31 spline axle question
im getting my 4:10'S put in next week, i want to also buy a moser 31 spline axle, do i need to change my diferencial also. or will the 31 spline, just hook up and go?
1/4: 13.585 @ 99.53, 1.8 60' bolt on's/slicks, wtf... ![]() Wisconsin BLOWS!! riding the fail shuttle all the way to loser moon ![]() whp:261 tq:301 |
12.73@111.36
You need to change the differential as well. Depending on how many miles you have on the car you might also want to replace the bearings.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
dam, well i just hit 40,000 miles, i also have a bearing kit that is being installed, i got a pair of slicks now, and i want to be able to launch at 4000-4500 rpms without worrying about my axle, would a girdle help out a lot?
2009 ROTY
a girdle would definetly be a good addition. if you gonna launch on slicks, a 31 spline upgrade is definetly a worthy idea.
thanks guys, im trying to hit 12.8's, i got every bolt on, just waiting for my 4:10's, sub frames, and lower control arms to be installed then its getting dyno tuned, ill run it like that and if i blow an axle oh well, keep on building !!
31 spline is DEF worth it. Just grab the 05+ takeoff one. They are like 5 miles used, and cheap. They work really well. I think you can get them with the carbon clutches in them to.
![]() Trevor 2004 GT HiTech Motorsports Stage 2 Cams
300/309 12.16@112 |
Threads Similar to: 31 spline axle question
| Spline question | rxnodoze02 | 2005 - 2010 | 10 | December 20th, 2008 01:40 AM |
| Whats the difference between 31 spline and 28 spline?? | BREEZY B | 99-04 | 18 | May 31st, 2008 08:01 PM |
| Question Bout 8.8" Rear End And 28 / 31 Spline | 4point6GT | 96-98 | 4 | October 23rd, 2006 12:05 AM |
| Axle Spline Count | ryanhewett466 | 5.0 Mustangs | 2 | July 19th, 2006 11:48 PM |
