#41 |
agreed. I want the i/c anyway. it adds to the look when i get my 03/04 bumper. It looks bare and empty. i/c makes it look more agressive imo.
Thanks guys. you all are a great help. Kenne Bell is probably what I'll get. does the kit comes with the gauges for fuel pressure and boost, but how hard are they to install?? and would you recommend the entire pillar replacement pod for them or just the smaller one? |
#42 |
99 limited edition vert
no guages included. they are not hard to install at all,There is a lot of options for mounting guages(dashboard,pillar,steering column and other) just get what you like best.
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
#43 |
i like the two pillar mounts, but im not sure which one would be better/ easier. the enitre pillar, or smaller dual pod.
#44 |
get the full pillar, looks more professional
#45 |
true. didnt think about it that way. looks more factory installed.
the boost gauges kb sells are also vacuum gauges too right? |
#46 |
1999 3V GT/2007 GT D/D
corner carver
Just so you know and are not disapointed but KB does not have a front mounted intercooler. It is under the S/C in the manifold so you dont realy see it.
OS2 (SW) USNREAR SEAT DELETE FABRICATOR "RSD pics in garage" 99 3V GT/2007 GT DD |
#47 | |
you can use the stock 03-04 h/e if you want to also
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com Last edited by limited; June 28th, 2009 at 05:50 PM. |
#48 |
corner carver
I just used aluminum mesh on my cobra R never cared much to see an intercooler or in this case the H/E. To each there own.
#49 |
hmmmm, not a bad idea, esp if it is a fine mesh. mine seems to be a bug collector and the screen might be easier to clean and give that alum. look in that area that I like
#50 |
2002 GT Convertible
Will a KB fit under a stock GT hood? That kicks up the cost a bit if it doesn't.
Mods- B&M Pro Ripper Shifter, Accufab 75mm TB/Plenum, Steeda UP's, JLT CAI, 3.73 Gears, MagnaFlow Catted X & Catback, FL Subframe Connectors, Diablosport Chip w/93 Octane Tune, Griggs Racing Lower CAs, Ford Racing Aluminum Drive Shaft
#51 |
The 2.1 will, the 2.6 or 2.8 require a new hood
Threads Similar to: Kenne bell for my 02 GT
| 1.7 Kenne Bell | BakerFX4 | 99-04 | 15 | March 21st, 2008 10:32 PM |
| Kenne Bell | Emay | General Tech | 16 | October 16th, 2007 11:52 AM |
| Kenne Bell ??? | silverstang0988 | General Tech | 17 | April 7th, 2007 11:38 AM |
| Kenne Bell | 03blownmach1 | 99-04 | 11 | June 28th, 2006 01:04 AM |
