putting in mmr long block
Old May 21st, 2009, 09:21 PM   #1
dcrow's Avatar
2001 mustang bullitt
dcrow is on a distinguished road
Hey guys I finally saved up enough money to buy a mmr long block and I figured if I am going to buy a block I am going all the way with it and of course I did not hold back.
Here is what i bought:
mmr long block,stage 2 heads,blower cams,mmr clutch kit,and I have a paxton novi 2000 that is existing.
So my question is this should I go ahead and buy the mmr pro 750 tranny and install 31 spline axles or should I wait till it breaks.
Also what type of horsepower do you think I will be putting down to the wheels?
2001 bullitt
mmr 900 LB,stg 2 blwr cams,spec clutch,alum flywheel,novi 2000,intercooled,gt pump,80lb injectors,3:73gears,bbk ceramic shorties,bbk xpipe,bbk 65mm tb,flowmaster catback,steedatriax.eibachsprings,m&m lower control arms,ford alum ds.
Old May 21st, 2009, 10:32 PM   #2
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
that will be a BAMF setup man... you'll need a tranny and rearend eventually but i would go easy on it and save a little longer. it would be cheaper to send in your transmission before it breaks.. and the rearend.. that can be done fairly cheap.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old May 21st, 2009, 11:00 PM   #3
BLK01SS's Avatar
1/8 7.95@82.43
BLK01SS has a spectacular aura aboutBLK01SS has a spectacular aura about
Im not sure how much those trannys run but promotionpowertain.com has buitl t-45 and t-3650's for just over $1000...with core.
But yeah like BOB said that setup will be badass!
Topless Mustang Club Founder
2000 Mustang Gt 5.4 SOLD
2001 Camaro SS
Originally Posted by rk_2000_Z/28 View Post
Black C6Z06=pure, hot, nasty, unprotected sex
Old May 22nd, 2009, 12:33 AM   #4
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
y wait till it breaks and possibly fuck other stuff up? I would just do it lol
4V swap in the works
Old May 22nd, 2009, 04:27 AM   #5
GTRACER88's Avatar
GTRACER88 has a spectacular aura aboutGTRACER88 has a spectacular aura aboutGTRACER88 has a spectacular aura about
How much boost are you running?
Super Slow 2011 Grabber blue V6...
Old May 23rd, 2009, 10:47 PM   #6
dcrow's Avatar
between 15 to 20 pounds,it is a mmr 800 long block,I was told I will be putting down 600-650 to the wheels not sure how true that is.
2001 bullitt
Old May 23rd, 2009, 11:46 PM   #7
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
I think those are modified TKOs. I've heard too many problems with those trans. I'm getting a PMP myself in about a month.
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old May 24th, 2009, 12:01 AM   #8
Boostang's Avatar
1997 Mustang GT
11.01@128.32
Boostang will become famous soon enough
Send a message via AIM to Boostang
problems out of the tkos??
i love my tko 500.. and i give it hell... once u get the stop bolt shift its almost unbreakable... but thats my own opinion?
If It Dont Flow It Wont Go!!!
forged pistons,teksid block and a romeo cast cranks for sale.. pm if interested..
selling them for next too nothing
Old May 24th, 2009, 03:13 AM   #9
jivepepper's Avatar
jivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the rough
I put down 665 with 20 psi and dyno about 30 hp less where I tune compared to other dynos I have been on it a very very old dynojet.
The Novi is a good bit bigger than my T-trim so 650 should be in the cards at 19+. I also suggest an overdrive crank pulley so you don't have to run such a small SC also an 8 rib pulley setup wouldn't hurt. Maybe port your bullitt intake while you're at it. I run my TFS unported and it performs well.
What's your fuel setup etc? Of course you'll need the support mods for the hp.
Also I like to see what a car traps in the 1/4 to see if the dyno numbers are accurate. I know of a 2.6h KB GT that dynoed 650+ at Modularpowerhouse and then was running less than 120 traps. Something wasn't adding up.
I have had a mmr shortblock for over 3 years and have been very happy with it.
Edit: I just seen were you went with a MOD 800 long block. 680rwhp is the limit of where it's rated. With your set up @ 20 psi you'll be close to it's limit already. Might want to considered going to the 900 or more. 765rwhp is the limit of the MMR MOD900 even though I've seen people go past that.
2000 GT 665/540rwhp/rwtq On pump gas
Best 1/4 638hp street tune 11.01, best trap 134MPH, 80*+day, 10.5" DD Cobra R's & 315/35/17 DR'S
DYNO VID --->
http://www.youtube.com/watch?v=K9uOS732mdA
Old May 25th, 2009, 12:33 AM   #10
dcrow's Avatar
I spoke with a couple of guys at mmr,when they say 800 or 900 block etc...,I was told those numbers are rated to the wheel so basically they said I could run 800 hp to the wheel with the motor.
2001 bullitt
Old May 25th, 2009, 12:43 AM   #11
jivepepper's Avatar
Well I guess they changed their policy since I bought mine. Plus a want a little buffer room.
DYNO VID --->
Old May 26th, 2009, 11:18 PM   #12
dcrow's Avatar
question: when you were putting down 516 to the wheel and you ran a 11.10
were you launching hard,did you have drag radials,have you changed out your axles or transmission,I think you said you had a tko 500.
The reason why I'm asking is that is a good time for a street car.
I was also told i have to be careful because my tranny and axles are stock and I am running a 285 35 18 drag radial on the track.
What is your opinion.Thanks!!!
2001 bullitt
Old May 26th, 2009, 11:33 PM   #13
UnixHH's Avatar
2003 Saleen S281
UnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of light
Send a message via Yahoo to UnixHH
my buddy has an mmr800 and hes putting 530 or 540 to the wheels through the stock tr3650 and he launches hard at beats it up lol
480RWHP 450RWTQ 15psi @ 15* on 91 octane
Old May 26th, 2009, 11:39 PM   #14
dcrow's Avatar
he's never had any problems?
what type of clutch is he running?
2001 bullitt
Old May 26th, 2009, 11:45 PM   #15
UnixHH's Avatar
2003 Saleen S281
no problems just a few tune issues
umm ill have to ask him about the clutch. i run a ram power grip and its a beast its supposed to be good to around 650 horse
Old May 27th, 2009, 04:18 AM   #16
jivepepper's Avatar
I was launching pretty hard. I just lose so much time and boost during my old man granny shifts. I was averaging high enough traps to be well in the tens I just needed the driver mod I think.
The 11.1 was on my 17" dd 10.5" cobra r's with 315/35/17 MT DR's I have a built 31 spline rear using a explorer diff and USA alloy axles.
I run a stock TR3650 with a 10.5" XTD stage 3 clutch ($185 lol) and a stock 8bolt flywheel from a 2000 gt. I had one laying around with only about 200 miles on it so I used it without turning it. I paid 300 for the transmission about 5-6 years ago. It was right after I bought the short block and I as running out of money.
I'm sure it's just a matter of time before it goes.
I ran a set of 15x8 summits stars with a 26x10.5x15' Dot MT street slicks a few time but I didn't do any better in my 60's, but they were more consistent.
DYNO VID --->
Old May 27th, 2009, 09:31 AM   #17
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
ok 1 question.... you have got the motor now you will not make the power if you do not have the fuel? so what do you have for fuel? and please done say 42s and a focus pump lmao.....and at 20 pounds you should be pretty damn close to around 660ish may be more just depends on if you guy can tune or etc... and you will need an 8 rib set up for that amount of boost or you will make no power with you belt slipping so much...
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Old May 27th, 2009, 09:46 AM   #18
MrSonic's Avatar
MrSonic is on a distinguished road
cant wait to see this
Old May 27th, 2009, 11:10 PM   #19
dcrow's Avatar
murrillo does all my tuning they also installed a 310 pump in my car when i installed the blower and i will be running 60lb injectors,mike in my opinion is the best tuner around and a hell of a nice guy.
they are the only ones i will let touch my car and mmr of course speaks very highly of mike and said he has never had a motor go bad from a tuning issue
from murrillo.
murillo will be installing the motor and retuning,I don't have the room to drop a motor and not to mention my home association will
have a shit fit.when i installed the blower and injectors i had a hell of a time getting the car to murillo's shop and of course all the good shops are never close to your house so i figured i would save myself the agony and pain and let him do it.
2001 bullitt
Old May 27th, 2009, 11:31 PM   #20
dcrow's Avatar
from murrillo.
I still have to upgrade my tranny and axles but i am running out of money right now.
2001 bullitt
Threads Similar to: putting in mmr long block
Thoughts on MMR Short block? SUHLeen 2005 - 2010 82 February 6th, 2009 01:49 AM
Short Block and Long Block street591 Modular Mustangs 2 August 30th, 2008 06:40 PM
long block or short block? jRoush 5.0 Mustangs 26 January 26th, 2008 06:35 AM
short block differs from a long block how? mustangfox9091 5.0 Mustangs 35 September 26th, 2007 11:57 PM
MMR Short Block vs DSS Short Block superbeef1000 99-04 6 September 20th, 2006 05:49 AM
