car cuts off in idle??
ok so my car takes FOREVER to crank up and i have to keep mashing the gas to crank it up.. and when it does crank up it sounds like its skipping but i just changed spark plugs and wires...
i have to keep the rpms up or it will shut off? i dunno wtf is wrong with it now!
If It Dont Flow It Wont Go!!!![]() forged pistons,teksid block and a romeo cast cranks for sale.. pm if interested.. selling them for next too nothing |
Check you IAC Cable hookup, the IAC should be bolted to your throttle body somewhere. I left mine undone after cleaning one day and it sounds like the same thing. Or could just be the sensor gone bad, or lots of other things i dont know much about cars.
Go Pokes! MM Cobra Club #33 VERT CREW #02 |
!FACEPLATED!
its most likely your IAC, it probably has to be cleaned.
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ |
Check your fuel pressure, Vac leaks and IAC.
one of my vaccum hoses is broken but it has been running fine for awhile like that so i doubt thats it?
the IAC makes yourcar sound like its skipping? i didnt know that?
yeah simple fix, just get some air intake cleaner and clean it out
ok ill try that.. thanks guys
#8 | |
1999 GT Rag
never@ran
Controls how much air gets to your engine when you are not mashing the gas. Basically, some gunk starts closing the small clearances between the IAC valve edge and the solenoid stuff which slows/stops the valve from working, which in some cases will stop working in the closed position, and will not deliver the necessary amounts of air, causing stumbling and stuff, eventually turning off the car, if not mashing the gas around idle rpm. |
on the topic of air.. i played around with something the other day.. the lil box just before the t/b that i belive goes into the IAC. its just a hollow box.. right.. i took it off. and the car dosent run hahahah put it on runs fine.. who woulda thought a empty box about 2 inches long could cause such a problem lol just a fun fact
![]() 2000 Mustang GT 2009 Kawasaki Ninja 250R (For Sale) 2002 Yamaha yzf R6 |
2003 gt
5.4 32v on the way
Yeah when you pull that off the air is not drawn from your intake, so the maf doesn't read any air. Your car needs air measured by the maf.
Before asking a gearing related question click THIS link and enjoy all your saved time. Click here for your tuning needs My slow paced budget 5.4 dohc build |
ok well guys i cleaned tje IAC,MAF and the TB,....... still not idleing... my oil has water in it..... some how... if i have a blown intake or head gasket ho will i know?
will this be the cause of it not idleing right?
umm h/o i helpd a guy with a problem like this ill post the thread
Threads Similar to: car cuts off in idle??
| what does your car idle at?? | o2gtstang | 99-04 | 46 | March 3rd, 2009 09:33 AM |
| do you need fly cuts? | 89lx | 5.0 Mustangs | 29 | December 17th, 2008 02:24 PM |
| my car at idle.. | jat | 2005 - 2010 | 4 | November 10th, 2008 12:19 PM |
| 94 ford mustang surges at idle and cuts out when push gas | akahoops | 5.0 Mustangs | 5 | February 18th, 2007 03:31 PM |
| fuel cuts out car completely/then kicks back in | bobs86 | General Tech | 9 | August 21st, 2006 05:11 PM |
