spark plug blew, need help
LinkBack (1) Thread Tools
Old May 15th, 2009, 12:46 PM   1 links from elsewhere to this Post. Click to view. #1
RALVAREZ26's Avatar
2000 MUSTANG GT
RALVAREZ26 will become famous soon enough
last night i blew out the spark plug and coil (only one) i dont have the money to get the head rethread and was told their is a temporary fix for it. any help?
http://smokinperformance.com
Slowmatic 2000 GT
Old May 15th, 2009, 12:50 PM   #2
2009 ROTY
AzSonicSnake's Avatar
2003 SVT Cobra
11.07@127
AzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud of
Send a message via AIM to AzSonicSnake Send a message via MSN to AzSonicSnake
i think you can go the helicoil route......
MM Cobra Club #25 My Autolog Profile
Old May 15th, 2009, 12:51 PM   #3
ajm
^ . If you dont have the money for a timesert kit you can just helicoil it for now.
Old May 15th, 2009, 01:11 PM   #4
R3dFyre02's Avatar
R3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura about
when this happened to me I went to the local autozone and asked what they had. Helicoil makes a kit called saveathread.... It comes with a tap, three different lengths of inserts and a installation tool. no drilling needed, and it is super simple to use. I coated the tap with grease and only turned it 1/2 a turn at a time so most of the shavings would stick to the grease. the tap is two stage, the first is the actual size of your plug and that helps guide and pull the larger second stage down into the head squarely. it took me maybe 2 hours to tap it all out and installt eh insert, but then again I was going super slow. once the threads were all cut I used a shopvac with some fuel line taped into the end of the nossle to go into the combustions chamber to help suck anything out that might have fallen in. coated the outside of the insert with a little ultra copper gasket material and screwed it in. let everything sit over night and installed the plug and away I went. been running strong for about 6 months now. granted I am always worried that when I do my next plug change the instert stays in the head... and if you go this route, might not want to cut the threads all the way through the head. I did, and I was worried that I might have the insert screw itself into the chanber.
I believe the kit only cost 25 bucks or something.
Good luck.
02GT - Blown motor
86LX 3.8TBI auto replacement daily driver
How to retrofit HID's
Old May 15th, 2009, 01:29 PM   #5
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
R3D, not really sure what the two stage thing your talking about is? When I fixed a stripped thread, i just used the tap it came with and then put the insert it. And you DO WANT the insert to stay in there. You should ever need to replace it.
Old May 15th, 2009, 01:32 PM   #6
RALVAREZ26's Avatar
2000 MUSTANG GT
helicoil that's exactly what i heard just couldnt remember but thanks everyone!
Slowmatic 2000 GT
Old May 15th, 2009, 01:33 PM   #7
RALVAREZ26's Avatar
2000 MUSTANG GT
reps for everyone!
Slowmatic 2000 GT
Old May 15th, 2009, 01:43 PM   #8
R3dFyre02's Avatar
its a single tap, but it has the plug sized thread at the tip, then it expands to the size for the insert. so it actually is cutting two different sizes of threads.
and I know the insert needs to stay in there. where did you get the idea that I thought it should come out? Only thing i said is that I am worried that when i do a plug change the insert will come out with the plug...
02GT - Blown motor
Old May 15th, 2009, 02:42 PM   #9
00redgt's Avatar
2000 mustang gt
00redgt is a jewel in the rough00redgt is a jewel in the rough00redgt is a jewel in the rough
iTrader: 5 reviews
Send a message via Yahoo to 00redgt
the save a thread is what i used,u will need the middle insert,thats what i have in mine now
Old May 15th, 2009, 02:45 PM   #10
00redgt's Avatar
2000 mustang gt
iTrader: 5 reviews
just make sure u get all the shavings out,i had to use a vacume with a straw on the end of it to make sure i got it all out
Old May 15th, 2009, 03:16 PM   #11
Blown 03 GT
All taps are tapered so you can start them but the are still one size. I wanst sure what you refering to when removing the plug but the coil should stay in, the upper tip is designed to bite into the material so it wont release. The kit I bought cam with about 15 coils and it should ruin anythin if it does come out.
Old May 15th, 2009, 03:21 PM   #12
R3dFyre02's Avatar
ummm... No stang guy. this tap is two different sizes. let me get you a pic. really Im not an idiot.
Hey, look at that, it cuts two different sizes of threads. Ill be damned.
02GT - Blown motor
Old May 15th, 2009, 03:38 PM   #13
06invertmini's Avatar
04 gt dsg
06invertmini is on a distinguished road
Got a ? about repairing threads. How do you keep shavings from going into the chambers? ive always wondered how it works.
Old May 15th, 2009, 03:42 PM   #14
R3dFyre02's Avatar
well, i coated the tap (pictured above) with grease, filing in the flutes. that way most of the shavings stuck there. I also only would turn it about .25 or at most .5 around before backing it out and cleaning and re-greasing it. that way most stuck in the grease. the rest I simply vacumed out iwth a shopvac that I had attached a length of fuel line to the nossle of. fule line fit into the plug hole and was able to be moved around in the chamber getting anything that fell in there.
02GT - Blown motor
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/123524-spark-plug-blew-need-help.html
need help asap - Page 2 - Steel City Stangs This thread Refback November 26th, 2011 02:16 AM
Threads Similar to: spark plug blew, need help
Champion Spark Plug 7989 Double Platinum Plug UNVMYGT 2005 - 2010 6 November 24th, 2011 01:50 AM
blew out a spark plug ColdSteel 99-04 9 November 13th, 2008 06:10 PM
spark plug blew out jrock 99-04 21 November 12th, 2008 08:05 AM
Spark Plug Help!!! flamed 98 gt 5.0 Mustangs 8 August 16th, 2008 11:57 PM
Pulse Plug vs. Spark Plug BlckBullitt01 99-04 4 May 18th, 2008 02:51 AM
