WHOOP!
7.44@95 (1/8)
![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
P-51 TFS or Hardballr?
Before I install a fogger kit i'm going to upgrade to an aluminum manifold to potentially withstand a nitrous backfire. I'm not worried about hp #s as much as strength. I've done a ton of searching on the P-51, Trick Flow and Hardballr intakes but haven't gotten many definative results. Which one would be best for my application?
![]() Buy my: Nitrous Accessories Diablosport Programmer In The Classifieds |
1992 Lx
11.39@119.24
or have your nitrous kit set up right and not get a nitrous backfire
WHOOP!
7.44@95 (1/8)
In a perfect world....
Just trying to cover my ass. Got a window switch, but after experiencing one backfire, if it happens again I want it to damage the least possible.
The hardballr most of the time is on backorder, trick flow you will loose torque but gain hp from what I've read. So I will go with the p-51 or hardballr,
2003 Mach 1 Procharged 500rwhp club
WHOOP!
7.44@95 (1/8)
The problem i've had so far is that there isn't much hard information on anything but the Typhoon intake.
WHOOP!
7.44@95 (1/8)
Does this look good?
WHOOP!
7.44@95 (1/8)
No input at all?
6.82@100mph 1.45 60'
as long as you have your window switch set up right and your rev limiter set right you wont have a problem with a backfire... you need a good 400rpm difference in your limiter and the top of your window...
Moderator
2012 300a gt auto
12.10@116
gonna loose a ton of torque with the p-51 (did I say a ton? I mean a TON) but a very nice intake other wise. if you rig up your nitrous trigger to your clutch switch (so your spraying as soon as you release it) & steepen up your gears, it may work well for you.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
WHOOP!
7.44@95 (1/8)
Well shit. That's not what I wanted to hear. Thanks for the info though.
#11 | |
03 GT, 92 coupe 2.3T
have you looked into hogan intakes. the can make you a direct nitrous set up while building your intake. whats your budget? hagan intakes are not cheap. but the look is awsome. Hogan's Racing Manifolds » Products
2003 DSG GT 5-speed full bolt on's 03 cobra irs swap 18x9/18x10.5 TF mach 5 wheels
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
200 rpm from limiter is enough. i run 200 under mine with no issues at all, that is enough room to keep nitrous from spraying again. you are going to see torque loss with almost any aftermarket intake. if set up and spraying right, you shouldnt have to worry about a backfire.
2001 Mustang GT
NA
Bbk is coming out with there new intake... Wonder how that would work out for u?
02 Mustang GT
9.91@133
Do you plan to add some type of FI in the near future?
I've had the typhoon, hardball'r and now the Edelbrock.
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
I agree with Sweet2k. I just said 400 to be on the safe side lol. I have had one pop when my top window was 6k and I had stock limiter on there.
#16 | |
WHOOP!
7.44@95 (1/8)
No i'm going to stick with the nitrous. Which one did you like the best?
WHOOP!
7.44@95 (1/8)
I just read about the P51 in mustang5.0 and they loved it. It retailed at $1200 then. If I could get that ebay one for $500 would it be worth the swap?
mm's nitrous mod
2000 mustang gt
there have been a bunch of mixed reviews on the p51 from people who have had them. the guys at foxlake "claim" to loose no low end, but they are about retarded as well.
WHOOP!
7.44@95 (1/8)
K I think I'm going to call a few places tomorrow.
02 Mustang GT
9.91@133
The aluminum intakes will break with a backfire also and they get a lot hotter than the plastic intake. I say keep what you untill you have an issue.
The hardball'r was great, the typhoon is junk and the Edelbrock I like the best.
Threads Similar to: P-51 TFS or Hardballr?
| tfs 2v intake? | acg | 99-04 | 4 | May 28th, 2009 10:24 PM |
| Tfs Cams | DARKHORSE02 | 99-04 | 19 | March 30th, 2009 12:22 AM |
| tfs tw 165cc | BORDEN | 5.0 Mustangs | 5 | November 5th, 2008 01:30 AM |
| denied for the tfs!!!!! | 95stallion | 94-95 | 7 | February 4th, 2007 03:47 PM |
| TFS And Rockers | jetpilot106 | 5.0 Mustangs | 6 | October 7th, 2006 12:58 PM |
