Electric Water Pump
Old January 26th, 2007, 02:06 PM   #1
MyBloodRunsBlue is on a distinguished road
Electric Water Pump
i have heard so much about how getting an electric water pump increases hp and i'm confused . how exactly does that give you hp? please someone elaborate..
wesley
Old January 26th, 2007, 02:10 PM   #2
Danny01gt is on a distinguished road
It elliminates the uses of the belt to power the pump shortening the drive belt distance and freeing up the restriction that it takes for the belt to run the pump.
Old January 26th, 2007, 02:21 PM   #3
what would you say the hp gains would be?
Old January 26th, 2007, 02:28 PM   #4
Jeff99gt is on a distinguished road
Send a message via AIM to Jeff99gt Send a message via MSN to Jeff99gt Send a message via Yahoo to Jeff99gt
Dude sick wheels im gettin black bullits, like the red and steeda wing
Old January 26th, 2007, 03:24 PM   #5
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
well actually your not shortning the belt you still use the stock belt its just less accessories for your motor to turn. the come with a idler so you belt will still go around it but it will not take any power from your motor to make it work since its electric. You can prob get about 10hp from it.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old January 26th, 2007, 03:31 PM   #6
superbeef1000's Avatar
thats pretty good gain for the 300 bucks
Old January 26th, 2007, 05:19 PM   #7
Slicey is on a distinguished road
Send a message via MSN to Slicey
ya...real good...just like 200 bucks on a cia is a great deal for 7 hp and 180 bucks on pullies for 9 hp.
Official MM Zeppelineers. Crew member #3
Old January 26th, 2007, 09:21 PM   #8
thanks guys appreciate the help where can you buy an electric pump?
Old January 26th, 2007, 10:13 PM   #9
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
personally, i dont reccomend and electric water pump on a street car. If you have any kined or wiring problem or elelctronic malfunction you pretty much lose drivability of your vehicle and you're not going anywhere. With a belt driven pump, if it breaks, at least you can limp home.
Old January 26th, 2007, 10:19 PM   #10
acehole is on a distinguished road
this should be it
http://store.summitracing.com/partde...5&autoview=sku
WHEN THE GREEN LIGHT DROPS THE BULLSHIT STOPS
Old January 26th, 2007, 10:37 PM   #11
sonicblue's Avatar
1990 GT
sonicblue is on a distinguished road
lethal performance has them
getting all fixed up for next season
2004 mustang gt 520rwhp, 491 trq sold
Old January 27th, 2007, 12:17 AM   #12
you can get the same pump cheaper at rpm outlet 308.00
http://www.rpmoutlet.com/musv8fan.htm#1
Old January 27th, 2007, 12:42 AM   #13
sonicblue's Avatar
1990 GT
lethal will match prices. but yea thats a pretty good deal no matter where u get it from
Old January 27th, 2007, 04:05 PM   #14
1999 Mustang
Invictus is on a distinguished road
55 gallons per minute! good lord lol
Old January 27th, 2007, 07:37 PM   #15
invictus what are you talking about?
Old January 27th, 2007, 07:42 PM   #16
1999 Mustang
i was reading the specs on the pump.. i didnt have any idea it flowed that much but then again i dont know much about anything lol
Old January 27th, 2007, 09:10 PM   #17
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Think about what you just said. If you lose power to your electric pump, you have no coolant flow. If your belt driven pump breaks not only do you have no coolant flow but you also have no belt to run your accesorries anymore because chances are the bearing failed and the shaft broke. How is that better? A good electric pump works fine on the street and will cool the car much better than a stock pump. Wire it properly with a relay and you will never have an electrical problem.
Threads Similar to: Electric Water Pump
electric water pump Newtgadget 5.0 Mustangs 12 October 29th, 2007 11:06 PM
electric water pump and fan notsoslow50 5.0 Mustangs 17 September 9th, 2007 05:12 PM
Electric water pump questions? catchtheroadrunner 2005 - 2010 5 April 30th, 2007 01:26 PM
Electric water pump MySallyMI 99-04 16 March 1st, 2007 11:58 PM
Electric Water pump question lugthug713 94-95 3 December 22nd, 2006 01:05 AM
