Which route for power?
Old August 11th, 2009, 10:51 PM   #1
MustangGT06 is an unknown quantity at this point
What would be better performance and reliability-wise? I either want just a 125 shot of nitrous or a 100 shot and some HP stage 2 nitrous cams. I could care less about idle sound with cams, i am just looking for the most reliable route to power out of these options.
Old August 11th, 2009, 10:55 PM   #2
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
100 with cams. Would give you a better baseline power to spray on i think. More all around fun.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old August 12th, 2009, 12:24 AM   #3
1999 Mustang GT
quiksilver225 is on a distinguished road
what are your long term goals? where do you see your car in 5 years? 10?
regardless, if you decide to spray be sure to take all the precautions with it. Get a window switch, WOT, a tune, etc. it wont hurt to get a bottle warmer either. Plus with the warmer your getting a more reliable pressure for each shot with more consistent results. warmers are a great buy!
When looking at cams you might wanna consider what your doing in the long run. if you plan to do top end work(heads, porting, intake, etc) or going FI you may want to hold off and get the cams after you do major upgrades and then buy cams that can take advantage of everything. As far as the set of cams go i always like the idea of a custom grind designed specifically for your car and mods.
BBK CAI, March UDPs, Eibach Sportline Springs, MM C/C plates, Koni Yellows, Centerforce DF clutch, FRPP Billet Flywheel, B&M Pro-Ripper Shifter, BBK ceramic LTs, BBK catted X-Pipe, SLP LM1, EBC rotors, 4.10 FRPP gears
5.4 4V coming soon
Old August 12th, 2009, 12:27 AM   #4
DSG40TH2V is on a distinguished road
i agree with above. spray and cams would be your best bet if you have the money. i have jlt, exhaust, gears and a 125 shot and im trapping 115 in the 1/4. my tune is safe, 10.5 a/f, and the car rips on the bottle. it gets addicting tho. only thing i would recommend is changing your gears tho. 4.30s is steep for nitrous. with my 4.10s, im hitting rev limiter at the top of 4th with 26" tires ..
12.777@115
JLT;Prochamber;Magnapacks;4.10s;31 Spline;Spec Stage 2+;Predator;NX 125Shot .. Quest for 11s
Old August 12th, 2009, 12:31 AM   #5
Moderator
casper gt's Avatar
2010 mustang gt auto
casper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud of
& he's a manual^ on an auto, spraying 125 you'll probubly want to look at 3.73's (mabie even 3.55's)
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2010 GT auto
Old August 12th, 2009, 12:33 AM   #6
1999 Mustang GT
4.30 can be done, but your gonna wanna look into slicks for the track. otherwise, prepare to spin 'em
5.4 4V coming soon
Old August 12th, 2009, 12:33 AM   #7
ajm
Depends on what you wanna do. If it were me id do
xxx nitrous
or
xxx nitrous + cams + valve springs
Basicaly if you do cams, do the springs too; for example what good is cam that will make power to 6200 but springs that crap out at 5500?
The whole gears thing at the track casper will be able to help you out with.
Old August 12th, 2009, 12:36 AM   #8
1999 Mustang GT
have you ever seen the guy at Keystone with the orange '04? he runs 4.30s, some bolt ons, and slicks. has a manual and last time i was there(last summer) he was in the high 12s... just curious if you know the guy...
5.4 4V coming soon
Old August 12th, 2009, 12:42 AM   #9
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
xxx nitrous
or
My dyno sheet shows this exactly!!! Do springs!!! at 5900-6300 rpms my dyno sheet looks like ~~~~~~~. My centrifugal blower and blower cams make power up top yet im stuck with stock springs. Bad decision on my part and shitty recommendation by a shitty shop with a shitty tuner thats just an overall shitty place (HOUSTON PERFORMANCE).
Old August 12th, 2009, 12:42 AM   #10
BakerFX4's Avatar
iTrader: 14 reviews
Oh but dont let the ~~~~~~~ fool ya.. she will run! LOLOLOL!!
Old August 12th, 2009, 12:44 AM   #11
im not saying 430s cant be done. all im saying is im crossing the traps on rev limiter. i hit 6300 maybe 15 ft or less from the end on 26" tires. He could probally get away with 28" tires but id def consider 3.73s or atleast 4.10s.
12.777@115
Old August 12th, 2009, 12:45 AM   #12
and im confused. is he an auto ?
12.777@115
Old August 12th, 2009, 12:45 AM   #13
Moderator
casper gt's Avatar
yeah that's our token stick guy . his name's Ed. he's on 4.10's & full bolt on's though & side-step's at 6K to get those number's.
2010 GT auto
Old August 12th, 2009, 12:46 AM   #14
Moderator
casper gt's Avatar
yeah the o/p's an auto.
2010 GT auto
Old August 12th, 2009, 12:48 AM   #15
Moderator
casper gt's Avatar
not on an auto with a 125 shot (unless you can spin to 10K ). we only have 3 gears & the spread doesn't work.
2010 GT auto
Old August 12th, 2009, 12:50 AM   #16
well nevermind on my part. real men bang gears auto guys take it in the rears .... just playing, but im not an auto guy lol
12.777@115
Old August 12th, 2009, 01:17 AM   #17
1999 Mustang GT
i could swear he said he had 4.30s... but like i said it was a while ago. guy was i dunno... 40ish. clean car. im sure it was an '04 cause i was looking at his dash to see if i could use the plastic piece from an '04 to put a double DIN sized monitor in my dash, lol. nice guy though.
5.4 4V coming soon
Old August 12th, 2009, 01:26 AM   #18
Moderator
casper gt's Avatar
yeah, it's an '04 (orange give's it away, only avalible in '96 & '04).
2010 GT auto
Old August 12th, 2009, 01:30 AM   #19
1999 Mustang GT
exactly! ill likely be giving you a call late this week for that x-pipe. i was just out 28 yesterday cutting down trees on my buddy's new property, but didnt have time to swing by...
5.4 4V coming soon
Old August 12th, 2009, 01:38 AM   #20
Moderator
casper gt's Avatar
no problem, call anytime.
2010 GT auto
Threads Similar to: Which route for power?
Best route and cost effective? Haseeb718 5.0 Mustangs 16 November 12th, 2008 12:40 PM
Need Suggestions on Route to Take (modifications) Stang4life82 V6 Mustangs 12 July 8th, 2008 01:20 PM
Quick Route To 560rwhp? IronStomach 2005 - 2010 7 December 20th, 2007 12:01 PM
