tork tech
okay is it worth doing the conversion to slap an eaton on my car with the new torch tech adapter... i have full drag suspension i jsut want to get into the 11's but i dont want nitrous. any opinions apprciated
I'm cool..
Centrifical is cheaper. Ajm got his for under 2k. Or around that price.
Super Slow 2012 Grabber blue 5.0...
2003 mustang gt
yr 1965 @ 88mph
![]() ![]() ![]() ![]() iTrader: 5 reviews
Go centri the eatons are very unefficient and for the money you could get allot more power.. The only thing i really like about them is it would be really interesting to have a nice sized whipple on a built 2v..
![]() i'm pretty sure that when i move into my own place i'm gonna mount an anti aircraft gun on my roof with somebody manning it 24 hours a day. why? because it would be fucking AWESOME.[/quote] |
The M112 Eaton based Tork Tech kit, is producing remarkable power. At 9 pounds they are at about 415-420. (in my opinion, pushing your luck), and at 19 pounds of boost on a built 2V with Fox Lake heads and cams, they hit 591 rwhp.
If you want to go beyond that point, swap in a TVS 1900 which bolts on the kit. 735 rwhp... |
#5 | |
2003 mustang gt
yr 1965 @ 88mph
I have looked into this and found out that an M112 is not worth spending that much money on. Just buy a Kenne Bell meant for your stang.
#7 | |
2003 mustang gt
yr 1965 @ 88mph
Imagine the tork tech kit on a built 2V, new TFS heads with either a 3.4 whipple or 2.8 kennebell mammoth kit
02 Mustang GT Stock
2003 mustang gt
yr 1965 @ 88mph
With the tork tech manifold it is to my understanding we can use any supercharger they can use..
#11 | |
02 Mustang GT Stock
2003 mustang gt
yr 1965 @ 88mph
Yep its cool.. But honestly for that amount i could do a 4v swap and have a much better base..
#13 | |
The other thing to look at, is the intake plenum. On a KB it is flat as a pancake, and really restricts the air, on the TTI, the plenum is HUGE, so it moves a ton of air, cooling it even more. |
Some results with the TTI kit using the M112 at 18 pounds. 3600 pound car including driver.
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
not a fan of the eaton here. I say a 2.6L Kenne Bell or a Centri.
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
OK. Freedom of choice. One more caviat. Lets say you sell the car or drop in a 5.4L. For about $100.00 bucks you buy a set of 5.4L adapter rails, and the entire kit drops onto a 5.4L no need to spend another 6-7 grand to put a S/C on the new rig.
2003 Mach 1
12.12@112.69
but why swap to a 5.4?
Fuck It
2001 Mustang GT
8.9@78
![]() iTrader: 2 reviews
And dont you have to get a cowl hood with that sense the S/C is raised up more? Add the cost of hood/paint.
Fire it up, burn it down.
or cut a hole in your hood and use their extended hood scoop to cover the hole. 200$ for hood scoop
02 GT
Still gotta paint the thing, and cutting the hole and sealing it correctly, without jacking up the final appearance and finish is something to think about.
If you have accesss to a Magn. MP112 for a good price, that might be the way to go. If it's all from scratch, I say go with the KB. BTW, I know people are split on this topic, but: The Magn. MP112 will be louder than the stock cobra eaton. It has less restriction on the exit port. This allows better power, but it will scream like a Biatch. Might be harsh for a DD, then again like I said, some people LOVE the whine and can't get enough, others don't. The Stock SC was restrictive to somewhat control the noise, but aftermarket SC's all bets are off in the name of power...
![]() 02 2v 5sp- 9lb KB 2.1L I/C, 90MAF, 75mmStack TB, FLSFC's, Magnaflow C/B, NT555R's, MGW shift, Black Sabbath |
Threads Similar to: tork tech
| Tork Tech supercharger kit? | pber13 | 99-04 | 27 | November 24th, 2009 01:17 PM |
| ? on the tork tech manifold.. | gray8188 | 99-04 | 17 | April 15th, 2009 04:40 PM |
| Tork Tech build-up | wishIhada5.0 | 99-04 | 41 | December 29th, 2008 03:21 PM |
| Tork Tech? | Hawaiianbro | 99-04 | 3 | September 22nd, 2008 01:37 AM |
| Tork Tech? | Cricket | 99-04 | 5 | July 5th, 2008 02:59 PM |
