LinkBack (5) | Thread Tools |
#1
Washed the car and took some pics and vids today :) Question on negative camber
Just took the front ISOs out on my H&R Super sports, gave me another 1/2" drop or so.
I liked the stance before, but it doesn't get much better than this now. Very streetable too! ![]() As for the tech piece of it: I took it to get aligned today, and the best they could do was get it to -1.5 degrees camber. Will I be ok with -1.5 degree camber for a DD? Should I really invest in some CC plates? I don't mind if I don't get quite the mileage I should out of the tires, unless it cuts the life down in half or something. Any recommendations? Here's the pics and vids though ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Here's some mild clips of exhaust in sig: (been procrastinating) Excuse the watermark, didn't feel like getting a legit program. Anyone have any advice on the negative camber situation? Is -1.5 too much for a DD? Let me know what you think!
![]() 99' Rio Red Mustang GT: --My Garage-- Check garage. Vortech V-1 intercooled running 9lbs of boost Life= eat, lift, eat, eat, eat, sleep, repeat
1999 Mustang gt
13.5@102MPH
sick ride looks good lowered like that why do you have 3 exhaust clips? ha
2003 True blue Mustang GT steeda triax , h&r springs , bbk intake , c&l plenum ,frpp tb ,SCT tuned , 4.10's or x-pipe,mac CB , max motorsports sfc, 125 shot ,315 drag radials nt05r's 13.4@104 n/a RIP:1999 Mustang GT Auto 13.5 @102 |
Lol, thanks a lot!
Didn't feel like editing them all into one. Plus movie maker was acting stupid. I really don't want to order CC plates :s
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
I have sportlines with no cc plates and when I aligned mine I was able to get it to -1.2 deg. it drives fine and tires seem to wear good enough for me. Of course since most people around here think they always have to be technically correct someone will say its not right though. I like the license plate frame.
04 gt dsg
you will be fine. mine are at -1.8 and ive made a trip back from south carolina like that and been driving on it this way for around 5 months or so now. All my tires are fine also. (Also i autox the same amount of time also). I was at -2.8 before my alignment.
I also daily drive mine also. |
#6 | |
![]() 2000 Laser Red GT: Hedman LT's, Hedman O/R X, SLP loudmouth catback, K&N CAI, Mach 1 Chin & Grill Delete...More to come |
#7 | ||
I wholeheartedly believe it though. At a 4-way stop, I start bringing the rpm up when its my turn to go, and everyone at teh intersection stops because they hear the car getting ready to pull away.
#8 | |
04 gt dsg
Yea i should have notched mine some before getting mine aligned i would have gotten a little less negative but oh well. I believe stock should be like -1 deg, so its not to far off. I mean since i was running -2.8 degrees for around two months and my tires hardly wore on the inside, its been great for me since then. The little bit more neg camber also does feel better in the turns also. Last edited by 06invertmini; May 11th, 2009 at 05:59 AM. |
2003 gt
5.4 32v on the way
Looks good, where is the rest of the blackout on the back?
Before asking a gearing related question click THIS link and enjoy all your saved time. Click here for your tuning needs My slow paced budget 5.4 dohc build |
The GTR sticker needs to go, thats hella lame. Other than that, nice.
Accufab 75mm tb & plenum MRT h-pipe Flowmaster catback FRPP king cobra clutch FRPP aluminum driveshaft FRPP 4.10 gear TA Perfromance girdle Steeda tri-ax shifter Moser 31 spline axles FRPP C Springs |
MM's Official Lucifer
^ I agree ricer boy.
j/k your car looks great, and I guess I'm that one guy who says get CC plates cuz I have them and you should be like me. If you're happy with ride quality, turning, and tire wear then it's a why? question. To be more of a perfectionist like I guess I am I'd get CC plates...
"Fast she goes...in the city of Overdose" ![]() |
#12 | ||||
GTR High Performance Mustangs Quite obviously NOT a skyline emblem: ![]()
: Yeah, the ride is great compared to stock springs. I might look into some CC plates only if my tires wear really bad. I could spend the money from CC plates on something like SFC
#13 | |
Nice looking ride.
I like to go to Subway because the women there have to make ME a sandwich. |
2000 GT CONVERTIBLE
youre right that stance is perfect now, it dosent seem too harsh with out the iso s?
![]() silvermustangsregistry#0711 |
1997 Mustang GT
Faster than an s4
In all honesty. 1.5 degrees is considered pretty aggrisive. race cars rarely dial in much more than 2 degrees.
The reason for it is not as obvious as it appears. Its not about how much your tires wear when you are driving straight. when you are driving straight, they are never theoretically losing any tread. Its when you are turning that you are technically sliding a portion of the wheel. And, when you are turning hard, the suspension flexes, pushing the body down further. With the single A arm design that our cars use, this means that the acual angle increases by a fairly large amount. So on a hard corner, instead of the tire being on 1.5 degrees ( an Ideal angle when in the actual corner) it may be closer to 5-10 degrees, which depending on the angle of your car, that is likely not flat on the ground at all. the bottom of your tire and the car will end uip looking like a "v". The car leaning y=twords to outside of the car will push it down, and with a weak sway bar and spring, the tire will push up to the car far enough that it will go past flat on the ground, into a non favorable angle with the ground. ALL OF THAT BEING SAID. This doesn't mean you need to go buy CC plates immeditely. It all depends on how you drive. If you don't take corners really fast, all the time, the tire will wear decently well, and you will have better control at low speeds. However, if you do push the limits on a regular basis, like those running Auto Crosses and such, without a proper set of springs and sway bars that are stiff enough to accomodate the forces at hand, you will most likely start to see an unever wear pattern on your tires. I can't quantify for you exactly which you are and exactly the amount of spring and sway bar you need without doing a lot of math, so to make it much simpler on all of us I wil say this... After a few thousand miles of driving, look at your tires, and decide whether you need less camber or not.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
2001 Mustang GT
Looks awesome!!!!!! GREAT STANCE!
#18 | ||||
Actually no, it feels great. I put duct tape around the 1/2 of the bottom coil because people say they will squeak without grease or something inbetween there. No squeaks. The ride is actually the same as it was with the ISOs in, it may even be better. or it might have been that alignment. Any car with 17x9 and 17x10.5: H&R SS springs with front ISOs removed is PERFECT stance, with almost no scraping on the streets.
![]() Thanks, a lot for the info. I'm going to adhere to those suggestions ![]()
#19 | |
04 gt dsg
Exactly, I use my car for autox all the time and have only been to the dragstrip once with it. So it is exactly what i want. |
#20 | |
04 gt dsg
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/122910-washed-car-took-some-pics-vids-today-question-negative-camber.html
| YouTube - 99 Mustang GT 4.6l MAC flowpath turndowns, o/r h, BBK shorties 2 | This thread | Refback | December 15th, 2010 02:00 PM | |
| YouTube - 99 Mustang GT 4.6l MAC flowpath turndowns, o/r h, BBK shorties 2 | This thread | Refback | April 7th, 2010 11:11 PM | |
| YouTube - mrsinister242424's Channel | This thread | Refback | August 12th, 2009 11:52 PM | |
| YouTube - 99 Mustang GT 4.6l MAC flowpath turndowns, o/r h, BBK shorties 3 | This thread | Refback | July 29th, 2009 02:49 PM | |
| YouTube - 99 Mustang GT 4.6l MAC flowpath turndowns, o/r h, BBK shorties | This thread | Refback | June 3rd, 2009 09:37 PM | |
Threads Similar to: Washed the car and took some pics and vids today :) Question on negative camber
| Went on a cruise today, got pics and vids | Seabee | Pictures | 35 | May 12th, 2009 02:41 PM |
| Washed and oil change today :) pics inside | AMmuslGT | Pictures | 35 | February 20th, 2009 09:01 PM |
| Washed car today. | MustanG_guy17 | The Clubhouse | 38 | April 21st, 2008 11:14 PM |
| Just Washed The Car... Pics | 98gt760 | 96-98 | 35 | November 19th, 2007 02:19 AM |
| Car got washed yesterday..!!..pics. | MustanG_guy17 | The Clubhouse | 8 | September 8th, 2007 05:01 PM |
