man...
Old May 24th, 2009, 05:06 PM   #1
bullitt ak's Avatar
2001 mustang bullitt
bullitt ak will become famous soon enough
man...
so i cleaned my engine bay via the sticky on it and i start it and its running rough so i shut it off....what to do now?
Old May 24th, 2009, 05:09 PM   #2
00GT5spd's Avatar
258.7 RWHP 301.1 RWTQ
00GT5spd will become famous soon enough
Send a message via AIM to 00GT5spd
i had the same proble a year ago.. if you used water check you COP's ones prob cracked. moisture got in there and now its missing. you have to look very closly
2002 Yamaha YZF R6
Old May 24th, 2009, 05:13 PM   #3
bullitt ak's Avatar
where would it be cracked just on the outside?
Old May 24th, 2009, 05:16 PM   #4
bullitt ak's Avatar
and why would the water make it crack?
Old May 24th, 2009, 05:20 PM   #5
00GT5spd's Avatar
water dident make it crack it just cracked from wear.. mine had a light crack on the top, and one had it down the side. then when water got in them they started to fail witch caused the roughness and boging
2002 Yamaha YZF R6
Old May 24th, 2009, 05:22 PM   #6
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
how did you dry it? just got something electrical most likely a cop wet
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old May 24th, 2009, 05:22 PM   #7
bullitt ak's Avatar
ok so im not seein any cracks i looked close with a flashlight...sounds like its an issue with a coil anyways tho but if i cant see any cracks..then what?
Old May 24th, 2009, 05:24 PM   #8
bullitt ak's Avatar
just dried it with rags...im sure theres still moisture somewhere..im gonna go look for any more wet spots but i guess ill just have to wait a while and see if it changes when everything is completely dry? this is my DD is it o.k. to drive the car like this if i have to?
Old May 24th, 2009, 05:25 PM   #9
2000 gt
it's possible it filled the bore for the plug up with water. how much water did you use? i never run very much around that stuff just for this reason, set the hose to mist and let it sort of "run" water off while mopping it up with a towel or microfiber.
HARDCORE CREW
Old May 24th, 2009, 05:27 PM   #10
bullitt ak's Avatar
yeah i mean i didnt use much water in general and esp. around cops and shit..
Old May 24th, 2009, 05:31 PM   #11
bullitt ak's Avatar
fuk my ass..so is it ok to drive the car like this if i have to?
Old May 24th, 2009, 05:36 PM   #12
00GT5spd's Avatar
i did for about 10 miles before i decided i dident wanna risk it.. if ur getting a misfire i wouldent. but like i said i did the same thing u did and that was my problem. make sure there seated right now water on the connector or a crack in the boot that maybe water got into
2002 Yamaha YZF R6
Old May 24th, 2009, 05:40 PM   #13
00GT5spd's Avatar
if none of that works.. go get the cops tested make sure there all fireing.. then again.. if it ran fine before u washed it.. its prob not the plugs
2002 Yamaha YZF R6
Old May 24th, 2009, 05:40 PM   #14
bullitt ak's Avatar
ok...and i can smell my exhaust more it seems like if that means anything
Old May 24th, 2009, 05:42 PM   #15
00GT5spd's Avatar
Misfire. not burning everything so its def a COP or spark plug. if its none of that something could have been shorted out. but i highly doubt that.
2002 Yamaha YZF R6
Old May 24th, 2009, 05:43 PM   #16
00GT5spd's Avatar
make sure u dident pull a wire loose or anything while you were cleaning around that area
2002 Yamaha YZF R6
Old May 24th, 2009, 05:47 PM   #17
bullitt ak's Avatar
so what do i need to check and see if they are all firing or not?
Old May 24th, 2009, 05:50 PM   #18
bullitt ak's Avatar
called autozone they say they cant check if i have no cel
Old May 24th, 2009, 05:52 PM   #19
00GT5spd's Avatar
start it up make sure its still running rough.. then pop the hood and one at a time un plug the cop's if it gets worse thats a good one d oit untill u get to one that when u unplug it the idle dosent change and it dosent get worse. then thats ur problem.. but dont stop make sure there all still good.. doing this you MAY.. throw a code. but it dident in mine
2002 Yamaha YZF R6
Old May 24th, 2009, 05:53 PM   #20
bullitt ak's Avatar
ok ill do that
Threads Similar to: man...
Man Oh Man Do I Have Good News! Mickey The Clubhouse 38 December 10th, 2007 02:33 PM
changing the whole gearbox from 5 man into 6 man Evilspark 2005 - 2010 1 June 12th, 2007 12:57 AM
oh man... 2000Si The Clubhouse 40 May 20th, 2007 01:28 AM
New Man MstnG36 New Members Introductions 10 February 28th, 2006 08:06 PM
