Electric Fuel Pressure Gauge Install
Old May 27th, 2009, 02:30 PM   #1
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
I've used the search and did not produce the results I was looking for. I have read all of the Autometer install doc and I understand it no problem. My dilema is where should I tie in the white wire (dash lighting)? The red wire goes to a switched 12v power source and the black is obviously a ground. I have a mechanical boost gauge and I used an add a circuit on port 37 (adjustable illuminaction) 5a on the fuse panel. I was considering using another add a circuit for the power and use port 21 (Instrument Cluster and Engine
Control Memory) 5a since I'm already using port 37. That will get me the switched 12v power and the ground is easy. Any thoughts on where to put the white wire?
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old May 27th, 2009, 02:44 PM   #2
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
I tapped my gauges into the light wire for the cig lighter. Mainly did it for ease of access, doesn take long at all to get at it.
Old May 27th, 2009, 02:55 PM   #3
I should have added I will be using the instrument cluster dual pod piece from autometer and the fuel pressure gauge will be on the far left as you are sitting in the car. The fuse panel is right there, so I would prefer to keep the wiring in that general area.
2001 Bullitt #5069
Old May 27th, 2009, 02:58 PM   #4
Blown 03 GT
I mounted mine on the pillar, theres plenty of room to run a wire under the dash, I just found that to be easiest. I was looking near the switch for the lights first but its a bitch to get at any of that.
Old May 27th, 2009, 03:00 PM   #5
Which wire did you use on the cigarette lighter? I don't use it at all. In fact I have the "Eject" plug with no coil in it.
2001 Bullitt #5069
Old May 27th, 2009, 03:23 PM   #6
Blown 03 GT
That part of the reason I used it too I dont smoke so I dont use it. Ill have to check the wire I used when I get home. Theres also plent of room there if you end up running 3 of more gauges.
Old June 2nd, 2009, 02:30 PM   #7
Did look to see what wire it was?
2001 Bullitt #5069
Old June 2nd, 2009, 03:05 PM   #8
Does anyone think it would hurt to tie in the white wire in with the red from the mechanical boost gauge that is on the add a circuit? I have the add a circuit plugged in to the illumination slot which will dim the gauge. I'm up for any other ideas or how to links. If not I guess I'll have to make my own how to for it.
2001 Bullitt #5069
Threads Similar to: Electric Fuel Pressure Gauge Install
How to install fuel pressure and boost gauge?? Saleenssc14 2.3 Mustangs 19 July 22nd, 2008 11:48 PM
Electric fuel Pressure Gauge Smeltzs 2005 - 2010 11 July 1st, 2008 03:55 PM
Fuel Pressure Gauge Install 01dutchGT 99-04 8 January 13th, 2008 08:58 PM
electric fuel pressure gauge chozen1 2005 - 2010 9 August 23rd, 2007 02:41 PM
Electric Fuel Pressure Gauge question hawks05 99-04 3 March 10th, 2007 05:57 PM
