Ordered some cams! Have a few questions
Old June 27th, 2009, 09:51 AM   #1
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
PapaSmurf has a spectacular aura aboutPapaSmurf has a spectacular aura about
iTrader: 11 reviews
Talking
Well i finally ordered some cams for the GT. I went with the HiTech stage 2's and also got a pair of manly nextek springs. These should work very well with my nitrous setup but i have a couple questions.
Am I going to have to upgrade to larger injectors or will my stockers be enough? I was thinking of some 30lb. Im going to upgrade my fuel pump to a single GT supercar pump but im just unsure on the injectors. Im currently running a 100 shot but will most likely up the shot to a 125 or 150. Also what is the normal cost of a cam instalation? Thanks guys
2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's
Old June 27th, 2009, 12:32 PM   #2
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
That would not have been my first choice in cams esp. with the 150 shot. the Hi-techs, iirc, favor the intake (more lift and dur.) which with nitrous I would assume you would favor the exh. cms stage 2 n/a cams would have been a better choice imho.
I would put bigger inj in. cam install I heard can be from $800 to $1100 with springs and no tune
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old June 27th, 2009, 01:26 PM   #3
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
iTrader: 11 reviews
Thats what i was thinking. Thanks for confirming the injectors.
Both the hitechs and cms do well with the nitrous. The intake side on our heads is already big and going with the cms would make it even bigger.
Old June 27th, 2009, 01:44 PM   #4
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
wanna buy me some cams caleb?
Can't wait to hear it when it's all said and done, and see how it does out on the track. I should have a few things done to the Termi by then...I'm used to the power, and need more. Damn you boost...damn you.
When do you get back man?
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old June 27th, 2009, 02:12 PM   #5
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
iTrader: 11 reviews
LOL! If i were you id be getting some pulleys from billetflow to up the boost. The GT is gonna be a different car with the cams, especially with some added spray.
I wont be back until winter. Before christmas though
Old June 27th, 2009, 04:14 PM   #6
Zoolander
iTrader: 5 reviews
Yeah, I'm about to beef up the irs a little bit, then a pulley with idler/auxillery pulleys, tune, cat back exhaust, JLT RAI...once I figure out midpipe, and headers I want I'll get them, but I think that will be a good start.
I'll give ya that ride in the Termi when ya get back man. I will want a ride in the GT though with all your goodies your getting.
MM Cobra Club #18
Team Tini Racing
Old June 27th, 2009, 06:31 PM   #7
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
injectors are fine, they will hold enough. if you do head work as well, then you will need to start shopping for them.
the hi techs do not favor the intake, the cam is well balanced. there is finally a cam manufacture that made a logical cam. the exhaust side out flows the intake side in a pretty bad way.
Old June 28th, 2009, 12:38 AM   #8
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
iTrader: 11 reviews
the hitechs actualily put down better numbers on spray than the cms stage 2's
Old June 28th, 2009, 01:18 AM   #9
zerofx150's Avatar
2003 GT
13.6 @ 101
zerofx150 is on a distinguished road
Send a message via AIM to zerofx150 Send a message via Yahoo to zerofx150
hitechs ftw
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports.
Old June 28th, 2009, 01:20 AM   #10
limited's Avatar
Just for my info, could you post where you got this info? Thanks!
Old June 28th, 2009, 01:22 AM   #11
limited's Avatar
Originally Posted by zerofx150 View Post
hitechs ftw
on a stock head/block I heard this also. on ported heads I would like to see the results compared to others
Old June 28th, 2009, 01:27 AM   #12
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
huh this get my pumped for my hitechs this september!
4V swap in the works
Old June 28th, 2009, 02:06 AM   #13
Double0Fox's Avatar
Double0Fox will become famous soon enough
+1 Next thing going in is Hi-Tech Stage 2's, so let me know how you like them.
Old June 28th, 2009, 02:51 AM   #14
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
iTrader: 11 reviews
I was talking to JayC on here about the cms stage 2's for awhile because thats what he is running and he told me he put down 394/497 on his 100 shot. I also talked to Casey on here (Sweet35th) about there cams and a 100 shot and he posted a dynograph HiTech stg2 cams. The car put down 408/530.
Old June 28th, 2009, 04:11 AM   #15
12.16 @ 112
Trevor04GT is on a distinguished road
Send a message via AIM to Trevor04GT
I cant see why people still think there are better cams out there than the HiTechs. I dont know, maybe I'm wrong, but for my daily driven to college everyday GT, my car seems to run pretty well with the HiTechs. I just could not imagine a more perfect cam choice for a stock head/bolton GT. The CMS/VTs may do better with a built motor and heads, but shit, the HiTechs are built for cars just like mine, Calebs, and any other GT running around with intake/exhaust.
With that being said, get a Focus pump and be done. Your injectors will be fine for a while. The pump will prolly be an issue. The focus one is a drop in basically. Very easy.
Good luck Caleb, I cant wait to see what your baby runs.
Trevor 2004 GT
HiTech Motorsports Stage 2 Cams
300/309 12.16@112
Old June 28th, 2009, 07:40 AM   #16
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
iTrader: 11 reviews
Thanks Trevor!
Old July 1st, 2009, 11:08 AM   #17
1999 Mustang GT
Regulator is on a distinguished road
Send a message via AIM to Regulator Send a message via Yahoo to Regulator
+1 for HiTech, one of the best choices I ever made on my car!
'99 GT FS/FT. Click here for details!
"And I heard a voice in the midst of the four beasts, I looked and behold: a pale horse.
And his name, that sat on him, was Death. And Hell followed with him."
Old July 1st, 2009, 11:46 AM   #18
JayC's Avatar
2001 Mustang GT
JayC has a spectacular aura aboutJayC has a spectacular aura aboutJayC has a spectacular aura about
A couple of things aren't right though. Note the jets weren't the NX recommended 52/33 for a 100 shot.
" 04 GT full bolt ons, long tubes, Hitech stage 2 cams, and NX with modified jet sizes to get 100rwhp out of the shot."
Also my dyno was a SuperFlow not the more "friendly" DynoJet. I'll stick with my CMS but I'm sure the Hi-Techs will be an awesome cam for you too.
tuned by SPEEDY DYNO
12.41 @ 109 mph w/ CMS stage II cams
11.13 @ 122 mph NX 150 shot
Launch soft, shift slow, rev low, stay slow
Old July 1st, 2009, 11:58 AM   #19
2002 mustang gt
momogt is an unknown quantity at this point
how much hp/tq will the hi tech stage 2 cam give a stock gt with basic bolt on,s and i have a automatic will i need a stall for that cam
Old July 1st, 2009, 02:43 PM   #20
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
iTrader: 11 reviews
They are both great cams and im sure the cms are workign great for you man. I was really close to getting the cms
Threads Similar to: Ordered some cams! Have a few questions
Just ordered cams & I have a question mrbill4 2005 - 2010 28 February 18th, 2009 07:34 AM
I ordered my cams today! RAGEman 99-04 5 February 1st, 2009 02:27 AM
great news.... ordered cams today!! HiTech stage 2s!! qwick04gt 99-04 27 January 29th, 2009 02:14 AM
just ordered! (cams) mustangrebuilder 2005 - 2010 13 May 23rd, 2008 07:04 PM
Just ordered my cams GTsetGO 94-95 10 April 12th, 2006 09:51 AM
