Procharger Install Questions - Page 3
Old June 22nd, 2009, 03:10 PM   #41
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
For my boost gauge, should I get just one that tells me my boost, or do I need one that is vacuum and boost?
Old June 22nd, 2009, 03:20 PM   #42
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
Vac will tell you if theres a leak in the system and it doesnt cost any more so def get one.
Old June 23rd, 2009, 08:46 AM   #43
iTrader: 7 reviews
How would you know if you had a leak somewhere? I'm not really familiar with how a vacuum system on a car works ie. when you should have vacuum, when you should have boost, and when it should be neutral.
Old June 23rd, 2009, 09:43 AM   #44
Blown 03 GT
Dcook when you car it at idle you will have max vacuum, about 19 inhg. With a NA car at full throttle you will be at 0 vac and 0 boost. With boost it depends how much your running but at some point you be neutral before it gets into boost. If at Idle your car only had say 10inhg vac then you have a leak. A leak in the vac system means your sucking in outside air. Theres alot of systems that work off vaccum pressure, depending on where the leak is it may or may not be an issue.
Old June 26th, 2009, 05:23 PM   #45
iTrader: 7 reviews
I'm hooking up my wideband, Autometer c2, and it's got a brown wire that's supposed to go to the throttle body and says something about WOT peak recall or something. On the autometer instructions, it shows that brown wire going to a sensor on the throttle body. I only see one sensor looking plug in on the actual TB, there's one towards the front of the car, like on the opposite side of where the throttle cable is. Does it hook in there somewhere? Has anyone wired up something similar that could help me out?
Old June 27th, 2009, 11:22 AM   #46
iTrader: 7 reviews
Anyone know about this?
Old June 30th, 2009, 01:45 PM   #47
Blown 03 GT
Whats the brown wire for? I dont think anythin goes to the TB
Old June 30th, 2009, 06:27 PM   #48
iTrader: 7 reviews
The brown wire is for peak a/f recall at WOT. I think it's supposed to read when the system goes into open (or closed loop, I can't remember which way it goes) at WOT, then sends a signal to the wideband to record the peak a/f while the system is running like it is (open or closed)
Old July 1st, 2009, 07:29 PM   #49
iTrader: 7 reviews
Here's what the manual says about the WOT Peak/Recall value that the brown wire reads:
This value is recorded when the Brown Wire in the instrument harness is connected to a good engine ground via a normally open, momentarily closed wide open throttle switch.
Is that type of switch already on our cars, or is that something extra that I'd have to get?
Threads Similar to: Procharger Install Questions
Procharger Install Questions dcook_14 99-04 7 June 18th, 2009 12:37 PM
Procharger Install. Help petrol_head 2005 - 2010 9 September 1st, 2008 11:48 PM
Procharger Install ~C~ General Tech 3 June 10th, 2008 02:54 PM
Procharger Install (06 GT) 06Black5spdGT 2005 - 2010 10 March 31st, 2008 09:04 AM
Procharger Install 2001Mustang Saleen 99-04 17 October 6th, 2007 03:27 AM
