2000 GT CONVERT
lifters
if i changed all my lifters/ lash adjusters do they have to be adjusted or are they alright by just putting them in
You don't have lifters... Its an overhead cam engine, not a pushrod engine.
![]() 99' Rio Red Mustang GT: --My Garage-- Check garage. Vortech V-1 intercooled running 9lbs of boost Life= eat, lift, eat, eat, eat, sleep, repeat
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Just lube them up with some oil or similar, drop them in and go. It prolly wouldnt hurt to run it for a bit at idle though, let it sit for a bit, then fire it up again. Sometimes theyll have air in them that needs to be bled out and that usually does the trick w/o having to fool with any "pre build" steps.
2002 GT
99.99@999.9
i soaked my lash adjusters in oil before i put them in, but just use some builders grease and lube them up really well and throw them in
2000 GT CONVERT
well i meant lash adjusters thats what the book calls em
2003 mustang GT
15.2@93.56
im having a loud taping sound coming from the passenger bank of my 03 gt the has only 58,000 miles... noise started right after an oil change any idea what it may be?
2000 GT CONVERTIBLE
man this thread wandered off fast!
tapping after oil change may be caused by not gettin enough oil back in or maybe some crud blocking an oil passage
![]() silvermustangsregistry#0711 |
Threads Similar to: lifters
| gap on lifters?? | worlz08 | 5.0 Mustangs | 4 | June 12th, 2008 09:32 PM |
| Lifters, which ones to buy? | burnout5.0 | 94-95 | 14 | April 11th, 2008 01:06 AM |
| Which lifters ??? | 86_Notch | 5.0 Mustangs | 4 | March 23rd, 2008 12:56 PM |
| lifters | terribleonexx88 | 5.0 Mustangs | 9 | March 11th, 2008 08:37 PM |
| Hydraulic Lifters | ssajdowitz | V6 Mustangs | 2 | October 30th, 2006 11:23 PM |
