Help with stereo wiring.
Old January 31st, 2007, 08:26 PM   #1
energiesource's Avatar
energiesource is on a distinguished road
So I've had my old deck for about 4 years, been in about 3 vehicles, so it was time for a switch, so i had the harness from before, i wired it all up
but my speakers dont work...now i heard something before about putting a resistor in the main power wire or something, did i do anything wrong? I mean im not exactly a noob at installing this stuff, its all connected right. So yeah, any ideas?
Old January 31st, 2007, 09:08 PM   #2
lol anyone?
Old January 31st, 2007, 09:18 PM   #3
vichael1's Avatar
vichael1 is on a distinguished road
if you have the mach system, you'll have to rewire your speakers.
CMS Stage I Cams
Tuned by Mike Rousch
Mid-Atlantic Performance
Old January 31st, 2007, 09:20 PM   #4
yeah i have a mach 460 system or whatever
why though?
it worked fine before?
aside from the popping everytime i turned it on
Old January 31st, 2007, 09:40 PM   #5
vichael1's Avatar
from what I've been reading. The factory amps won't respond well to the aftermarket decks without rewiring the whole system. I'm not 100% sure but it's what I've read.
CMS Stage I Cams
Old January 31st, 2007, 09:41 PM   #6
well i heard if you get the harness it should work fine, i heard something about putting a resistor in there, but the one i had when i was uninstalling the old deck, broke off, so i tried installing it without one and the speakers dont work, but i dont see why they shouldnt?
Old January 31st, 2007, 10:57 PM   #7
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
There is no resistor and you can buy a harness but that will adapt the MACH to your H/U but it is not going to sound the same as the factory. It will sound like ass. Whenever I deal with MACH systems at my job we get the customer to rewire the system b/c 90% of the time they come back and say that there system sounds like ass.
BUILD 2 IN PROGRESS
Old January 31st, 2007, 11:31 PM   #8
the system sounds good now
i just get a popping when i turn on the car. meh whatever.
Old February 1st, 2007, 12:47 AM   #9
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
now that i remember I believe that there is a resistor that you do use to get rid of that popping sound but i think that you put it on the remote wire, theres also a certain size you use. Ill check up for you and get back to you tomorrow after i get off of work.
BUILD 2 IN PROGRESS
Old February 1st, 2007, 01:00 AM   #10
1999 Mustang GT
N/A
captain_communism is on a distinguished road
I also have the Mach 460 system in my car and I'm in the middle of putting in a Pioneer head unit. If i rewire the system and use the same stock speakers will it work fine?
Old February 1st, 2007, 01:41 AM   #11
superbeef1000's Avatar
yeh you cant run your new deck into the mach amps yo! you gota run new wires to the speakers or try and find an adaptor that you can run like that i think
Old February 1st, 2007, 07:50 AM   #12
ATLmustang is on a distinguished road
yea it will work fine as long as you bypass the mach amps
Old February 1st, 2007, 11:17 AM   #13
AtxStang's Avatar
AtxStang is on a distinguished road
Get the Metra wiring harness that uses factory amps. Although the Mach system is kinda shitty with aftermarket decks. Its just a lot of cheap stuff combined to make OK sound. You'd be better off installing new everything.
Old February 1st, 2007, 11:46 AM   #14
yeh if you want aps kenwood makes kick ass power for a fair price
Old February 1st, 2007, 11:47 AM   #15
1999 Mustang GT
N/A
Where are the amps located? Are they in the doors by the speakers, or are they all in the trunk? And when I bought the car, the guy I bought it from said it had a powered subwoofer. Is that true? And if it is, where is it?
Old February 1st, 2007, 11:48 AM   #16
you may have to geta hanes manuel to find themi dont know
i would not take them out just re rout with new wires
Old February 1st, 2007, 10:17 PM   #17
mystang0673's Avatar
6.82@100mph 1.45 60'
mystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura about
the amps are in the trunk mounted to the bottom of where the speakers are. you have to let your back seat down and climb in through there to even see them. there is a guard on the other side so you cant tamper with it or see it from outside the car. There should be two amps. and you can buy the harness for the mach systems at autozone. its called the ford premium sound harness. then all you do is match the colors and you are good to go. i have an aftermarket cd player in my car and it sounds great. granted. i did put a new sub in but even before that it surprised me how well the factory ones sounded. and no. the cars do not have powered subs in them. powered subs are anything that the sub,amp,and box are all one thing. the cars do have amps and they are a pain to get to and re wire. because they are nothing like a normal amp.
Threads Similar to: Help with stereo wiring.
New Stereo Shorty's Stang Audio/Video 6 August 5th, 2007 12:50 AM
wiring diagram for stereo exofreeze Audio/Video 7 July 25th, 2007 09:57 PM
Stereo in my 83 GT jake1191 5.0 Mustangs 3 July 6th, 2007 10:57 AM
Stereo HelP! BlackStallion00 Audio/Video 1 June 16th, 2007 09:59 AM
New Stereo? Shorty's Stang V6 Mustangs 70 May 14th, 2007 02:03 PM
