quick blower ic setup question....(bov related)
Old June 13th, 2009, 11:51 AM   #1
turbot4's Avatar
R.I.P.
twin screwed!!
turbot4 has a spectacular aura aboutturbot4 has a spectacular aura aboutturbot4 has a spectacular aura about
iTrader: 9 reviews
just wondering if i have my ic set done correctly.....
at part throttle i feel like the valve maybe openeing and closing, which i think is normal..
when i rev the car and release the pressure, i get a fluttering noise...as my bov is venting back into the power pipe....
is this bov flutter or commpressor surge?....
just want to make sure i have my setup done correctly..(don't want to hurt the sc or the car)
my bov (stock vortech) connects to my tb ic pipe, and then connects again to the power pipe...the mass and filter are in the fender...
here is a pic and video of what it sounds like and looks like..
Old June 13th, 2009, 02:45 PM   #2
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
Are you running the stock BPV? I know my stock BPV doesn't sound like that. I don't recall the exact number, but if you're pushing past a certain # of boost the stock one isn't going to bleed off that pressure like a larger one can. You'll have to upgrade to the Vortech mini race BPV.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old June 13th, 2009, 07:20 PM   #3
turbot4's Avatar
R.I.P.
twin screwed!!
iTrader: 9 reviews
it is the stocker, but i have a bigger bosch dsm bov, thinking of swapping it in ...
Old June 13th, 2009, 07:38 PM   #4
I would since you are already pushing what about 10#s IIRC?
2001 Bullitt #5069
Old June 13th, 2009, 09:00 PM   #5
turbot4's Avatar
R.I.P.
twin screwed!!
iTrader: 9 reviews
yeah, the dsm bov is much larger than the stock vortech, they appear to work the same and the dsm valve has a stiffer spring than the vortech....i gotta get some new rubber piping next week, and i will install it...i'll post up when i do since nobody else wants to chime in.. oh yeah, what's IIRC mean?
Old June 13th, 2009, 11:54 PM   #6
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
IIRC=If I Remember Correctly...
yes that fluttering noise is the bpv blowing back into the intake tube. or at least that's the sound mine makes. but it's never a bad idea to upgrade bpv's.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old June 14th, 2009, 07:23 AM   #7
turbot4's Avatar
R.I.P.
twin screwed!!
iTrader: 9 reviews
so switching to a blow off valve from a bypass will be bo different?...i won't be venting it, so it will work just like the vortech bpv...it's much larger and has a stiffer spring so i think i will benefit from it...
so since they both work the same, i should have no problems correct?
Old June 14th, 2009, 08:47 AM   #8
Right. They both funtion the same. In this case they work as a bypass valve since your MAF is before the BPV. That air is metered, so you can't make it a BOV. If the MAF was after the BPV then it would funtion as a BOV and you can blow off to the atomoshpere.
2001 Bullitt #5069
Old June 14th, 2009, 11:01 AM   #9
2000 gt
yup if you're a draw thru system you can't blow it off to the atmosphere. you'd be wayyy too rich if you did that lol.
HARDCORE CREW
Old June 14th, 2009, 04:52 PM   #10
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
I've not seen the vortech BPV, but I'm assuming that it works the same as a Procharger if both are blow through systems. I'm not sure why you want a stronger spring. The throttle body controls how much boost your engine gets. Unless the throttle body is wide open the excess boost has to go somewhere and that's out the BPV. And they do make a lot of noise when you go WOT and then let off.
Mine made excess noise because it was loosing vacuum, not because of the spring. There wasn't enough vacuum to hold it wide open so the excess pressure had to sqeeze through a smaller opening.
You can basically tell how open your BPV should be by looking at your vacuum/boost gage. The more vacuum the wider it is open. At idle it should be fully open. As vacuum goes down, the spring closes it. When the gage shows boost then not only the spring but the pressure is holding it closed.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old June 14th, 2009, 08:32 PM   #11
turbot4's Avatar
R.I.P.
twin screwed!!
iTrader: 9 reviews
well, i believe at part throttle driving , my stock vortech is not staying closed causing a few blips every now and then , my tuner says it's normal, but i think with a bigger stiffer bov, it should help the problem.....and release pressure much quicker
does that make sense or am i way off?...
Old June 14th, 2009, 10:45 PM   #12
12.73@111.36
I don't think that's correct. A centrifical supercharger builds boost with rpm but it doesn't matter how high the rpm or how much boost you're generating if you are at partial throttle your vacuum/boost gage will show vacuum. The butterfly valve in your throttle body has the boost from your supercharger blocked. It needs to go somewhere that's why the BPV is open. I've tested this by driving at 5000 rpm in third down the highway. You can hear the pressure roar out the BPV. If it didn't the pressure would be forced back into the supercharger damaging it. Ideally the BPV and the throttle body valve work together but in opposite directions.
Old June 14th, 2009, 11:32 PM   #13
turbot4's Avatar
R.I.P.
twin screwed!!
iTrader: 9 reviews
but either way , using a larger bov the same way the bpv is set up will work right?...
Old June 15th, 2009, 01:53 AM   #14
12.73@111.36
A larger diameter BPV should work the same way. It's diaphram and spring should be balanced to operate correctly. You ought to call Vortech and ask.
Old June 15th, 2009, 05:29 AM   #15
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
There's a bigger volume of air now and I doubt the stock bypass can keep up. That's why you hear the flutter now.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old June 15th, 2009, 07:30 AM   #16
turbot4's Avatar
R.I.P.
twin screwed!!
iTrader: 9 reviews
thats why i thought with the bigger valve should help it out..i'll find out later this week..
gotta get to the junkyard to get some hose..the local autoparts store only sells radiator hose that big and it cost alot more than expected being i need to by a radiator hose so i need to wait..
Old June 15th, 2009, 09:04 AM   #17
jivepepper's Avatar
If you lived a little closer I would probably have some. What size pipe did you use for the intercooler?
Old June 15th, 2009, 08:56 PM   #18
turbot4's Avatar
R.I.P.
twin screwed!!
iTrader: 9 reviews
3inch...pepper, where do you live?...
anyway if i can't get any hose, i'll just hit the local you pull it at the boneyard...i'm sure the'll more than likely give it to me...
Old June 15th, 2009, 09:13 PM   #19
jivepepper's Avatar
Right at the end it looks like the stock vortech pipe. Morgantown WV.
Old June 16th, 2009, 07:28 AM   #20
turbot4's Avatar
R.I.P.
twin screwed!!
iTrader: 9 reviews
no , it'snot...speaking of i need to put that one for esale on ebay.
i thought you were in pa..
Threads Similar to: quick blower ic setup question....(bov related)
Post your blower setup! mustang_montana General Tech 51 July 9th, 2009 01:28 AM
Need quick help about a breake related part 04silversnake 5.0 Mustangs 5 May 31st, 2009 04:11 PM
Quick and simple non car related chop. Help! keeprollin02 Chopshop 9 March 12th, 2009 01:39 PM
Question about a blower setup futureMACH1racer 4V / SVT 27 October 14th, 2008 07:18 PM
just looking out: cheap blower setup nes General Tech 7 December 25th, 2007 11:42 PM
