HID help please?
Old July 22nd, 2009, 05:12 PM   #1
Too Soon, Junior!
asiansensation78's Avatar
03 GT Vert
15:43.28@25.21 Too many naked bitches in the back
asiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to behold
HID help please?
Hey guys, got my HID kit earlier today, my aftermarket headlights take H1 bulbs so that's the kit I ordered... though I'm beyond confused on how everything goes together. Do I just cut apart the rubber grommet that went over the bulb and throw it away? Where do I insert the metal tabs coming out of the HIDs into? I've attached pics to illustrate... thanks for your help!
03 GT - Scrapes on lane markers - Modded
02 Cougar - Able to clear most speed bumps - Some mods
01 Explorer - Parking blocks NOM NOM NOM - Stock
Old July 22nd, 2009, 05:16 PM   #2
zippeewannabee
ZoomZoomMFer's Avatar
06' Mazda Speed6
ZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura about
iTrader: 17 reviews
Send a message via AIM to ZoomZoomMFer
the grey socket should connect to the original headlight connector, and those black and red wires are you power and ground.
not to sure about the blue one
Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount
Old July 22nd, 2009, 05:29 PM   #3
1992 Lx
11.39@119.24
you ordered the wrong one, your supposed to order 9007
Old July 22nd, 2009, 05:32 PM   #4
Too Soon, Junior!
03 GT Vert
9007 is the stock headlight kit, my projectors take H1...
So would the best route to go be just to connect the socket to the OEM plug from the car and just take wire taps and tap the power and ground wires?
Old July 22nd, 2009, 08:33 PM   #5
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
I'm going to venture a guess that they're single xenon bulbs (no high and low beams)?
The gray connector connects to you stock wiring. This plug is common ground. Basically, the middle prong is the ground prong. The side prongs are the power wire for the high and low beams (one side is for low beams and the other side is for high beams).
The original connector to H1 bulb is the other power wire for the high beams. Basically, for standard H1 halogen bulbs the black would be connected in the middle. The red and blue wires would be connected on the outside.
You need to connect the red and black wires (from the last picture) to the wire on the middle prong (black wire here) and the red wire to the side prong for the low beams.
Old July 22nd, 2009, 09:00 PM   #6
Too Soon, Junior!
03 GT Vert
ok got it, thanks guys!
Old July 23rd, 2009, 12:30 AM   #7
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
If it makes you feel any better...my shit doesn't work and I think I have a bad relay
Old July 23rd, 2009, 10:53 AM   #8
2003 Cobra
1StockGT is on a distinguished road
Send a message via AIM to 1StockGT
That kit looks like a pita. My kit was all plug and play, all they way to the relay. Good luck.
Old July 23rd, 2009, 11:04 AM   #9
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Well I just bought a different kit from HID guy. Lifetime warranty so hopefully this one won't be bad like VVME's ()
Old July 23rd, 2009, 12:28 PM   #10
gray8188's Avatar
2003 mustang gt
yr 1965 @ 88mph
gray8188 is just really nicegray8188 is just really nicegray8188 is just really nicegray8188 is just really nice
iTrader: 5 reviews
Ive had 4 kits from vvme with absolutely no problems.. What happened to urs?
i'm pretty sure that when i move into my own place i'm gonna mount an anti aircraft gun on my roof with somebody manning it 24 hours a day.
why?
because it would be fucking AWESOME.[/quote]
Old July 23rd, 2009, 12:57 PM   #11
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Beat's me
I'm sending it to Weems and he's going to see if he can get it to work (to double check to make sure I didn't hook anything up wrong). I went over it 3 times. Everything is hooked up correctly. I'm getting power through the VVME blue connector from my stock harness. Then it dies at the relay. I'm thinking I've got a bad relay.
Old July 23rd, 2009, 01:49 PM   #12
gray8188's Avatar
2003 mustang gt
yr 1965 @ 88mph
iTrader: 5 reviews
Beat's me
Yea if it is give them a call and they should send you out a new one..
why?
Old July 23rd, 2009, 02:41 PM   #13
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
They won't. They said they would require me to send them back the whole harness and they'll refund my money / test to see what parts need fixed. Then they'd send me out whatever needs to be replaced. But it would cost me almost $100 for me to ship it back to them. Ef that.
I already bought a slim ballast kit from HIDguy.net today.
Old July 23rd, 2009, 02:45 PM   #14
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
Sucks man, my vvme single beam kit works wonderfully. And its blindingly bright
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Old July 23rd, 2009, 05:16 PM   #15
Too Soon, Junior!
03 GT Vert
That sucks bro, yea my kit was crazy simple once I figured out that red=power and black=ground haha. 1st one took 3 hours, second one took 15 minutes including me making a sandwich
I've heard both good and bad things about vvme so I ordered from a US based company with a 3 year warranty. Everything works but the spread from my beam is really whack, I get this giant glob of black right in the middle near the driver's side. I think my projectors weren't really made for HIDs
Hopefully I can adjust the lamps to the point where there isn't such a weird scatter anymore, I'll post pics once it's done.
Old July 23rd, 2009, 05:26 PM   #16
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Hopefully Weems can see if it's working (to make sure I'm not a retard). If he gets it working then I'll just resell it no biggy. If it's actually broken; well...that'll suck ass. But I have a new one on the way w/ a lifetime warranty so that'll be good.
Threads Similar to: HID help please?
HID help Megawatts88 Audio/Video 14 March 2nd, 2009 01:13 PM
HID Help mantis3567 99-04 10 February 15th, 2009 01:27 PM
One HID is out Ticket-Me-Yellow V6 Mustangs 9 February 11th, 2009 04:27 PM
hid help energiesource 99-04 11 September 15th, 2007 01:29 PM
HID energiesource 99-04 20 July 29th, 2007 07:11 PM
