I have a offset and backspacing question.
Old May 15th, 2009, 03:29 PM   #1
mustangmanic's Avatar
13.334 @ 106.27 w/2.01 60'
mustangmanic will become famous soon enough
Send a message via AIM to mustangmanic
Ok first... what is ideal for our cars backspacing and offset for the front and back?
Second.... What is the maximum you can put on each?
I Kinda of want the rears to stick out a tad farther than the fronts, i've realized that you have to have a much bigger backspacing in the rear to accomplish this because of the front break clearance.
So what would be a good combination to accomplish the look i'm going for?
Old May 15th, 2009, 03:40 PM   #2
With the certain wheels i want to get. The Offset in the front is 30mm, and the rear is 45mm. Is that too dramatic of an offset for the rear?
Old May 15th, 2009, 03:44 PM   #3
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
There is no "ideal" back-space / off-set to get the look you describe with all wheel widths
I have a couple questions for you:
1. Do you want to run some super fatty meats?
2. What wheels do you currently run?
3. GOOD GOD MAN.... ARE THOSE THINGS REAL?
Head over to American Muscle and pepe the '99~'04 wheels and look at customer rides for particular wheels. This will give you a good idea of how they will look on YOUR ride. If you pick up a set of rear wheels with a 6.3" back-space or less (going to be 10"s or 10.5"s, you can do what I did and run a set of 1/2" spacers. This provided you run some longer/stronger lug-bolts to support them properly.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old May 15th, 2009, 03:58 PM   #4
Abyssinian of AX
'02 Saleen
19.34@42.259
Keep in mind that the off-set is based on the center-line of the wheel in question
So if you have an 8" wheel with a +30mm off-set, the face of the wheel will be FARTHER under your fender than a 9" wheel with that same +30mm off-set.
Head over to ***HERE*** for a nice graph on this subject. Scroll down to back-space section.
Jazzer hopin' that helps to clarify
Old May 15th, 2009, 03:59 PM   #5
1. Yes sir, Only the meat with the most Grissel will be worthy for my ride.
2. I currently run American Racing Rebels. 18x9 fronts with a 25mm offset and 6" backspacing, and 18x10 rears with a 30mm offset and a 6.75" backspacing.
3. Yes they a real
With my current setup, The fronts stick out farther than the rears, it looks quite homo, but then again, many people like it... Kinda gives it a "Bulldog" stance...
They're Aluminum wheels with a chrome plating on them, and over the period of the 2 years i've had the car, they've pitted like a MO FO!
These are my favorite rims for a new edge, and its great cuz no one has em, but they're just pretty damn expensive lol... So idk if i wanna do em again.
Old May 15th, 2009, 04:00 PM   #6
o yeah... and reps for Jazzer, for being a helpful friend and having the most badass saleen here lol.
Old May 15th, 2009, 04:30 PM   #7
Abyssinian of AX
'02 Saleen
19.34@42.259
Thanks
The "bulldog" look as you describe is pretty common. I actually have this worse than most due to the SLA I run up front. Do the following for an experiment:
Jack the rear of your ride up from the axle just enough to get the tire bearly off of the ground. Loosen the lugs 1/2" so the wheel will slide outward to the nuts. Step back and look down the side of your ride. I think you will be AMAZED how much better your ride will look with those rear wheels moved outward that 1/2".
If you like this idea, you will need to replace your lug-bolts as I did to safely run a 1/2" spacer. This requires pulling your axles and getting them pressed in, but worth it as I think you will see.
Jazzer.... pushin' silicone for the rear end
Old May 15th, 2009, 05:21 PM   #8
Yeah, i'm gonna try jacking it up and movin them out, thats a good idea.
If i pull the axles, i might as well just do the whole rear end lol, its time for a 31 spline anyways lol.
Do you have any rubbing/clearance issues with fat meats out back with the 1/2 spacers.
Old May 15th, 2009, 05:28 PM   #9
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
A little spacer can make a BIG difference in stance. My rear wheels are 10.5 and I have 315 nittos on them. But I didn't like how they sat in a little in the fender, so I put a 1/4" spacer on them and it sits flush with the edge of the fender. I love it
Make sure you post pics of how it sits when you're done
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Old May 15th, 2009, 05:41 PM   #10
O my! That looks buck nasty!
Old May 15th, 2009, 06:07 PM   #11
Abyssinian of AX
'02 Saleen
19.34@42.259
I did the same thing as Sinister, but run a 1/2" spacer and had my 10.5"s widened to 11"s
I had my fenders rolled, but zero rubbing.
Jazzer
Old May 15th, 2009, 06:27 PM   #12
99' Mustang GT
3214@OVER 9000!!!
What size tire you running? I bet it would looks so sexy with 335's.
I wish my nittos were wider
Check garage.
Old May 15th, 2009, 06:30 PM   #13
99' Mustang GT
3214@OVER 9000!!!
Hey jazzer post more pics of your car, I wanna see your stance
Check garage.
Old May 15th, 2009, 07:14 PM   #14
Abyssinian of AX
'02 Saleen
19.34@42.259
Ha ha..... I actually had a thread started for over a week before I even knew it for exactly this thing....
Head over to ***HERE*** for some pics.
I will be riviving this issue soon in the videos section as I now have a nice new dig camera for 1080i video along with mount for front windshield. I did some testing yesterday afternoon and works fantastic.
Anyway, don't want to high-jack thread any longer, so stay tuned.....
Jazzer Ford Coppola
Old May 15th, 2009, 08:42 PM   #15
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
what studs to go with to safely run a spacer? i ran a 3/8 on the rears of mine for a little bit and had to replace all the studs because i ended up stripping them out.
Old May 16th, 2009, 01:15 AM   #16
99' Mustang GT
3214@OVER 9000!!!
Photobucket is broke jazzer
Actually I'm running stock studs right now. I just bought some extended nuts though. I don't want to replace the studs. I'll get to it. A little more unsafe, but its a compromise.
Check garage.
Old May 16th, 2009, 10:08 AM   #17
Abyssinian of AX
'02 Saleen
19.34@42.259
I have installed Moroso 46180 with link, courtesy of the following Tmac post. I needed to cut the starter portion of them off so they wouldn't bottom out on the studs. I HIGHLY recommend one remove the axles and have them pressed in as I did not and was a PITA!!!
Originally Posted by mrsinister2424 View Post
"... Actually I'm running stock studs right now. I just bought some extended nuts though. I don't want to replace the studs. I'll get to it. A little more unsafe, but its a compromise.
WHOOOO THERE PARDNER!!!
If you are running studs/nuts you feel are unsafe in ANY way whatever.... what the hell are you doing???? Any "compromise" on your safety is not a good idea. Address this issue NOW before you lose a wheel merging onto the freeway on-ramp.
Yes, Photobucket is down and causing me some probs right now with my earlier mentioned link, as well as a cruise I set up in Marin County. Hopefully it will be resolved soon or I will need to upload to another photo site.
Interested...? PM me and will fire you off some details. It is in Marin County and starts just past the GG Bridge in Mill Valley on June 14th with 28 miles of pure twisty
..........................................Dammit, I promised Lefty I would not do ^ again....
The Jaz
Old May 16th, 2009, 12:25 PM   #18
Yeah mrsinsiter... You need to get that fixed IMMEDIATELY! That is very unsafe man.
Threads Similar to: I have a offset and backspacing question.
Our Rim offset and backspacing. mustangmanic 99-04 5 April 3rd, 2009 02:28 PM
Wheel offset Question D0c sUn 2005 - 2010 1 July 3rd, 2008 07:27 AM
How do you calculate proper backspacing and offset? Oddball 2005 - 2010 2 February 18th, 2008 02:05 PM
Offset question... mustang_marine 99-04 8 July 27th, 2007 12:56 PM
Rim Offset Question/Request onetwin69 All Other Vehicles 1 March 29th, 2007 09:03 AM
