battery relocation
Old August 12th, 2009, 04:43 PM   #1
Ryguy33's Avatar
2002 Mustang Gt
3 seconds......flat
Ryguy33 will become famous soon enough
Send a message via AIM to Ryguy33
battery relocation
is it better if the battery is where it is now, or in the center of the trunk.. for canyon driving?
Mods = stuff to make me take corner faster
Old August 12th, 2009, 04:45 PM   #2
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
The trunk is better for weight distribution. And you generally want it to be on the passenger side to help even out the weight distrobution for you being in the driver seat.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old August 12th, 2009, 04:47 PM   #3
Ryguy33's Avatar
2002 Mustang Gt
3 seconds......flat
^ oh yea i never thought of that.
Old August 12th, 2009, 09:21 PM   #4
JayC's Avatar
2001 Mustang GT
JayC has a spectacular aura aboutJayC has a spectacular aura aboutJayC has a spectacular aura about
My car has a drag set-up but it's much the same. Unless you got to a track that techs you won't need the cut-off switch. Here's some pics........
tuned by SPEEDY DYNO
12.41 @ 109 mph w/ CMS stage II cams
11.13 @ 122 mph NX 150 shot
Launch soft, shift slow, rev low, stay slow
Old August 12th, 2009, 09:50 PM   #5
MustangGT06 is an unknown quantity at this point
I have a battery relocation as well, the girlfriend bought it for my birthday. That with the swaybar gone gave me uch better weight transfer.
Old August 12th, 2009, 10:48 PM   #6
1998 mustang gt vert
98stanger is on a distinguished road
Send a message via AIM to 98stanger Send a message via Yahoo to 98stanger
or u can do what i did and bought a 17lb brail battery and mount
check out my garage for info
Old August 12th, 2009, 10:53 PM   #7
JayC's Avatar
2001 Mustang GT
Not quite the same result
Old August 13th, 2009, 05:04 PM   #8
Novanutcase's Avatar
2003 GT
Novanutcase has a spectacular aura aboutNovanutcase has a spectacular aura aboutNovanutcase has a spectacular aura about
I've been meaning to do this but haven't gotten around to it so maybe you can do it and tell me what you think:
If you put the battery in the trunk, it'll give you a little more rear wheel traction as long as you're going straight this is a good thing but if you're going to be canyon carving then it might work better if you place the battery on the passenger side under the rear seat. This way the weight is in between the axles which will help give you better weight distribution along with being able to take advantage of the polar moment of inertia. Another plus, although small, will be that you'll have to run less wire which means a little less weight in the car.
John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles
Old August 13th, 2009, 06:09 PM   #9
1997 Mustang GT
Faster than an s4
John
Not quite. While your head is in the right place, you are off a bit. The issue is that you want the best center of gravity. You got that part right, the problem is, you don't get that right by putting stuff closer to it. You try to cancel out weight that you can't control. You want to use your battery like balast.
The goal of balast is the place it as far out as possible, so you get the most leverage on the center of gravity as possible, while having the smallest amount of weight added. Ideally, the best place for your battery would be about 2 feet to the side and 4 feet back from the passenger tail light. Completely out of the car. That would end up canceling about 50-60 pounds off the front of the car. The problem of course, thats impossible.
So, when in your car, the ideal center of gravity is in the absolute middle of the car front to back and side to side. And at the center of the axles height wise. This will lead to totally flat movement and weight transfer. This is for the twisties obviously. To do that, you place the battery opposite the driver to event he weight side to side. Then you place it as far back as you can, to help balance out the weight of engine.
Its like a see-saw. You don't balance the fat kid on the end by standing in the middle, you sit as far back as you can so you don't have to work as hard to lift his fat ass. ideally you'd put him in the middle, but you can't. Cause he is bolted to the frame there, so you do what you can.
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
04' PI Motor
Old August 13th, 2009, 11:39 PM   #10
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Threads Similar to: battery relocation
Battery Relocation F8L GT 99-04 7 October 11th, 2008 12:19 AM
Battery relocation whitemustang02 Audio/Video 2 February 19th, 2008 11:39 PM
Battery Relocation dgt_mustang V6 Mustangs 17 December 21st, 2007 11:00 AM
battery relocation onewinner 5.0 Mustangs 13 May 29th, 2007 03:17 AM
Battery Relocation 98vortech Modular Mustangs 0 September 14th, 2006 06:23 PM
