Blown 03 GT
Low oil pressure at start up??
When I start the car up I can hear a lil ticking for 15-20 seconds or so and my oil pressure gauge shows like 90psi cold. This started happening after my oil change this weekend. I double checked and the oil is 5w-20. The motor is brand new with a brand new cobra oil pump. It was running just fine before the oil change. Im lost as to what it could be.
Actually my car does a similar thing now. Not sure if its the weight of the oil or what. But when I first start my car it does that ticking for about 4 seconds then stops, just during the initial vrooom, then it goes away. I figured it was just oil not reaching the top end yet
![]() 99' Rio Red Mustang GT: --My Garage-- Check garage. Vortech V-1 intercooled running 9lbs of boost Life= eat, lift, eat, eat, eat, sleep, repeat
99 limited edition vert
what kind of oil filter are you using?
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
#4 | |
Blown 03 GT
Im using the purolator pure one filter, could that be it? Ive used purolator before with no issues but they jsut came out with the new design.
put a factory filter on it and see if it helps,fl820 iirc
Blown 03 GT
Yeah I was thinking at lunch I always ran synthetic oil, but im still breaking in the new motor, that may be it.
I run a motorcraft filter with motor craft oil, and it still does it at startup, only for a few seconds though
Blown 03 GT
what oil weight? and regular or synthetic? hes it always done it?
Regular 5-20. And no it hasn't... Don't know what changed. Only within the last few months I'd say.
Blown 03 GT
Your issue sounds more like a oil pump problem. Mine is brand new so it should be ok.
Threads Similar to: Low oil pressure at start up??
| Low oil pressure | Night Watch | 5.0 Mustangs | 4 | August 6th, 2008 06:05 PM |
| oil pressure to low at idle?? | jasons_98gt | 96-98 | 9 | July 2nd, 2008 12:03 AM |
| Low Oil Pressure | 91lxhatch | 5.0 Mustangs | 2 | July 29th, 2007 01:14 AM |
| kickout 7qt oil pan w/low oil sensor hole | Iownastang | 5.0 Mustangs | 2 | July 19th, 2007 02:17 AM |
| low oil pressure | kratos2250 | 5.0 Mustangs | 4 | March 1st, 2007 09:18 PM |
