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old May 9th, 2009, 12:25 AM   #4
KevinJ99GT's Avatar
1999 Mustang GT
8.30 1/8th mile
if u-joints are simple i may try to do it. Anyone have a write up?
Old May 9th, 2009, 12:36 AM   #5
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
ajm loves making write ups. LOL.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old May 9th, 2009, 12:38 AM   #6
KevinJ99GT's Avatar
1999 Mustang GT
8.30 1/8th mile
good, he can help idiots like me.
Old May 9th, 2009, 12:38 AM   #7
ajm
lol not for something that simple
but all in all just get you a ujoint press, pair of pliers, and a 12 point 13mm socket or wrench (think its 13mm), and a marker
Mark the driveshaft in relation to the pinion flange so you can like it back up when you put it on. Remove the 4 bolts using the socket/ratchet or wrench mentioned, using the pliers remove the little retaining clips for the ujoints, press them out with the ujoint press tool. And put it back together with the new ones.
Theres a few other alternatives to a u-joint press if you cant find anywhere thatll rent you one.
Old May 9th, 2009, 12:41 AM   #8
BakerFX4's Avatar
iTrader: 14 reviews
hahaha.... It will prolly be like 3 lines.
AJM... you see my threads bout the 5.4 swap bro... If you have any thoughts, throw them out there. Im starting to really feel doing this.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old May 9th, 2009, 12:45 AM   #9
ajm
Sounds like a good plan. I didnt know stuff for them was that cheap. I about shit when I seen that link to parts for $1300 or something like that. Which way you wanna go is up to you, if it were me id just get what you linked, upgrade/down grade to parts you want on the drop down and get it done. As far as boring it thats up to you, probably wont be a major gain in performance as far as I know but itll leave you with a nice fresh cylinder.
Old May 9th, 2009, 12:47 AM   #10
2001 Mustang GT
01BlackGT will become famous soon enough
AJM rulez the WORLD!!!!!!!
Threads Similar to: Al. driveshaft
Driveshaft... 97Slobra 4V / SVT 2 November 16th, 2008 01:40 AM
driveshaft..which should i go with? energiesource 99-04 11 September 28th, 2008 08:25 PM
driveshaft? blackbullitt08 2005 - 2010 3 June 14th, 2008 12:51 AM
Driveshaft ? guesswatidrive V6 Mustangs 0 April 8th, 2007 10:10 PM
DriveShaft sctravis77 99-04 1 August 31st, 2006 02:36 PM
