Kenne Bell Supercharger
I'm really considering gettin the kenne belle 2.1L Kit for 6-14 psi. The kit comes with chip, injectors, boost a pump, bypass valve and recommends 1 heat range cooler spark plug. Are there any more accessories that I may need to purchase? If so give the accessory and reason why....thanks for your help in advance.
Whatever it originally would be
Boost and air/fuel gauges-so you know what your runnin duh
![]() MILITARY CREW ANTI ILLEGALS CREW FOUNDER |
I already knew that.....other than that...I'm talkin about other components i.e. fuel pump upgrade maybe?
Yea fuel pump, what year is your car?
And if you dont want the injectors they give you, give some higher flowing ones
2000 GT
If you are getting the complete kit and going for 9 psi you will be good to go.
Just get the plugs, and a CAI. I used the one they sold just to make it easy. You would probably be wise to get it dialed in at a dyno though. A 75mm tb would complement the blower well also. But not required.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
2004.
thx..I already have 70mm throtte body..my other question is will the stock engine and internals hold up to the additional horsepower...I don't plan on running anything outrageous...probably no more than 9 psi...
Yea they will handle it, just make sure its tuned right and you have all the essential things listed, and you should be good.
9 would be the best. I would start to save up for a motor after that so you can run a crazy amount of boost
My Car- 2004 Mustang GT Her Car- 2011 V6 Auto Premium Saving up for either a 2009 Shelby GT500 or a 2011 5.0...Can't decide! |
Thats wat I plan to do.I will be in Iraq by January if not sooner for at least a year so I will save up then....What motor would be good to run boost over 9 psi for my mustang?
2001 Mustang GT
Depends on how much boost you plan on ultimately pushing. You could go with a forged shortblock with stock compression and be okay for awhile, but if your goin with crazy amounts of boost (BTW 14 psi isn't crazy) go with a lower compression ratio, but I would definitely get a new shortblock past 12-13 psi, especially if you plan on running the car hard.
2001 Black Mustang GT 4R70W - MMR Street Mod 600 Shortblock, Patriot Stage 2 Heads, Modular Head Shop Stage 2.5 N/A Cams, Full Bolt Ons |
#12 | |
1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
I have seen people Run up to 12 Psi On a Bone Stock motor with no issues,As long as you stay under 425Ish to the Rear Wheels you should be fine with a stock bottom end,Unless you want to Exceed 400 RWHP Then you might want to look into a Complete rotating assembly.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
#13 | |
1997 SVT COBRA
1996 Mustang V6
2000 GT
At 9 psi, with a 70mm tb and the cai from them i was at 405 hp on a conservative tune.
So don't go past 9 psi till you forge up, its just playing with fire. I picked up some hp from the 75mm tb don't remember how much though. But you would be pretty much exchanging it. You would buy a new one, and sell your old one on ebay/classifieds for a little less. Thats what i did. If you want to get closer to the 450 mark, then get supporting mods (not required, but fun). Like an aluminum drive shaft, Long tubes, cams.
KB'd GT
If you ever plan on more than 9 psi, or think you might forge the block, it would be better to buy the tuner kit and better components. Get an X3, 60lb injectors, cobra gas tank, etc. If you are going to stay at 9psi then the kit is ok. Make sure to run a wideband because the KB tunes are hit or miss.
buy mine... it has everything that you need in addition to a JLT RAI & BBK 75mm TB... it's basically in brand new condition... 1500 miles... never raced or beat on the car while the blower has been on there--too afraid that I was going to blow something with 422 rwhp/425 rwtq.http://www.moddedmustangs.com/forums...c-s-c-kit.html... tell me what you think
2003 Cobra Stock as of now... |
I would but I won't be buying until mid September...right now I'm just doing the research so that I don't have any surprises...
Threads Similar to: Kenne Bell Supercharger
| kenne bell supercharger | mustangrebuilder | 2005 - 2010 | 13 | June 13th, 2010 07:17 PM |
| kenne bell supercharger! | billabongsmp | 94-95 | 19 | July 24th, 2009 05:52 PM |
| Kenne Bell supercharger! | 1997Stang | 96-98 | 39 | February 6th, 2008 06:02 PM |
