#41 |
MM's Official Lucifer
^ I think you're right.
#42 |
1998 Mustang GT
1:34.43@13.86
yeah the cable is already on the fork and on the quadrant. and when i pull the clutch up, i dont really hear a rachet, and when i get under the pedal and look, pull the pedal up with one hand and the quadrant doesnt even adjust, it pretty much stays the same.
![]() "The only way to learn about a car truly is to break something and fix it yourself..." |
#43 |
1992 Lx
11.39@119.24
buy the one i posted earlier, 3 ways to adjust it
#44 |
1998 Mustang GT
1:34.43@13.86
okay ill try it i guess.... but theoretically speaking the stock one should work right? im tryin to save $$$ but i guess if this might do it.
#45 |
1998 Mustang GT
1:34.43@13.86
bump.
#46 |
2011 Mustang GT
12.1 @ 116
So it is as tight as pictured with the quadrant at full release (all the way at the top of the ratcheting)? Are you sure the routing of the cable is right dude? It WILL work correctly if it's all correct man. The main reason people get rid of the stock quadrant is for adjusting a much heavier clutch than stock.
Mods in garage. Built suspension and gears since posted times. |
#47 |
The Mean Green
I had a similar problem when I did my clutch. I put the car in 1st (not running) then pulled up on the clutch pedal. That seemed to pop everything into place and has been working just fine since. Maybe give that a try if you havent yet
#48 |
1998 Mustang GT
1:34.43@13.86
yeah i just tried putting it in first and pulling back on the pedal to adjust and still no luck. its funny because when the cable has a lot of tension like when i have someone push the fork in with a breaker bar and then i tighten the slack at the pedal, the clutch disengages a little bit more... but still not enough to get into gear. but that still isnt right with all that tension even it it was going into gear. wtf.
#49 |
Did you try to slide the cable in and out before you installed it? Wondering if the guy sold you a faulty one, or the wrong year cable.
#50 | ||
1998 Mustang GT
1:34.43@13.86
naw the cable is good i tested it and took it out of the car. the routing is correct for sure, used the haynes manual. i just dont know if the clutch disk is installed backwards. im tryin to get one of those dentist mirrors and look up into the trans through the clutchfork hole thinger and maybe i can see if its in backwards.
EDIT: i was searchin around on google and i found this.
![]() "The only way to learn about a car truly is to break something and fix it yourself..." Last edited by ndfrspd; August 4th, 2009 at 05:13 PM. |
#51 |
1998 Mustang GT
1:34.43@13.86
and this is the clutch and pp i ordered:
garbage or what? heres another issue, but his solution cannot be mine cause i already checked it. Clutch not disengaging/releasing - 1992 Mustang GT, T5 - Ford Mustang Forums
![]() "The only way to learn about a car truly is to break something and fix it yourself..." Last edited by ndfrspd; August 4th, 2009 at 05:22 PM. |
#52 | |
I Poop Entirely Way Too Much
Blown 03 GT
Ive never seem that brand before, and your not saving anythin so why not just get something tried and true?
#53 |
1998 Mustang GT
1:34.43@13.86
yeah that was a dumbass move on my part. ill swap it with another clutch i have.
#54 |
1998 GT suckaaa
4 tickets @ 1 stop
did you figure this out?
Military Crew
Completely stock... I promise. ![]() |
Threads Similar to: clutchfork is tight against pressure fingers... need help!
| cross your fingers for me.........work....... | SilverStang03 | The Clubhouse | 14 | July 12th, 2009 09:29 PM |
| Dyno magic fingers | dr.gonzo! | The Clubhouse | 2 | May 17th, 2009 02:26 PM |
| the fingers back :) | DeMello | The Clubhouse | 3 | June 1st, 2008 02:10 AM |
| I've got my fingers crossed! ! ! ! | Psychojimmy | The Clubhouse | 9 | November 7th, 2007 06:25 PM |
| Tight Tight Pulley | guesswatidrive | General Tech | 2 | April 17th, 2007 09:22 PM |
