LinkBack (6) | Thread Tools |
#1
4.6 Engine swap help please..
I have a 1999 Mustang GT,
I am able to purchase a 2003 Mustang GT motor. My shop is telling me that because my 1999GT is setup for a windsor motor, that the 2003 Romeo motor will not fit due to balancing issues and some other stuff... What all will I need to make this swap work? Or is that BS and will it be just as easy as putting in a Windsor motor? Thanks guys. |
will the electrical all be the same or will i need new harness + ecu etc?
if its a complete motor im pretty sure it is a direct swap and u can use all the electrical from the 99
yes it is complete motor he has everything, just was told because it is a romeo and my car was setup for windsor it wouldnt work.
2005 Mustang GT
If they're both 4.6L v8 they will be the same, the difference will be the crank. yours will have an 8 bolt crank where as the romeo will have a 6 bolt (i beleive) which means that your clutch might not match up to the new flywheel. also means that if your getting the motor make sure to get a new flywheel because the one u have now will NOT work.
When building my motor (01 romeo) we put a windsor crank in it, and i had to buy a new flywheel. luckily the clutch worked. wiring wise tho, everything should be the same.
MM + Cleavage member #22
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
everything is a direct swap. there is minor differences with the long block itself, but thats it. the flywheel is a 6 bolt in a romeo, so all you would need is a corresponding flywheel. a stock 01+ clutch kit will be 11in, if you want to stick to a 10.5 kit, you will need to get an aftermarket flywheel that will take either. there are a couple campanies that make a flywheel for either, i got an xtd for mine, it takes either. we put one in a mach as well not too long ago. intake, electrical, etc will bolt up.
ok cool, i already have a 6 bolt flywheel and an 8 bolt flywheel lying around... I wont even need to swap the electrical? Just need different clutch? this has been really helpful guys!
No need to swap any electrical. Just make sure any sensors you get or use are from the 99 if you want to be sure... but everything should all be the same as far as that goes.
Moderator
2010 mustang gt auto
all the electrical parts need to come from the 99. the coil's are diffrent, the IAT is diffrent, the MAF is diffrent, the alt mount's & wiring is diffrent, you guy's already adressed the flywheel issues. basically you'll use the complete romeo motor with intake, alt, & alt mount (you will have to fabricate some alt wiring from both motor's), all the rest of the accesories will have to come from the '99.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2010 GT auto
#10 | |
#11 | |
mm's nitrous mod
2000 mustang gt
He's saying you have to use the coils off the 99, because the 99 wiring harness has a different plug that you cannot use 00+ coils on.
The valve covers are different, so the wiring harness won't sit on the motor the same as it did before, but everything should plug up just fine. Use your old alternator and bracket if you can, and I believe the coolant neck on the intake faces a different direction on the romeo vs. windsor, but they are interchangeable. If the motor is out of an automatic, make sure you put a pilot bearing in the crank.
'99 GT FS/FT. Click here for details! ![]() "And I heard a voice in the midst of the four beasts, I looked and behold: a pale horse. And his name, that sat on him, was Death. And Hell followed with him." |
I just completed this exact same swap in April. I bought an 03 motor and tranny and the swap was pretty smooth. The motor was complete though from wiring harnass to oil pan.... didn't come with the accessories though (ie AC, starter etc) The issues that I ran into were that the alt. bracket is different which I modified with new hole locations and the coolant sensor plug is on the engine harnass of the 99 and the chasis harnass of the 03. Other than that it was plug and play. As was stated previously if you are not putting 3650 tranny in you will need a different flywheel. Any questions PM me. Good Luck
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/130330-4-6-engine-swap-help-please.html
| difference entre 4.6 99 et 4.6 03? - Montreal Mustang | This thread | Refback | April 28th, 2011 05:05 PM | |
| difference entre 4.6 99 et 4.6 03? - Montreal Mustang | This thread | Refback | April 17th, 2011 01:26 PM | |
| difference entre 4.6 99 et 4.6 03? - Montreal Mustang | This thread | Refback | April 16th, 2011 09:52 PM | |
| difference entre 4.6 99 et 4.6 03? - Montreal Mustang | This thread | Refback | April 16th, 2011 06:47 PM | |
| difference entre 4.6 99 et 4.6 03? - Montreal Mustang | This thread | Refback | April 16th, 2011 06:22 PM | |
| difference entre 4.6 99 et 4.6 03? - Montreal Mustang | This thread | Refback | April 16th, 2011 05:31 PM | |
Threads Similar to: 4.6 Engine swap help please..
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 05:33 PM |
| Engine swap? | JSummersPHD | V6 Mustangs | 13 | May 26th, 2008 12:56 PM |
| Engine swap v8 | mustangdevil69 | V6 Mustangs | 3 | November 28th, 2007 12:16 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 07:48 PM |
| 88 5.0 engine swap? | chrismac66 | 5.0 Mustangs | 2 | December 23rd, 2006 11:53 PM |
