Rod knocking, motor shopping.
Might have to start looking for a motor if my knock gets any worse. Whats the best way to go about getting a motor? Cheapest and quickest way. Not looking for carb motor.
2000 GT JLT Shortram, Mac long tubes, Mac o/r H pipe, UPR k member kit, UPR Billet cc plates, Spec stage 2, steeda clutch quad. 1/8th mile-9.035, 1.980 60ft just flows. New time- 8.92, 2.28 60ft. Mods. |
The Doctor
'01 Cobra Vert.
03/04 Termi motor swap. You can find a full drivetrain w/ ECU for around 75-8k. Engine, Tranny, ECU, etc. (Sometimes you may find them cheaper and other times you may find a package deal for like 1k more.)
But before you jump too conclusions looking for a new engine you may want to consider rebuilding yours w/ some forged internals, etc. if money is going to be tight.
1999 Mustang GT
im in a similar situation. rod bearing on the way out... i decided to go with a 5.4 4V motor swap. i have a gigantic thread on here with a ton of good info on both the 2V and 4V 5.4s. check it out. the 2V is extremely simple to do(as easy as putting in another 4.6).
BBK CAI, March UDPs, Eibach Sportline Springs, MM C/C plates, Koni Yellows, Centerforce DF clutch, FRPP Billet Flywheel, B&M Pro-Ripper Shifter, BBK ceramic LTs, BBK catted X-Pipe, SLP LM1, EBC rotors, 4.10 FRPP gears 5.4 4V coming soon |
what would be a price estimate for the motor. I can do all the labor.
The Doctor
'01 Cobra Vert.
It depends on what motor you want man.
rebuild with forged internals would def be the cheapest. andprobably the quickest. maybe do a stroker while your at it. but a 03/04 termie would be aweful nice!
#7 | |
1998 Mustang GT
1:34.43@13.86
![]() "The only way to learn about a car truly is to break something and fix it yourself..." |
mmr 900 short block!!!!! pure sex!
If It Dont Flow It Wont Go!!!![]() forged pistons,teksid block and a romeo cast cranks for sale.. pm if interested.. selling them for next too nothing |
1999 Mustang GT
you can get a 5.4 for less than a grand. complete and running.
02 mineral grey GT
SORC 29 miles 13 mins 14 secs
MMR rotated and balanced shortblock, then swap everything over, in and out for less than 4k and bullet proof.
I cant decide if I want to rebuild or just get a running motor. I'd like to do a 5.4 swap would be nice but I want something strong I can throw a good size shot and not be worried about it snapping. Looking at a budget of say 2,500?
12.73@111.36
The only recommendation above that is both easy and cheap is to get one from Craigs list. The MMR short block rebuild, 4v swap or 5.4 swap are not necessarily what I would call easy (meaning a direct drop in or slight modification). If you don't want to use Craigs list go to a nearby salvage yard and pick up a 2v. The salvage yards I've dealt with all give you a short warranty period. If you feel ambitious then go to the salvage yard and get a 3v then get the 3v conversion. You won't have to buy a complete new exhaust and you can use your stock wiring harness and ECU.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
Now looking, Im kind of interested in the 5.4 swap. What all do I use of the 4.6 block?
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
A 5.4 swap is going to be a waste of time. The kids on here talk 5.4 all day long, but the only one who has actually done the swap and produced numbers for scrutiny put down 280RWHP after building the shortblock, ported heads, ported hardballr intake, comp cams, and spending about $3000 for a set of headers that would work with the swap. For all the people suggesting the 5.4, ask them what their cars have made (power wise) with the 5.4 and you are going to hear a list of fantasies and excuses about 10 pages long. As far as the 5.4 swap thread goes, it is chocked full of needless chit chat and theories. If you want a strong 4.6, I will be glad to give you some advise that will get you right around 340-350 HP and TQ from a stock stroke and bore 4.6- and that's proven.
MM Official Sammich Maker
1999 mustang gt
n/a
heres where i buy all my stuff it's in ontario
pretty cheap all in canadian $ have a look Sean Hyland Motorsport - Ford Crate Engines, Shortblocks, Longblocks |
Threads Similar to: Rod knocking, motor shopping.
| motor knocking | 87gtmustang | 5.0 Mustangs | 26 | April 22nd, 2009 02:07 PM |
| Bad things...Motor Knocking | SteviGX | 99-04 | 3 | October 9th, 2008 01:31 AM |
| Knocking. Not the Rod Bearings???Pls Help! | tweeaks | V6 Mustangs | 18 | May 18th, 2007 02:38 PM |
| 1997 Cobra Motor knocking........ | 1stcobra | 96-98 | 17 | March 15th, 2007 09:15 PM |
| Motor knocking :( | ricer_slayer | 5.0 Mustangs | 5 | February 26th, 2007 02:12 AM |
