mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
flashing battery light
i posted about this a couple years ago, but didnt get very far on it. i getting rid of my udp's and going back to my stockers. i got to remembering today about the issues it used to have with stock pulley's. i now have to worry about if the stupid thing is going to start doing it again.
at WOT about 4500 rpm's or so, the battery light would start flashing, it would did this at high rpm's. once i installed my udp's, the issue went away. the alt charges fine, belt is fine, etc. i still using the stock one that came on it, and dont have any plans to change it as of yet.
mm's nitrous mod
2000 mustang gt
no one? honestly?
2003 Mustang GT
12.28 @ 116
![]() ![]() iTrader: 13 reviews
it was the opposite for me. My underdrive pulleys caused the flashing battery light and like you said everything worked just fine. I eventually took the bulb out of the speedo cluster so i wouldnt have to see it anymore lol
![]() 2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's |
mm's nitrous mod
2000 mustang gt
come on guys.......
2002 GT
99.99@999.9
sweet, you know more about cars than i do, but my car did that same exact thing for about a month and my alternator was overchargeing and melted the wire leading from the alternator to the batt.
2002 GT
99.99@999.9
my alternator tested fine at the shop, but would only overcharge when i would goose it up to around 3500 and up
Moderator
2012 300a gt auto
12.10@116
the high rpm over-charge makes the most sense, when you put the udp's on it slowed it (the alt) down enough not to notice the problem.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
2002 GT
99.99@999.9
it fried my shit, and i didn't notice it until i smelled wires burning (thought it was stereo) and took me 2 hours to find the rubber boot that covers the contact on top of the alternator was melted... needless to say it fried all the way to the batt.
mm's nitrous mod
2000 mustang gt
i checked the wiring and no damage. i not sure if its going to do the same thing again or not. i will be turning a lot more rpm's after the build, son i will have to keep an eye on it.
2000 GT CONVERTIBLE
could the light have been triggered by the belt slipping at the higher rpms maybe not charging well just briefly?
![]() silvermustangsregistry#0711 |
mm's nitrous mod
2000 mustang gt
according to my tuner, i never had a drop in voltage. if i remember right, the lights would dim as well. its been so long i cant remember what all it was doing.
Threads Similar to: flashing battery light
| OD off light flashing | PHXGT06 | 2005 - 2010 | 16 | June 19th, 2009 07:06 PM |
| Flashing O/D Light? | 06z28eaTer | 96-98 | 2 | December 26th, 2008 01:20 PM |
| OD light flashing | wannabeimportkiller | V6 Mustangs | 17 | January 1st, 2008 12:31 PM |
| Airbag light flashing | Ritchie58 | 94-95 | 3 | March 29th, 2007 08:54 PM |
| help-- flashing theft light | General Tech | 20 | February 16th, 2006 11:21 PM | |
