Codes P1000 P0171 P0174 Please Help!!!
Old June 9th, 2009, 01:49 PM   #1
JerseyTrueBlue's Avatar
2001 Mustang GT
JerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura about
I have no idea why I am pulling these codes I'm throwing a P1000 OBD system test not complete? and P0171 and P0174 System too lean bank 1 and bank 2. Can anyone dumb this down for me? I have to get my car running right it's my only vehicle and I just put in a brand new motor I can't afford to f it up. I've checked all my hoses everything is fine and connected properly I'm getting an exhaust leak taken care of tomorrow I don't know what else could be causing this I'm seriously so fed up I wanna drive it off a cliff. I had none of these problems before a spent a few grand on a new motor, is it because I'm running my old ecu? Does that even matter? Should I take it to a dyno shop and let them tune it? Please any advice is greatly appreciated.
Old June 9th, 2009, 02:25 PM   #2
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
Where is your exhaust leak at? If it's near the front it might throw those codes. I'm not for certain though.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old June 9th, 2009, 04:35 PM   #3
Quick99's Avatar
1999 Mustang GT
Quick99 is on a distinguished road
Fix your exhaust leak first. Try cleaning your MAF sensor and check for vacuum leaks.
Old June 9th, 2009, 05:52 PM   #4
2001 Mustang GT
I checked all my vacuum hoses the maf is brand new the exhaust leak is somewhere by the mid pipe im not exactly sure where
Old June 9th, 2009, 06:11 PM   #5
I'm cool..
GTRACER88's Avatar
GTRACER88 has a spectacular aura aboutGTRACER88 has a spectacular aura aboutGTRACER88 has a spectacular aura about
That is caused by bad reading from your O2 sensors. Either your sensors failed or the exhaust leak is causing the system to read bad.
Super Slow 2012 Grabber blue 5.0...
Old June 9th, 2009, 11:19 PM   #6
neverfastenough1's Avatar
I don't think it is very often that both sensors go bad at the same time, but I guess they could.
Old June 10th, 2009, 08:57 AM   #7
2001 Mustang GT
It wasn't the leak or the sensors I'm running out of options anyone else have any ideas? Vacuum leaks sensors and exhaust all checked what could it be!? Will a new tune help?
Old June 10th, 2009, 12:16 PM   #8
Trick Tuners's Avatar
KB'd GT
not if you are on the stock tune. If you have an aftermarket tune you need to contact your tuner and have him fix your tune.
Old June 10th, 2009, 06:51 PM   #9
I'm cool..
GTRACER88's Avatar
Do you have cats? Check to see if they are clogged.
Old June 10th, 2009, 06:52 PM   #10
I'm cool..
GTRACER88's Avatar
I got both codes but only changed my drivers side O2 sensor and the problem was fixed. Saved $40 on a second O2.
Old June 11th, 2009, 08:32 AM   #11
2001 Mustang GT
It's broken down to this, someone at svt told me that if I'm running the old ecu I have to run my old wire harness which I did not know. Supposedly if you don't change the harness the computer won't even act like you changed the motor. Anyway if this works it will be a miracle sorry for making you all guestimate at what was causing these codes if this doesn't change anything I'll try your other suggestions thank you again.
Old June 11th, 2009, 10:01 AM   #12
Did you just start it and run codes, or did you let it warm up first? Just asking. Has to be a certain temp I believe in order to complete the test. Hopefully it is corrected with the harness.
Old June 15th, 2009, 04:36 AM   #13
2001 Mustang GT
It was always warmed up
Threads Similar to: Codes P1000 P0171 P0174 Please Help!!!
P1000 njstang 99-04 4 April 17th, 2009 02:39 PM
p0171 p0174 codes 03 cobra rob 4V / SVT 8 November 30th, 2008 02:05 PM
codes p1000 and p1605 gtdan 96-98 8 August 19th, 2008 04:49 PM
P0171,P0174 Clay 99-04 4 October 2nd, 2007 05:58 PM
p0171 code 96gtponyred 96-98 7 August 24th, 2007 12:03 AM
