03 GT Procharger P1sc bracket question
Old July 2nd, 2009, 01:21 AM   #1
03 Mustang GT
klep2024 is on a distinguished road
Hey whats goin on guys? First post on here so ill make it a good one
I changed my belt yesterday and on the way home today it shredded on me already. When we were putting everything back together it went smooth except for the stud on the lower left side of the procharger bracket. That stud seemed pretty loose and every time we tried to tighten the nut it was just pulling the stud out of the head. My question is this..does that stud actually hold the idler pully on the backside of the bracket? And if the stud wasnt tight could that be the reason im shredding belts due to the bracket flexing forward and misaligning the pully?
Also the ATI idler pully isnt spinning as freely as all the other pullys...is this normal or could it be a bad bearing in that pully that is my problem?
Thanks in advance for anyone that can help out.
Old July 2nd, 2009, 11:43 AM   #2
El Danno
dcook_14's Avatar
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
I got a longer stud than Procharger sent and put that in there so it would go all the way into the hole and still has enough stick out to get a nut and lock washer on. And that stud does hold the pulley on the backside of the bracket.
Maker sure that the threads on the stud match the threads where its supposed to go. And if any of those bolts are loose it could cause a little flex in the system and maybe lead to a belt shredding. Are you sure it's all spaced right? There is supposed to be a washer between the bracket and the block on the upper left side. And did you put in that other M8x100 full thread bolt and back that out to butt up against the bracket? That's a pretty important part.
My ATI pulley spins pretty freely, but I dont know if it would matter that yours doesnt
Old July 2nd, 2009, 11:56 AM   #3
~C~
~C~, The Other White Meat!
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
~C~ is just really nice~C~ is just really nice~C~ is just really nice~C~ is just really nice
Send a message via AIM to ~C~
It should spin freely. I will check mine when I get home. I remember when I installed it it was a little weird, but then we adjusted a bunch of other bolts and it worked perfectly. You may have to loosen up the head unit and the bracket and then do a few bolts at the same time....little on each till they are all done.
BLOWN Bumblebeast!
370 rwhp / 381 ft lbs
~Tuned by JJ at WMS
"Like the blind man says......We shall see...."
Old July 2nd, 2009, 03:38 PM   #4
03 Mustang GT
Awesome thanks for the info guys...i have a feeling its that lower bracket stud that is causing my problem. I'll hafta check on the washer and the other stud being backed against the bracket.
Im almost 99% sure its the lower stud tho...cuz when i had everything back together and fired it up, i noticed when i gave it some throttle it looked like that stud was spinning its way out. i slathered the stud in loctite and spun it in as far as it would go and it didnt seem to move anymore, but i still ended up shredding the belt. Im gonna tear it apart tonight and see if the thread needs helicoiled to accept that stud.
P1SC Procharger @ 10psi w/ 3 Core Intercooler
and too many other mods to list
386 rwhp 397 rwtq
Military Crew
AM2-USN
Always looking for 03/04 cobra body parts
Old July 2nd, 2009, 08:59 PM   #5
~C~
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
you shouldnt have to helicoil it. The stud that was supplied by ati fits perfectly. the instructions are very hard to really figure out...especially the diagrams. When you do figure it out, all the parts are used you should have about a millimeter or two between the pulley and the alternator. The bolt that holds on the idler should be tight but the bearing, though a shitty one, should allow it to spin freely.
BLOWN Bumblebeast!
~Tuned by JJ at WMS
Old July 2nd, 2009, 10:22 PM   #6
03 Mustang GT
Everything is all together..my concern is with the threads inside the head that accept that stud. Thats why i was gonna helicoil it. It seems like everytime i went to tighten that nut down on the lower stud it was just spinning the stud out. When i gave it throttle the bracket flexed and the stud spun and was vibrating out of the block a bit. I'm pretty sure thats causing the pully to flex with the bracket and shredding my belt.
386 rwhp 397 rwtq
Military Crew
AM2-USN
Old July 3rd, 2009, 07:56 PM   #7
03 Mustang GT
Alrite guys i fixed the lower stud problem..helicoiled it and reused the stud after cleaning it up..Looks like the guy i bought it fromn discovered the problem i did but decided to mickey mouse it instead of do it right. There was JB weld all over the stud when i literally unthreaded it 2 turns and then pulled the stud right out of the head. So we drilled, tapped, and permathreaded a helicoil and the stud back in the head. Fixed the flexing and the car seemed to run MUCH better and even sounded much better!
So i took it out for a drive..babied it at first til it warmed up, then flogged it a couple times. Brought it home, popped the hood and found that the belt jumped two ribs towards the block on the a/c pully...bad tensioner? What do you guys think? The pulleys seem to be aligned perfectly but my buddy noticed that when i revved it up that the tensioner was moving back and forth quite a bit.
The guy i bought it from said the tensioner hasnt been replaced since the procharger was bolted on 11000 miles ago...procharger calls for a new tensioner at 10-15,000 miles. I think its the tensioner..what do you guys think?
386 rwhp 397 rwtq
Military Crew
AM2-USN
Old July 6th, 2009, 02:33 AM   #8
03 Mustang GT
Update: Replaced the tensioner this afternoon and everything is good to go! Thanks for all your help guys!
386 rwhp 397 rwtq
Military Crew
AM2-USN
Old July 6th, 2009, 10:13 AM   #9
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
glad to hear it.
Old July 6th, 2009, 03:28 PM   #10
~C~
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
Nice man! I will keep an eye out for my tensioner as well. Didnt know that. Good lookin out!
BLOWN Bumblebeast!
~Tuned by JJ at WMS
Old July 7th, 2009, 05:19 PM   #11
BOOSTED96's Avatar
1996 STEEDA
BOOSTED96 is on a distinguished road
I didnt know that either with the tensioner...I think I will go get a new one this weekend since I have definitely driven the car more than 15,000 miles since the blower install
Highly Intelligent Modular Young Gun!
Get off my D1 SON!!
Old July 7th, 2009, 06:05 PM   #12
03 Mustang GT
Cool hopefully i saved you guys the pain in the ass of changing a shredded belt. I'm pretty much a pro at it now haha..yah if you still have your procharger manual laying around it says it right after the head unit instructions.
The tensioner was CAKE to change...one bolt. You dont even hafta take the belt off to do it, just take tension off first. The only prob i ran into was that the previous owner just decided to slap whatever bolt he had in there so i had to drill the bolt hole a little bigger in the brand new tensioner.
You also hafta grind off a piece of the tensioner by the pulley to clear the procharger bracket. I've also heard that if you dont do this the belt will rub on it and eventually shred.
386 rwhp 397 rwtq
Military Crew
AM2-USN
Old July 7th, 2009, 06:32 PM   #13
02sonicGT's Avatar
02sonicGT is on a distinguished road
Reps to the newbie kep2024 for the good info on the tensioner!
Being another sonic blue certainly helps
2002 Sonic Blue GT : Manual, FRPP 3.73's, Ram HDX Clutch, Pypes Violator Cat-Back, Pypes catted X-Pipe, Mach1 Chin, SCT Livewire, PLX SM-AFR as Analog input to LW
Old July 7th, 2009, 07:24 PM   #14
03 Mustang GT
Haha thanks man im just glad i can help out. I wouldnt wish what happened to me over the past week or so (shredded 2 belts in 36 hours, found out my new toy was ghetto rigged) on anyone at all.
To be honest sonic blue wasnt my first choice but im definitely glad i got this one. That color just pops whether its night or day.
386 rwhp 397 rwtq
Military Crew
AM2-USN
Threads Similar to: 03 GT Procharger P1sc bracket question
Procharger P1SC vs D1SC adam0421 2005 - 2010 11 October 24th, 2008 10:57 PM
