plans to build twin turbo 347 for 2002 stang
Old June 17th, 2009, 04:52 PM   #1
scp616's Avatar
scp616 is on a distinguished road
I'm about to sell my corvette I've been building for the last few years (no more chevy's in my driveway!) and I want to make my mustang faster, but if i take the 4.6 out, it's not going back in. I've also been dying to make something twin turbo, and as 302's are cheap, and a 347 doesn't cost anymore to build, since i already have to buy rods and a crank, it all comes down to a twin turbo 347. I found a few good turbo kits on ebay for around $1000, and with all the stuff i'll need for the engine, and the k-member to mount a 302 in my chassis, it's looking like i can build everything for > $5000. However, i would like to find some one that has done something similar, or just twin turbo'd any motor in a 4.6 mustang to see about the plumbing. Based on how large the 4.6 is, and how small the 302 is, i believe there should be plenty of room for everything, but seeing some pictures of turbos installed would help put my mind at ease. Any info is greatly appreciated
Scott
02 GT --> long tube headers w/ x pipe and flow masters, throttle body w/ intake plenum, cold air intake, short throw, 255 nitto 555's all around, 373 diff gears, 2 inch lowering kit w/caster camber plates, sony radio working with stock system
Old June 17th, 2009, 05:12 PM   #2
blkragtop's Avatar
2000 Mustang GT Conv.
blkragtop is on a distinguished road
Just my 2cents: I did the 5.0 thing for a number of years (still have a 347powered 85Ranger) and I think you should keep the 4.6 simply because the block is WAY stronger (unless you go after-market block) and you can keep the COPs system using crank and cam sensors to power an MSD ignition.
Built shortblock, P1SC- intercooled, MAC catback, lowered, black chrome Saleens, Nitto DRs
Old June 17th, 2009, 05:14 PM   #3
mpboy's Avatar
2002 GT
99.99@999.9
mpboy has a spectacular aura aboutmpboy has a spectacular aura aboutmpboy has a spectacular aura about
go 5.4
Originally Posted by Dennis View Post
i fail to see the humor here. the farve thing ok its funny. but that shit there is just fucked up.
Wow Chris. You are the square root of stupid.
Eh, I personally think 4" is too big.
Old June 17th, 2009, 05:17 PM   #4
scp616's Avatar
the block may be, but i would need a better crank to run any significant amount of boost and it's way easier and cheaper to get 700+ horsepower out of a 347. I ran the engine diagnostics and with inexpensive heads and only 10lbs of boost, it will push out about 680 hp, and 700+ with 12lbs
Old June 17th, 2009, 05:18 PM   #5
mpboy's Avatar
2002 GT
99.99@999.9
bigger is better i guess
Old June 17th, 2009, 05:18 PM   #6
scp616's Avatar
The 5.4 was an option for a while, but it's a little wider and i've heard you have to modify the strut towers. Plus, to get that kind of hp out of a 5.4 would also be pretty expensive, because i don't have any 5.4 parts.
Old June 17th, 2009, 05:22 PM   #7
I'm cool..
GTRACER88's Avatar
GTRACER88 has a spectacular aura aboutGTRACER88 has a spectacular aura aboutGTRACER88 has a spectacular aura about
Where are you getting the 347? Im curious how you figure to keep this project under 5k?
Super Slow 2012 Grabber blue 5.0...
Old June 17th, 2009, 05:25 PM   #8
scp616's Avatar
I'm building it from the ground up, i get all my parts for wholesale prices, so it's fairly inexpensive, and 302 stuff seems to be even cheaper than sbc. We just built my friend a 383 stroker for his cammaro for about $1400 and it's a solid 400+ hp engine
Old June 17th, 2009, 05:29 PM   #9
mpboy's Avatar
2002 GT
99.99@999.9
iv never dropped a 5.4 in, but i remember seeing a write up where a guy only had to notch the driver side exhaust manifold, but it is a wider motor
Old June 17th, 2009, 05:38 PM   #10
blkragtop's Avatar
I assumed you would be building an all forged shortblock anyway. The 347 won't live past 550hp very long (weak block), main bearing cap support be damned. On the plus side, the 347 is narrower, giving you more room between the towers for big turbo piping.
Old June 17th, 2009, 05:40 PM   #11
scp616's Avatar
yeah man, i think i'll stay away from anything wider, it was hard enough to put long tube headers on my 4.6, i had to jack the motor a few inches out of the car =P
Old June 17th, 2009, 05:41 PM   #12
scp616's Avatar
Originally Posted by blkragtop View Post
I assumed you would be building an all forged shortblock anyway. The 347 won't live past 550hp very long (weak block), main bearing support be damned. On the plus side, the 347 is narrower, giving you more room between the towers for big turbo piping.
I might go with an after market block anyways depending on the budget, but otherwise i'm just putting 4 bolt splayed caps on it and a girdle
Old June 17th, 2009, 05:41 PM   #13
mpboy's Avatar
2002 GT
99.99@999.9
i hate the 4.6....... it is a pain in the ass to work on. i had to take one out by my self in a driveway
never again
Old June 17th, 2009, 05:44 PM   #14
scp616's Avatar
No kidding, if i had to take it out there is NO WAY i am putting a mod motor back in, it's just too freaking big, and it weights 150lbs more than a 302 =P
Side note --> i'm also putting a 6 speed in with a double over drive so i get better gas mileage
Old June 17th, 2009, 05:45 PM   #15
mpboy's Avatar
2002 GT
99.99@999.9
well you sound like you know a bit more than me, and you have planned it out, so ill be looking forward to seeing what ya do
Old June 17th, 2009, 05:46 PM   #16
mpboy's Avatar
2002 GT
99.99@999.9
and at least you don't have to worry about inspection like the rest of these poor bastards
Old June 17th, 2009, 05:47 PM   #17
blkragtop's Avatar
Nice. I'd love to see you with an after market short deck aluminum block with twin turbos. SICK
Old June 17th, 2009, 05:49 PM   #18
blkragtop's Avatar
You might also catch the all new BOSS302 block on ebay for a good price sometime.
Old June 17th, 2009, 05:51 PM   #19
scp616's Avatar
Thanks man, i'll post some pictures when i get it done
Haha, yeah that's definitely a great advantage of being in SC
Old June 17th, 2009, 05:54 PM   #20
scp616's Avatar
I would love an aluminum block, but i don't know if i'll be able to afford one =P
Once i sell that chevy piece of crap (corvette) then i can start putting the engine together, but until then i'm just the kid in the candy store that doesn't have any money lol
Threads Similar to: plans to build twin turbo 347 for 2002 stang
DSS 347 twin turbo? 5.0 street stanger 5.0 Mustangs 75 May 31st, 2009 05:44 PM
Plans for BIW build. circleacustoms Chopshop 3 February 21st, 2009 10:37 PM
Looking to Twin Turbo My 83 Stang ccstud16 5.0 Mustangs 7 December 28th, 2006 03:19 AM
New plans for the stang Drgnracin72 99-04 3 May 1st, 2006 05:38 PM
DIY foxbody twin turbo build 87vert General Tech 57 April 14th, 2006 07:39 PM
