02 GT suspension!! HELP!
Old August 14th, 2009, 11:12 AM   #1
Blitz34's Avatar
13.907@99.85
Blitz34 will become famous soon enoughBlitz34 will become famous soon enough
iTrader: 11 reviews
Send a message via AIM to Blitz34 Send a message via Yahoo to Blitz34
Exclamation
A question on the stock shocks/struts, I have an 02 GT and when Im going down the road, my car has really rough ride, and shakes pretty bad. also when I catch a bump of any kind it sounds like the springs are really creaky/ squeaky like a box spring matress for example : you jump on and the springs bounce abck and forth making a high pitch squeaking noise. what could cause this??
Other than that, my suspension or steering creaks when I turn my wheel to the Right only not the left?? Like when I pull into my driveway something creaks only when I turn right. never left??? WTF???
need help guys.
Old August 14th, 2009, 11:49 AM   #2
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Sounds like you are in need of some joint lube at the very least
This will cause LOTS of squeaking, but not a harsh ride. Is your car lowered (not sure from sig pic). Stock shocks/struts can fail pre-maturely on lowered springs.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old August 14th, 2009, 11:54 AM   #3
Blitz34's Avatar
13.907@99.85
iTrader: 11 reviews
Jazzer
I havent lowered it myself since I got it, however I do not know what was done before I bought it. Im not sure how to tell really. It doesn't look any lower than the Sixxer we also have at the house which is the same year model.
Its kind of annoying. How could I check the shocks, struts, and other steering? What could I look for as an indication of failure/ wear?
Old August 14th, 2009, 11:54 AM   #4
Whatever it originally would be
Seabee's Avatar
05 Saleen #824
Fast as fuck
Seabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to behold
Send a message via AIM to Seabee
Also on the springs, are your isolaters out that you know of? that coulde be a possibilty.
MILITARY CREW
ANTI ILLEGALS CREW FOUNDER
Old August 14th, 2009, 11:57 AM   #5
Blitz34's Avatar
13.907@99.85
iTrader: 11 reviews
I dont know much about suspension components so Im not even sure what those are to be honest. I do my own work but, as Im on my third 99-04 car, I have only done electrical work on them.
Old August 14th, 2009, 12:01 PM   #6
Seabee's Avatar
05 Saleen #824
Fast as fuck
Above and below the spring theres rubber pieces, as to not cause squeeking and noises. Youll see those on there. If everythings stock there probobly there.
MILITARY CREW
Old August 14th, 2009, 12:05 PM   #7
Blitz34's Avatar
13.907@99.85
iTrader: 11 reviews
Its stock as of my knowledge. I will take a look though. I HATE noises other than RPM's and my exhaust as I pass those little fart cans.
Old August 14th, 2009, 12:08 PM   #8
Seabee's Avatar
05 Saleen #824
Fast as fuck
But like jazzer said lube up the parts. Its an 8 year old car, it could have those problems.
MILITARY CREW
Old August 14th, 2009, 01:10 PM   #9
Abyssinian of AX
'02 Saleen
19.34@42.259
Take your ride to a good local shoppe and have them take a peek at it
Odds are, there is a loose suspension component or lube-job needed.
Jazzer
Old August 14th, 2009, 02:58 PM   #10
Blitz34's Avatar
13.907@99.85
iTrader: 11 reviews
Just got back home with some multi purpose grease so Im going to take a peak around and try and free up some friction.
Old August 14th, 2009, 06:08 PM   #11
Abyssinian of AX
'02 Saleen
19.34@42.259
You will need a grease-gun to lube the ball joints and likely at least some of the issue you have
Jazzer
Old August 14th, 2009, 06:34 PM   #12
Blitz34's Avatar
13.907@99.85
iTrader: 11 reviews
Yes i have a grease gun. Unfortunately this doesnt solve my rough ride or the shaking steering wheel.
Old August 14th, 2009, 06:37 PM   #13
Blitz34's Avatar
13.907@99.85
iTrader: 11 reviews
Also i tried to read up and couldnt figure out where the proper place to put a floor jack would be to lift either end of the car for a better look. Where do i place it?! Not suppose to use differencial and dont know of a front end place either.
Old August 16th, 2009, 12:13 PM   #14
Blitz34's Avatar
13.907@99.85
iTrader: 11 reviews
Anybody? Help??
Old August 16th, 2009, 03:24 PM   #15
1999 Mustang GT
quiksilver225 is on a distinguished road
ive jacked my car up by the pumpkin a hundred times or more. in the front i used to jack it up by the k member, but now that its lowered cant get a jack under there lol. when you jack it up on the side obviously use the frame and do it so you can place your stands closer to the front of the car. you dont want the weight of the motor pulling down on the frame, this is how frames bend... same thing when lifting the front end. put the stands close to the front of the car. Dont ever work on a car supported by a jack only. always get some jack stands under it before YOU get under it.
BBK CAI, March UDPs, Eibach Sportline Springs, MM C/C plates, Koni Yellows, Centerforce DF clutch, FRPP Billet Flywheel, B&M Pro-Ripper Shifter, BBK ceramic LTs, BBK catted X-Pipe, SLP LM1, EBC rotors, 4.10 FRPP gears
5.4 4V coming soon
Old August 16th, 2009, 03:30 PM   #16
neverfastenough1's Avatar
To jack the whole rear I use the diff, and to jack the whole front I use the k-member. Like above, now that its lowered I drive half way up my ramps to get the jack under the k-member when I need to pull the wheels.
Old August 16th, 2009, 03:46 PM   #17
1999 Mustang GT
same here. i have to drive it onto blocks.
5.4 4V coming soon
Old August 16th, 2009, 09:17 PM   #18
Blitz34's Avatar
13.907@99.85
iTrader: 11 reviews
Okay, so Im clear with the whole flow jack thing, but in relevance to the original topic, I checked out my suspension as i did my oil change, and I dont see a single grease joint, or any place I can use a grease gun to quiet the squeaking.
does anybody have some pictures of the exact places your suppose to grease?
seriously I dont see anywhere that I could, I cant even insert anything into a boot.
Old August 16th, 2009, 09:18 PM   #19
Blitz34's Avatar
13.907@99.85
iTrader: 11 reviews
and another note, ill have pictures coming where someone decided to half ass throw my bumper back on and such, didnt even re-attach the fender correctly so yeah any opinions on if i need a new bumper let me know.
Old August 16th, 2009, 09:33 PM   #20
Abyssinian of AX
'02 Saleen
19.34@42.259
You should have a zerk fitting on your lower ball joint, I have uppers as well , and is probably the source of your squeaking.
Jazzer
Threads Similar to: 02 GT suspension!! HELP!
Steeda Suspension- Suspension Questions MustangJon255 2005 - 2010 22 June 2nd, 2010 05:43 PM
Suspension? blackmustang285 2005 - 2010 6 September 16th, 2008 09:02 AM
Need Suspension temple30 5.0 Mustangs 14 September 3rd, 2008 06:29 PM
suspension ?s mustangsoldier 5.0 Mustangs 8 August 31st, 2008 05:39 PM
new suspension dadesolja General Tech 3 June 12th, 2007 01:45 AM
