Kenne bell for my 02 GT
well, I wanted to go N/A but its not the power I want, so im thinkin of a kenne bell supercharger.
What i want to know, is what all do i have to buy aside from the keene bell kit, to install it??? ![]() can i take the kit and it go right on my stock 4.6 or will i have to buy otehr mods as well???? |
what all does the kit come with?
![]() 480RWHP 450RWTQ 15psi @ 15* on 91 octane |
I dont really know what it comes with from kenne bell.
Im actually currently leaning towards an eaton M112 off a cobra.... will that fit on my GT? heres the link on ebay, very cheap!! |
1997 Mustang GT
335rwhp/370rwtq
upgrading injectors fuel pump and air delivery will add hp/torque. as far as i know you can run it stock
#5 | |
Im not looking for a vette killer, just a mild 375HP or so, i dont want to push my car.
My friend has a kenne bell on his, but he bought it that way so idk whats involved. I want to know what it will take to get it on my car for a mild tune, with minimal boost, of maybe 8-10lbs. nothing major. idk if im asking the right questions, thats why im asking here. lol i was thinking the eaton because its not very powerful, cheap, and i could run it without hurting anything. |
just make sure you upgrade the fuel system. pumps and injectors. and get a good tune. other than that i think kb comes with everything you need even a chip with a canned tune to get you around
beware though.. i run 9lbs of boost.. ill hunt you down .. lol
jk
come find me first. ha
what pump and size injectors should i get to run either the kenne bell or the eaton?? |
1997 Mustang GT
335rwhp/370rwtq
injectors and pump depends on the power you want, anything above stock will be an improvement
yea thats going to be dependent on the amount of boost/power your looking for.. you should be good with some 42lb ers
nice... what fuel pump would you recommend?
for about 8-10 lbs of boost? |
i run the twin cobra pumps .. fairly inexpensive
i would recommend a cobra tank or some sort of sumped tank though
yes
fuel tank..
not necessary but recommended
1999 3V GT/2007 GT D/D
corner carver
If he stays at 9 psi he wont need a fuel pump because the KB comes with the BAP and will feed it fine. If you up it to 12-14 you will need to upgrade to either the GT supercar pump, SVT focus pump, or the cobra set up. The KB kit comes with everything you will need to hit the road for the level of kit you buy. It will bolt right up to your 4.6 with the intake manifold that is part of the kit. I have instaled a number of blowers on friends mustangs and by far KB is the most complete and reliable. Just my opinion though
![]() EDIT: here is what the 2.1 comes with and some optional parts that I would recomend getting: MAJOR KENNE BELL KIT COMPONENTS Billet BIG BORE Twin Screw 2.1L Supercharger Hi-Flo Inlet Manifolds Billet Bypass Valve Assembly Bar and Plate Intercooler ("Intercooled" kit only) HD Heat Exchanger ("Intercooled" kit only) Intercooler Pump ("Intercooled" kit only) Water Fill Reservoir ("Intercooled" kit only) Re-calibrated Mono Chip 36lb Injectors BOOST-A-PUMP™ Fuel Rails ('96-'00) 160° Calibrated Thermostat Kenne Bell BOOST-A-SPARK™ (Best Ford 4.6 ignition. Recommended after 10 psi) Kenne Bell 90mm Meter & Chip (up to 13HP over stock meter) Kenne Bell 75mm Throttle Body & "Big Tube" Kit (18HP over stock) Kenne Bell Cool Air Kit (up to 13HP)
OS2 (SW) USNREAR SEAT DELETE FABRICATOR "RSD pics in garage" 99 3V GT/2007 GT DD Last edited by mustang_gtr_99; June 26th, 2009 at 02:57 AM. |
El Danno
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
Here's my advice
1) Buy a complete KB setup 2) Install it 3) Post videos of you ripping up the street so I can drool over them ![]() Seriously though, a KB is an awesome setup. If wouldn't have stumbled onto such a good deal on my Procharger, I was gonna save up and get a 2.1 or 2.4 Kenne Bell |
Threads Similar to: Kenne bell for my 02 GT
| 1.7 Kenne Bell | BakerFX4 | 99-04 | 15 | March 21st, 2008 11:32 PM |
| Kenne Bell | Emay | General Tech | 16 | October 16th, 2007 12:52 PM |
| Kenne Bell ??? | silverstang0988 | General Tech | 17 | April 7th, 2007 12:38 PM |
| Kenne Bell | 03blownmach1 | 99-04 | 11 | June 28th, 2006 02:04 AM |
