Exhaust Manifold Gasket or No?
Old July 6th, 2009, 10:23 PM   #1
JasonT1124's Avatar
2000 Mustang 4.6l
JasonT1124 is on a distinguished road
Send a message via AIM to JasonT1124
Just recently had the heads rebuilt on my car and when i re-installed my MAC Long tubes, I installed a set of exhaust manifold gaskets. I now have pretty nasty leaks from both headers. Are these meant to be installed with a gasket? or without one (like the stock heads)?
Is there a liquid sealant I should be using instead??
Old July 6th, 2009, 11:06 PM   #2
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
i used some gaskets from oreillys and have had no leaks. I dont think i woulld do the liquid. that would be such a mess by the time you fought and fought with it.
Old July 6th, 2009, 11:06 PM   #3
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
stock ones use gaskets and yes you should have gaskets with the headers also. Do have all the header bolts tight? Problems with headers are the header bolts tend to loosen up. you can try red rtv silicone which is high temp. but make sure it is sensor safe
Old July 6th, 2009, 11:46 PM   #4
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
yes check them for the 1st week about every other day and tighten them back, happen to a buddy of mine..had them for 2 weeks and was getting a leak....check it and 2 of the bolts had backed out to finger tight, and one bolt had backed all the way out and was missing.
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old July 7th, 2009, 03:12 AM   #5
JasonT1124's Avatar
2000 Mustang 4.6l
okay. I am going to pick up some new gaskets and redo this. I wonder if using a combination of gasket and RTV is a good idea?
also.... how the hell do you get the EGR tube tight!? thats a friggin nightmare with LTs.
Old July 7th, 2009, 04:04 AM   #6
superbeef1000's Avatar
i did this on mine and it was the only way i could get it to keep a seal
Old July 7th, 2009, 12:45 PM   #7
JasonT1124's Avatar
2000 Mustang 4.6l
Great. It seemed like the best idea to me... now is there a special high temp RTV I should be looking for? I'm sure that stuff burning off can't be good for the O2 sensors... is there one that wont hurt them?
Old July 7th, 2009, 12:47 PM   #8
JasonT1124's Avatar
2000 Mustang 4.6l
Well this is the problem that started this whole mess. I had them on and drove them for about 500 miles and the leak got progressively louder and then I started throwing an O2 code on brand new O2s. So I pulled the headers to try and fix this (also I had put a dent in one becuase of rubbing issues) but when I attempted to reinstall them the leak is so bad it is causing a misfire!
Old July 7th, 2009, 01:08 PM   #9
1999 Mustang GT
Regulator is on a distinguished road
Send a message via AIM to Regulator Send a message via Yahoo to Regulator
Definitely get some new good gaskets. I used locking header bolts on mine when I reinstalled my MAC L/T's, never had an issue
'99 GT FS/FT. Click here for details!
"And I heard a voice in the midst of the four beasts, I looked and behold: a pale horse.
And his name, that sat on him, was Death. And Hell followed with him."
Old July 7th, 2009, 01:14 PM   #10
02sonicGT's Avatar
02sonicGT is on a distinguished road
retorque and use high temp lock-tite to keep them on there. I tightened mine(previous car) from the center out to keep from creating a "bubble" in the middel if the unit flexed while it was being torqued. gaskets are definately a must and I would stay away from combining liquid sealer with the gasket. it will be an awful mess and really should not be needed.
2002 Sonic Blue GT : Manual, FRPP 3.73's, Ram HDX Clutch, Pypes Violator Cat-Back, Pypes catted X-Pipe, Mach1 Chin, SCT Livewire, PLX SM-AFR as Analog input to LW
Old July 7th, 2009, 02:13 PM   #11
GTRACER88's Avatar
GTRACER88 has a spectacular aura aboutGTRACER88 has a spectacular aura aboutGTRACER88 has a spectacular aura about
I had that problem. Go buy the ford metal stock gaskets. It solved my problem!
Super Slow 2011 Grabber blue V6...
Old July 8th, 2009, 12:21 AM   #12
JasonT1124's Avatar
2000 Mustang 4.6l
I found some metal ones that Felpro makes. They sell at Autozone for only $10 and claim to be "redesigned high heat application" so I think I will go that route!
Threads Similar to: Exhaust Manifold Gasket or No?
Exhaust gasket? adam0421 2005 - 2010 11 March 26th, 2009 05:12 PM
2000 Mustang Gt (Intake Manifold Gasket) Murphy-Stone 99-04 0 January 3rd, 2009 07:13 PM
intake manifold gasket or head gasket? rasalibre 5.0 Mustangs 5 November 26th, 2008 06:37 PM
Exhaust manifold gasket blkragtop 99-04 4 November 22nd, 2008 08:04 PM
lower manifold gasket question nolife 5.0 Mustangs 2 April 10th, 2008 12:27 PM
