bore??
Old August 8th, 2009, 06:55 PM   #1
Boostang's Avatar
1997 Mustang GT
11.01@128.32
Boostang will become famous soon enough
Send a message via AIM to Boostang
bore??
if i were to bore my block .030 over what gains would i be getting off that.. pros? cons?
thanks
If It Dont Flow It Wont Go!!!
forged pistons,teksid block and a romeo cast cranks for sale.. pm if interested..
selling them for next too nothing
Old August 8th, 2009, 07:21 PM   #2
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
thanks
Thinner Cylinder Walls,More Heat,A Slightly Bigger motor
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old August 8th, 2009, 07:28 PM   #3
Boostang's Avatar
1997 Mustang GT
11.01@128.32
ok so do u think i should go with that or a high compression big bore 4.6 with spray?
Old August 8th, 2009, 08:35 PM   #4
mikestang's Avatar
2001 mustang gt
12.89@104
mikestang is an unknown quantity at this point
I have heard of people having some problems with doing a big bore with our block, b/c you have to sleeve it and there is problems with that. MMr would not do a big bore uless you buy there block, which i think is the boss 302 block. But there are a few around that claim they havent had any problems doing a big bore with a stock block so I guess its up to chance.
my $.02 is stroke it for extra torque down low, with 11.1 cp, and some stage 2 or 3 heads and cams and rock it out. with the cp raised you will have to dutune it for pump gas but will fine, but you can put a race gas tune in and raise the timing, probably for another 50 hp for when you want to go to the track or bust some ace on the street, good luck bro
Old August 9th, 2009, 12:06 AM   #5
y2k02's Avatar
02 Mustang GT
9.91@133
y2k02 has a spectacular aura abouty2k02 has a spectacular aura abouty2k02 has a spectacular aura about
here is my stock stroke 305ci big bore.
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
http://i160.photobucket.com/albums/t...t/DSCF5654.jpg
http://i160.photobucket.com/albums/t...2gt/IMG060.jpg
Old August 9th, 2009, 12:13 AM   #6
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
^ show off
Old August 9th, 2009, 12:39 AM   #7
mikestang's Avatar
2001 mustang gt
12.89@104
dam that looks bad azz
just curious is there problems with something leaking or cracking on a 4.6 block when you sleeve it, i know i heard that somewhere or another
Old August 9th, 2009, 02:18 AM   #8
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
there have been issues with a few people of sealing on a wet sleeve. and there have been a few that have had sleeve fastening issues with a dry sleeve. it depends on who does it (experience), how much power you have, the way the block is prepped, etc.
Old August 9th, 2009, 09:18 AM   #9
y2k02's Avatar
02 Mustang GT
9.91@133
You can get the FRP Big bore and have no issues. The dry sleeved blocks are not good for a lot of boost due to the thinner walls. The wet sleeved blocks are good for lots of boost providing they are installed right. I have about 300 miles on mine right now driving it like I stole it with no issues. The power feels as good at 10psi as it did at 16psi and makes more torque than it did at 16psi.
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
Old August 9th, 2009, 10:03 AM   #10
mikestang's Avatar
2001 mustang gt
12.89@104
good info, thanks
Old August 9th, 2009, 05:14 PM   #11
Boostang's Avatar
1997 Mustang GT
11.01@128.32
link to the frp big bore?
Old August 9th, 2009, 08:26 PM   #12
y2k02's Avatar
02 Mustang GT
9.91@133
They also make a aluminum block, but it is like $3700.
Ford 5.0 DOHC Aluminum Big Bore Block
Here is a good read. The iron big bore is around $1700.
324 C I Boss 5 0 Technician Photo
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
Old August 9th, 2009, 08:52 PM   #13
Boostang's Avatar
1997 Mustang GT
11.01@128.32
9.5 compression ratio?? can i boost and spray with that compression?
Old August 10th, 2009, 06:00 PM   #14
y2k02's Avatar
02 Mustang GT
9.91@133
yes
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
Old August 10th, 2009, 06:34 PM   #15
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
I think the stock blocks are around 9.5:1 if I'm not mistaken
Threads Similar to: bore??
stroke and bore? kotten148 2005 - 2010 6 October 27th, 2008 10:16 AM
4.6 big bore? product1620 96-98 7 August 31st, 2008 12:39 AM
Short stroker, large bore/ Long Stroke, small bore 331STANG 5.0 Mustangs 20 July 23rd, 2008 05:28 PM
bore gooberhead320 V6 Mustangs 5 May 11th, 2008 05:02 PM
bore Iownastang 5.0 Mustangs 11 February 5th, 2008 10:18 PM
