clutchfork is tight against pressure fingers... need help!
Old July 28th, 2009, 01:20 PM   #1
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
ndfrspd is infamous around these parts
when i press in the clutch pedal, i cant get into gear and i went to go look under the car with that shield off and i see the fork is really tight against the fingers and its super hard to get the clutch cable off the fork because of the tension.... is that bad? how do i adjust the cable so i can get it into gear?
"The only way to learn about a car truly is to break something and fix it yourself..."
Old July 28th, 2009, 01:56 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
yes thats a bad thing. new intall? the TOB may be installed wrong.
Old July 28th, 2009, 02:08 PM   #3
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
yes it is a new install. but my throwout bearing is good. maybe it wasnt aligned right? i swore that it felt good when i installed it. my buddy just hopped in the car and moved the clutch pedal in and out while i was under it and the clutch fork moves freely on the shaft its just that the cable is really tight and the clutch fork doesnt fully release from the fingers, it rides them. can i just try and slide the fork up and down or do i have to drop the whole trans to fuck with it?
Old July 28th, 2009, 02:15 PM   #4
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
If you can't get the cable off you prolly have to pull the trans, which blows, but gotta do what you gotta do. If everything was/is installed right you may just need a new cable. I hear the adjustable cables are no good cuz they tend to break, but I have one with the Steeda Clutch Adjuster Kit and I like it, it allows you to find that sweet spot in the pedal that you want, and you can adjust it at the clutch fork as well as at the firewall.
Old July 28th, 2009, 02:18 PM   #5
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
dropping the trans SUCKS, but maybe ill wiggle the clutchfork around and see if i can get it into place. so if im correct, the clutch fork should have like 1/4" of space from the fingers?
Old July 28th, 2009, 04:00 PM   #6
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
Did you change the quadrant? Some have two lacations depending on what cable you use.
Old July 28th, 2009, 04:29 PM   #7
1992 Lx
11.39@119.24
my guess is you have the routing of the clutch cable off, theres a very specific way it has to go through the k member
Old July 28th, 2009, 04:35 PM   #8
goren813's Avatar
'00 3.8L & '05 4.6L
Correct, but don't go crazy on getting that perfect. You do not want the fork to touch the fingers while disengaged, but don't want it to be loose floating around inside of the bell housing.
+1, if you replaced the quadrant check into that.
Also a good point. You'll want to follow the same path as the cable was stock.
Old July 28th, 2009, 04:39 PM   #9
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
No you should have just a bit of play in the pedal. Make sure the pressure plate bolts are tight. Then check to see if you installed the clutch disc in the right direction.
TT Build in progress.......
Old July 28th, 2009, 05:16 PM   #10
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
Have you driven the car after the new install? If he's driven the car, I highly doubt the disk is backwards.
If it's really hard to press, I'm gonna say that the cable route is wrong in the K member. It's supposed to go (looking from up top) to the left of the master cylinder, and bend between the radiator and K member. From there you feed it through a little gap near the oil filter and it should find home pretty easily. I'll look under my car the next time I can and get it for you, but it's been raining all day here.
The throwout bearing should LIGHTLY rest against the clutch fingers. There should also be about 1-1.5 inches of freeplay in the clutch. It should ALSO have that heavy top, easy bottom feeling. Like at about half way the clutch 'gives' on the pressing down of the pedal, but don't use that as a means of measurement. Use the cable and stress against the clutch/fork as your measurement.
You should have about 1/8 inch of play in the cable at the fork. Like, with the fork cover off, you can take the cable in your index finger and thumb and wobble it about 1/8th inch up and down.
Mods in garage. Built suspension and gears since posted times.
Old July 28th, 2009, 06:27 PM   #11
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
so heres what happened. the clutch cable got pulled to one side, the firewall side and i dont know how, but something caught inside the cable and it got jammed up and froze. i took it to a shop and the guy had to yank on the cable with a vice. and he said maybe try pb blaster in the cable to free it up, but its so taught even with the pb, idk what to do. id rather not buy a new cable but what do you think?
Old July 28th, 2009, 07:11 PM   #12
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
You need a new cable.
Old July 28th, 2009, 07:14 PM   #13
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
The way I understood the first post I thought he was getting pedal travel it just wasn't releasing.
Old July 28th, 2009, 08:04 PM   #14
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
^ +1
the TOB can be installed incorrectly and will cause the same issue. thats why i thought of that first.
Old July 28th, 2009, 10:27 PM   #15
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
Sorry.
Old July 29th, 2009, 01:36 AM   #16
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
yeah my first post was correct but when attempting to fix it the cable froze, i just got my hands on a new oem cable from this guy off craigslist im gonna put it in tomorrow. also i told the guy what happened to my other cable and the first thing he said was "do you have longtubes?" YES. of course, the clutch cable was too close to the tubes and melted the inside causing the cable to freeze up. DUH. i feel like a dummy.
Old July 29th, 2009, 02:46 AM   #17
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
Take the cable of and push straight in on the end of the clutch fork. Mine likes to pop off the pivot ball and it feels just like you described. If so it should pop on a little more.
Edit just read your last post.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old July 29th, 2009, 11:59 AM   #18
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
i put a new cable in this morning and its routed correctly and one end is connected to the pedal at default setting and the other end of the cable wont even reach the clutch fork... this only leads me to believe something in the trans was installed wrong or the pedal was fucked with. heres pictures to confirm. more pictures are here: clutchfork pictures by cttblakeman - Photobucket
Old July 29th, 2009, 12:11 PM   #19
1992 Lx
11.39@119.24
that looks right to me, theres supposed to be tension on the clutch fork, pry it forward with a prybar then throw the cable in
Old July 29th, 2009, 12:22 PM   #20
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
are u serious? thats what i had to do to get the cable off, pry it forward and unhook it. everyone is saying that theres supposed to be 1/8" of space inbetween the bearing and fingers...
Threads Similar to: clutchfork is tight against pressure fingers... need help!
cross your fingers for me.........work....... SilverStang03 The Clubhouse 14 July 12th, 2009 09:29 PM
Dyno magic fingers dr.gonzo! The Clubhouse 2 May 17th, 2009 02:26 PM
the fingers back :) DeMello The Clubhouse 3 June 1st, 2008 02:10 AM
I've got my fingers crossed! ! ! ! Psychojimmy The Clubhouse 9 November 7th, 2007 06:25 PM
Tight Tight Pulley guesswatidrive General Tech 2 April 17th, 2007 09:22 PM
