2001 Mustang GT
8.98 1/8
Getting Really Fed Up ...Noise Problems
Alright people i really hope you can help me out here . im not looking for people to bash me or anything else i just want some help from you guys/ ladies ,,,,Alright so about to months ago i did a gear install this is my second one but this is my first i did all of the work on. I used AJM write up cause it covers everything pretty clear so i dont forget crap . So the gear install went pretty good except i broke an Abs sensor but i replaced it. When i went to put on the passenger side caliper on it acted funny as if it didnt fit right like the piston kept backing out, so i through the wheels on and drove around, it seams like i do have a tad gear whine but only on deceleration but its not that loud its very quite to hear. But i turned right and it sound like a massive grinding sound on the brakes but only from the passenger side.
So i have been driving around like this for awhile now and cause i thought it was the caliper acting funny and i saved up some money so i could do the brakes and replace the ps caliper. So i was doing the brakes today and the passenger side caliper went on really smooth like it should and i put new brakes in on both sides obviously and the brakes on the ps were pretty much shot especially the inner pad . So i put my wheels on and went for a drive and took a right turn the grinding sound is still there along with the hum ( it hums after you go straight again for like 5 seconds almost like the pad is re setting itself but then the hum is gone ) so if i drive straight or make a left hand turn there is no noise what so ever so this has me stump ... i hope i dont have to tear into the gears again ... i might kill myself cause its one thing i dont like doing. so if anyone could help me that would be helpfull ... and if you think of the way to fix the problem and it works reps will be given for sure
![]() CHECK MEH GARAGE BAMA Performance Drag Team #9 |
1999 Mustang GT
8.30 1/8th mile
Sounds kinda like my problem, hope someone can help you.
99 limited edition vert
wheel bearings? put it on stands and run it to see if you can hear it, or go in circles and have someone pinpoint it for you. Just remember...SAFETY FIRST
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
2001 Mustang GT
8.98 1/8
Ok ill go pull the wheels off to check if there is play ... should there be any play or no ?
oh and i just talked to my buddys dad and he thinks it would be a axle wheel bearing maybe ?
2001 Mustang GT
8.98 1/8
limited looks like my buddys dad wasnt the only one who thinks that is what it could be
2001 Mustang GT
8.98 1/8
zip ... i havent taken off the wheels yet but what does that mean if there is play in the axle ? ( obviously not good ) but what causes that
Moderator
Well, usually there will either be the proper amount of play, just a small amount, or you will know something is seriously wrong, like the bearing is completely torched, or you forgot to put a c clip on in the dif. lol
The only other real possibility is a broken axle, but obviously that would be catastrophic and the car wouldn't have moved very far.
2001 Mustang GT
8.98 1/8
thanks zip ... ok i went out there and jacked the car up and there is a lot of play on the passenger side and some on the driver side that isnt as much as the passenger but seams like more than a c-hair lol and i dont think i forgot a c clip lol ... ( well lets hope not) so if its the axle bearing should i just do both then so i dont have to dig into my diff again lol
odds are even if you forgot the c-clip or it fell out during assy. the axle will not come out. the brake caliper will hold it in. pull the caliper and then check your play to be sure it did not fall out
2001 Mustang GT
8.98 1/8
caliper off and axle didnt fall out .... zip so what am i going to need to replace just the axle bearing or is there other crap that goes along with that ... a parts list would be great guys thanks
This sounds like exactly what happened to me when I installed my first set of gears. Only happens when you turn right without giving it any throttle? Open the rear end up again, and I bet you that if you push hard enough you can move the carrier back and forth. When I did mine I got back lash, and everything set, but couldn't tell it was going to move (not enough shims) cause you really have to give it a good push back and forth. So first off I hope you didn't throw away your extra shims. Second just get some more fluid, and some more RTV, and reopen her up. When I did it I had it done in like 1 hour cause I knew what to inspect, even getting back lash correct again after adding in more shims. Also does there seem to be any play in the drive line even with the clutch in?
Threads Similar to: Getting Really Fed Up ...Noise Problems
| Fed up with 3650 | 06VistaBlueGT | 2005 - 2010 | 15 | October 17th, 2008 03:55 PM |
| fed up with it... | usmcsawgunner | 5.0 Mustangs | 15 | October 16th, 2008 08:32 PM |
| seriously Fed up | tsp_2177 | The Clubhouse | 28 | April 13th, 2008 03:31 AM |
| Getting Fed UP | 00SoSlow | V6 Mustangs | 7 | May 31st, 2006 01:04 PM |
| forced fed??? | 97six | V6 Mustangs | 10 | May 2nd, 2006 12:38 AM |
