How to pull your 4.6 motor - Forums at Modded Mustangs
post #1 of 14 Old June 26th, 2009, 01:27 PM Thread Starter
im pulling mine now and could use some pointers if anyone else has pulled a 99-04 4.6 before and if someone wants to do a really nice write up im sure it would be great for the HOW-TO sticky. thanks. ill chime in with info as i go along.
BBK CAI, March UDPs, Eibach Sportline Springs, MM C/C plates, Koni Yellows, Centerforce DF clutch, FRPP Billet Flywheel, B&M Pro-Ripper Shifter, BBK ceramic LTs, BBK catted X-Pipe, SLP LM1, EBC rotors, 4.10 FRPP gears
5.4 4V coming soon
quiksilver225 is offline
post #2 of 14 Old June 26th, 2009, 01:30 PM
ndfrspd's Avatar
i just did mine a couple weeks ago and im posting pictures soon. its easy really. just label all your hoses and electrical connections with tape and sharpie. disconnect a/c compressor and power steering pumps and let them dangle. disconnect tranny bolts, 2 on top u can get to with a wrench and the others a socket wrench. disconnect 3 starter bolts, the top one is a PITA. unbolt the motor mounts with 21mm short socket. get that bitch outta there.
ndfrspd is offline
post #3 of 14 Old June 26th, 2009, 02:00 PM Thread Starter
what about the fuel system?
5.4 4V coming soon
post #4 of 14 Old June 26th, 2009, 02:11 PM
I Poop Entirely Way Too Much
This is the info I used for mine, its pretty helful
Originally Posted by SWEET2KSTANG View Post
put car on ramp on the rear tires and frame on stand on front of car
remove:
d/s from diff (i leave in on the tran side)
exhaust mid pipe
hood (in put blanket on top of car and lay hood on top)
raidator hoses
serpentine belt
top end (air filter to manifold)
ac compressor, p/s pump, and alt
wire harness
front tires
steering arm from rack to steering wheel
struts
calipers (tie up to car)
p/s lines to the rack and pinion
hook motor to cherry picker
put jack under trans
unbolt the 8 bolts for k-member
unbolt trans x-member
lower together
once lowered:
remove:
starter
hearders (if running long tubes)
un bolt motor mounts off k-member
take trans bolts out
slide trans off
jack motor up enough to clear k
pull k-member out
then lift motor strait out of the top.
thats what the steps i take if i can rember it all step by step. i just threw this list together really quick.
I left my fuel rails connects and just put them out of the way.
Nothing says "were dating" like sticking your dick in her.
03_StangGuy is offline
post #5 of 14 Old June 26th, 2009, 02:16 PM
I Blumpkin Entirely Way Too Much
KS_Yeti's Avatar
I also left the fuel rails connected, and i also left the ac all hooked up, just unbolted the ac compressor of the motor, same was the powersteering.
MM + Cleavage member #22
KS_Yeti is offline
post #6 of 14 Old June 26th, 2009, 02:17 PM
you can leave them connected, but you could also just get a fuel rail disconnect tool from autozone and pop it off there really quick.
on modular depot there's a good writeup someone did a couple years ago.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, 10 lbs, lee blankenship tune 430/405
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
mustanginky is offline
post #7 of 14 Old June 26th, 2009, 02:34 PM
KS_Yeti's Avatar
haha, now i need one of those tools because im replacing my stock fuel rails anyway! haha
KS_Yeti is offline
post #8 of 14 Old June 26th, 2009, 03:46 PM
mpboy's Avatar
just make sure you hang the PS pump on the body somewhere with a coat hanger when you get the motor out of the way, mine started leaking because i let it hang
Originally Posted by Dennis View Post
i fail to see the humor here. the farve thing ok its funny. but that shit there is just fucked up.
Wow Chris. You are the square root of stupid.
Eh, I personally think 4" is too big.
mpboy is offline
post #9 of 14 Old June 26th, 2009, 04:16 PM Thread Starter
link?...
5.4 4V coming soon
post #10 of 14 Old June 26th, 2009, 09:25 PM
mm's nitrous mod
SWEET2KSTANG's Avatar
iTrader: 8 reviews
its not bad, i did mine by myself and had it to bare block in 1 case of beer and 6hrs. you be suprised how much time you will waste to take a piss with that many beers in ya.
wagon burner built! track times coming soon!(04 lightning)
follow shop builds on facebook at: MP2 Performance
SWEET2KSTANG is offline
post #11 of 14 Old June 28th, 2009, 05:00 AM
2k3 Blown Mach 1
2002 BLK GT's Avatar
Send a message via AIM to 2002 BLK GT
A little bit of more info..
How to Pull a Mustang GT 4.6l Engine - Associated Content
2003 Mach 1 Procharged 497rwhp club
MMR broke me a valve.
2002 BLK GT is offline
post #12 of 14 Old June 28th, 2009, 09:49 AM
ndfrspd's Avatar
if you need more help PM me. i literally just did this a couple weeks ago and actually my new motor still has to be dropped in. if you need to swap fuel rails then YES go to advance autoparts and buy a fuel line disconnect tool. its a couple bucks and its like a piece of metal that will pop the line off the rail. ill tell you right now, its a billion times easier to remove the intake manifold and then use those holes to pull the engine, and it will make the engine just that much lighter when you pull it
Motor pictures by cttblakeman - Photobucket
ndfrspd is offline
post #13 of 14 Old June 29th, 2009, 02:25 PM Thread Starter
will do
5.4 4V coming soon
post #14 of 14 Old July 19th, 2009, 11:07 PM
Send a message via AIM to fordman992
nice info, good post and thanks for the pic
fordman992 is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/128352-how-pull-your-4-6-motor.html
I need help please step in - SVTPerformance This thread Pingback February 19th, 2010 03:57 PM
