fuel pump and injectors
hey ive been thinking a little bit now that my fuel pump is not going to be nearly sufficient for my build. i am going to be putting out well over 700 hp anyone have any ideas about fuls pumps and what size injectors to use? im pretty stumped as to what to use! will the fuls pumps form the svt focus work for this application or will i need something more stout, anyways ant info would be greatly appreciated!
would this be sufficient. and what fuel rails would yall suggest?
http://www.teamjdm.com/shop/product_...roducts_id=152
11.47@120.58
You might be able to get close to 700hp out of the returnless system with a Cobra tank and pump swap and a BAP. I wouldn't try it though if your expecting over 600rwhp. You'll need to swap to a return style fuel system.
If I were you I would talk to the folks at Kenne Belle and see if I could get enough fuel out of the pump you already have by using their Boost-A-Pump. I have heard a few people that use them say they work pretty good. I have aeromotive fuel rails on my mustang and they work nice. Sean Hyland uses 42lb injectors on a 675 horse engine so I would think they would work fine for you.
what exactly is the difference from the return fuel systme to the returnless. i was talking to a guy and he said his buddie is running that same fuel system i linked toearlier with rails and 60# injectors. and his buddie is putting down like 640 hp. and he said it works fine.thanx for the info and any more is greatly appreciated
A Return Style fuel system has a return line going back to the fuel tank. On a returnless system your computer varies the voltage to your fuel pump to vary the amount of fuel pressure to your engine. This eliminates the need for a return line. I would seriously look at a boost-a-pump (http://www.kennebell.net/accessories...boostapump.htm) because it could potentially save you a lot of money. I ended up putting a jdm setup like you are looking at on my '97 cobra and I am wishing I hadn't now because I ended up spending a lot more money that I wanted to. If you don't think that will be enough capacity, then I would still go with the boost-a-pump and get an aftermarket in tank 210 lph fuel pump which would supply more than enough fuel and would still save you money. I don't know for sure what a GT has for a stock fuel pump, but i bet it would be good enough. Also since I am retarded and didn't read your post right, forget what I said about the 42 lb. injectors. I would go with 55 lb., as they would be good for well over 700 horsepower (http://www.rpmoutlet.com/musv8fuel.htm)
what is the point of the return line. is that if it sends to much fuel it can send it back?
Yes, on my 97 cobra I have a return line because my computer doesn't vary the voltage to my fuel pump.
Lethal Performance has a kit but it's expensive plus the additional costs of the 03 cobra pumps and tank.
Here's just some thoughts... - 03 Cobra pumps and tank - 60lb injectors (drivability is very good with them) - Fuel Rails & adapters - Swap out cobra pumps for ford gt or aviator pumps - Send out FPDM to MJchip, he'll modify it for $100. Your FPDM can suffer from thermal meltdown if you try to run two Ford GT or Aviator pumps. - Upgraded -8an fuel line (when pushing 600rwhp) - BAP - MAF like SCT that support that type of power If you search the 03/04 cobra forums like ModularFords and SVTperformance, there is a lot of really good info.
Shaun Strayer Supercharged '99 GT Vert Kenne Bell 1.7
Threads Similar to: fuel pump and injectors
| Injectors and Fuel Pump | scxc15 | V6 Mustangs | 2 | November 3rd, 2007 02:48 PM |
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 09:54 AM |
| fuel pump fuel pressure stuff | JBIGBOOTSY | 5.0 Mustangs | 2 | April 26th, 2007 03:31 PM |
