#21 |
Honeybadger is Crazy
I would save up, have my heads worked, and either buy an aftermarket intake, or port my factory to match the flow of the heads. You'll get a lot more form the cams. PM Acmillr, and he can put on the right track as he has been very successful with the 2v engines.
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
#22 |
Baker Jr.
Well I just want it to lope
but HP is always good, Just seeing what I was looking at, I dont want to have to cut the pistons, what cams can I use without cutting?
MMR-Modular Mustang Racing Phils Machining-For your ABS Module Delete Manifold! American Muscle-www.Americanmuscle.com HorsePower By Hermonn-TUNER THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
#23 |
WHOOP!
7.44@95 (1/8)
![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
I didn't have much of a lope at all with my cams. Pretty dissapointing.
![]() Buy my: Nitrous Accessories Diablosport Programmer In The Classifieds |
#24 |
Baker Jr.
Id be pissed, need more duration
#25 |
11.493@121.32
Mellow, I'm surprised you didn't pick up much power with the cams.
Maybe your tune is really on the "safe" side??? |
#26 |
cushmanmotorsports.com
their n/a stage 2's are really really good imo
If It Dont Flow It Wont Go!!!![]() forged pistons,teksid block and a romeo cast cranks for sale.. pm if interested.. selling them for next too nothing |
#28 |
If you want sound get a Crower Cam. This is what I would run in an N/A 2v if I didn't get custom bumpsticks from ACmillr.
Crower Cams & Equipment - What's New Also when you get a chance check out Mofomotorsports.com You can get cams ground by AC through them.
#29 |
WHOOP!
7.44@95 (1/8)
We'll find out next time I get it tuned.
#30 |
Baker Jr.
Do I have to get the adjustable cam gears? Im trying to not have to get those, It says the stock ones arent adjustable but does it have to be adjusted, cant I just adjust the timing at the tuner
#31 | |
Adjustable cam gears are not necessary as you can just grind the tooth (that normally lines it up in a fixed position on the cam) out and manually rotate the cam gear on the cam. The bolt for the cam gear is what holds it in place so there is no issue doing this. The adjustable ones are a lot more convenient however, because they are marked so if you need to move the gear, say 2 degrees, you can move it exactly 2 degrees. It removes a lot of the "guess and check" from the job. |
#32 |
Not valvetrain timing.
#33 |
Baker Jr.
Guess im getting cam gears...Will the 262's be better for the piston and valve clearance
#34 |
That I don't know, I would contact ACmillr like I suggested. He will set you straight on this.
#35 |
Threads Similar to: Cams
| Turbo cams vrs supercharger cams | adrenaline=lifeline | 4V / SVT | 45 | October 31st, 2008 12:20 PM |
| Turbo cams vrs supercharger cams | adrenaline=lifeline | 99-04 | 7 | October 26th, 2008 02:10 PM |
| Thumper cams or Stage II SPR cams. | 07stanggt | 2005 - 2010 | 26 | August 17th, 2008 08:42 PM |
| Comp Cams SPR stage 2 cams on the way!!! | RStrick0352 | 2005 - 2010 | 10 | August 9th, 2008 03:06 AM |
